ECX Torment?
ECX Torment?
I ran the torment at my lhs indoor carpet offroad track yesterday for my first race. It was the open/novice class. I know the torment is not as good as the other trucks, but figured I'll try it out to see how it does. Running it stock, except for adjustable turnbuckles, it seamed to have a ton of oversteer and had a hard time getting it make the sharp turns. I know it has a higher center of gravity then the onther trucks. Is this why is does not handle well? Is there anything I could do to it to make it turn/handle better. I know getting a better truck would make the best upgrade, but not really in the budget. I don't mind upgrading it, but juist wonder if it will actually make it any better.(I know more track time will help, but know the truck can only run so good)Thanks for advice.
Correction, I ment it has a ton of understeer
Yea the servo is painfully slow in stock ECX trucks. Upgrade that and get some decent tires for the surface you are running on.
Props to you for trying out a entry level hobby grade RC and racing it too!
Thanks guys. Is there a certain servo I should look for or will any high speed/torque do the job.
