Tekno SCT410 Thread
i was gonna put 7000 in the f/c/r diff for racing outdoors..would this be ok?
thanks
thanks
will slash offset wheels fit the SCT410
Tech Legend
give the latest recommended outdoor setup a look. Even if the vehicle isn't a full sct410.3 you can still see benefits it appears.
I am to Tekno SCT 410 and need advice on seting up the truck as a bmx track basher.
I got a Castle creations 2400KV motor using 2-3s unsure of gearing
As my previous sct was a Slash 4x4. Which are two different beast from what I hear.
Im interested in the oval setup👍
On Monday night theres a parking lot asphalt oval racing at a restaurant and I've been working on a good setup. There an open 1/10 scale class that has a little rubbing and i figured this would be perfect 🐂
Since your running on asphalt, I would run my spring collars all the way up to get as low as you can. Stand up the left side shocks, and lay down your right side. It shouldn't take too much to get it to handle.
On 2s, that thing is going to be a sloowwww roller with that motor. You'll need to step it up to 3s and I would probably start with something like an 18t pinion and go up or down from there depending on your temperatures.
