Like Tree36Likes
Old 01-21-2013, 01:00 AM   #1321
Boz
Trader Rating: 23 (100%+)
Originally Posted by frito View Post
Has anyone tried running same fluid front and back?on diffs ..my car is just so sketchy , if you soften for bumps it won't stay planted in turns..I'm driving car so much harder than should to keep the pace..
I have be using 7/7 for the last few race meets. Last week I tried 5f/4r and 7f/5r they where both a little unpredictable off one of our jumps. Its a small jump that you hit with some speed and land with speed on power. This week I'll make up the spare diffs with 10/10 and try them.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 01-21-2013, 01:26 AM   #1322
j0pp3's Avatar
Originally Posted by BentKa View Post
I have a few brand new spare sets of front & rear towers if you want a set
PM me for a low price including shipping to you.
Bent
Originally Posted by niggs98 View Post
have 4mm grp ones in stock as well as a bulkhead strengthener. set for 25 posted to sweden if needed
Thanks guys!
I'm thinking about creating some towers and reinforcements my self. I'll contact you if I fail and see if the deal still exists
j0pp3 is offline   Reply With Quote
Old 01-21-2013, 02:00 AM   #1323
doorz's Avatar
1st full meet,,shocks leaking,,diffs leaking,,car feels ok,,but..
will try a different setup,,rear felt too stiff,,rotating too much,,does anyone know the stock rear toe-in,,kit says 3deg,,,is this fact ?,,
has anyone tried changing ackerman ?
car is quick...............yeh.............
Cheers,,BAGGZ:
________________
ACE HOBBIES:ASSOCIATED:
REEDY:ORION:JCONCEPTS:
doorz is offline   Reply With Quote
Old 01-21-2013, 02:08 AM   #1324
doorz's Avatar
I made my own tower braces,,exactly like the upgrade kit,but for both towers,
out of 1.4 ally sheet,,also made up some blocks to fit behind front bulkhead mounted with longer screws on the front of top deck to strengthen,and had some epic tumbles with NO breakages at all,,
Cheers,,BAGGZ:
________________
Old 01-21-2013, 06:05 AM   #1325
OleC's Avatar
What surface are you running on?
JQ The Car Black Edition - O.S. - BUKU - AKA - Byron - Sanwa - Savx
No sponsors. I drive what I like, and so should you
OleC is offline   Reply With Quote
Old 01-21-2013, 06:58 AM   #1326
Racerx336's Avatar
Trader Rating: 34 (100%+)
Really starting to get a feel for this car. I still need to try a stiffer sway bar and some three stripes for the front, but even still, the car is coming along great. I have been able to take the win in our last couple of club races and a couple of the other RCA drivers and I have been trying some different things as far as setup goes. I will post my current setup sheet later tonight.
-Andrew Clark-
/ Nemo Racing USA /Agama / Pro-line Racing / VP Powermaster / RC Shox / Triton RC / Dutch Oven Designs / Paradise Air / TIX RD /
Racerx336 is offline   Reply With Quote
Old 01-21-2013, 11:59 AM   #1327
Default Thanks for the set up help Andrew
Your car looks great on the track Andrew, very balanced. After your set up ideas, my car was much easier to push harder. One thing I added was .5 up, .5 down to add more front kick up. Smoothed out the steering a little more.
I did manage to break 3 ball cups in the outer rear at the thread in part. They where 3 off kilter crashes trying to stretch for the center triple. I shouldn't have gone for it but the car was giving confidence. I think I'm going to go to 1 up, 1 down for maximum kick to see how it feels.
Thanks again.
losi b is offline   Reply With Quote
Old 01-21-2013, 02:24 PM   #1328
Boz
Hard pack clay, very dusty.
Here is a video which a club member took and its was my first run with the car.
http://www.youtube.com/watch?v=AgK_E...ature=youtu.be
Setup (not the setup in video)
http://forum.teamxray.com/xform/inde...D=22&setup=xb4
Chris Bozich
Xray XB8 XB4 XB2
Old 01-21-2013, 03:32 PM   #1329
Racerx336's Avatar
We have been going thinner on our diff oils with tons of positive feedback. I am currently at 5k/3k and it is the best the car has felt. The lighter the oil, the more corner speed you carry and the smoother the car feels.
-Andrew Clark-
Old 01-21-2013, 04:47 PM   #1330
Boz
It tried 5f/4r last race meet and I ended up putting the 7/7 back in.
Is your track very smooth? As in like it has just been rolled.
Chris Bozich
Xray XB8 XB4 XB2
Old 01-21-2013, 05:06 PM   #1331
Tim Garland's Avatar
Car look good Chris. I just went to a 2 hole piston all around, drilled to 1.6, oil 30/25. Car was smoother but lost traction coming from a stiffer setup. What effects did you see going to 7k in the rear?
RacePro Hobbies
RadioActive RC Raceway
Tim Garland is offline   Reply With Quote
Old 01-21-2013, 05:13 PM   #1332
Racerx336's Avatar
Our track is far from smooth. We are already developing holes and ruts in multiple sections of our track and we just had a rebuild two weeks ago, it is just the nature of our dirt unfortunately. Also, our track rarely gets more than medium traction, this past weekend I would say the traction was very low for the most part. I know when I went down to 5k in the front, I instantly had a ton of initial steering and turn in. It took me a few packs to relearn braking points and when to initiate the turn because it was so different. For now, I limited my dual rate on the radio a bit and it has allowed me to really push the car without fear of turning into a pipe. Once I get the 3 stripes on the front and a stiffer front sway bar, I will gradually increase my dual rate back to 100%.
-Andrew Clark-
Old 01-21-2013, 05:13 PM   #1333
seth556's Avatar
Trader Rating: 42 (100%+)
On what surface is that?
Hard packed indoor clay track. Barcode type track. It was a little too dusty for slicks in my 2wd but on my XB4 I could get away with them, didn't want to burn through tires.
Next up to try is thinner diff oils. Everything besides the shock oil/pistons I tried I've reverted back to the stock setup. Drove the car for 2 races without the front sway bar since every other buggy doesn't use it on clay, but I put it back on and it was much more consistent and easier to drive off power. So if anyone was thinking what I was thinking, just remember it's not any other buggy.
seth556 is offline   Reply With Quote
Old 01-21-2013, 06:07 PM   #1334
Boz
Thanks Tim. It looks even better on the track with the setup I posted.
The car was very balanced in the corners when using the same diff oils front to rear. It was something that I did when running a DEX410. I went down to the bottom hole on the rear shock tower which helps with the rear traction.
The 30 in your front shocks may be a little light (but I will try it one day). What brand of oils are you using?
Chris Bozich
Xray XB8 XB4 XB2
Old 01-21-2013, 06:39 PM   #1335
Yep 30 is way to light with the 1.6 pistons. The track that I tried that with is VERY bumpy, car is almost never solid on the ground. It felt better with the soft, no pack setup, but on the clock was about .5 sec a lap slower. I guess it would never put any weight to the tires so I lost traction everywhere it seemed. The oil is ae so just a bit heavier than cst. The car rotates very well but I tend to get back on the power to fast making it just to free for me on exit.
RacePro Hobbies
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
