Short Course set up tips!
Hey guys, The track I run majority of the time is carpet and really grippy. With my SC10 2wd it has a tendency to roll over in corners a lot! what set up tips can help this? Any help would be appreciated. Thanks.
The way I have mine setup for indoor carpet is a tight front end and a loose back end. That way when you dive into a turn, the turn in is immediate and the rear isn't trying to fight you. I've never traction rolled with this setup and it is extremely forgiving. Also more or less steering is easily adjustable with the toe.
Lay the front shocks down, light fluid in the front. one step higher fluid in the reas with the shock position in a more upright position.
