Like Tree52Likes
Old 01-18-2013, 10:54 AM   #1291
Odin544's Avatar
Trader Rating: 93 (100%+)
Xray has posted their solutions to the issues people have had. Scroll to the bottom.
http://www.teamxray.com/teamxray/new...rade%20Package
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 01-18-2013, 11:23 AM   #1292
Trader Rating: 19 (100%+)
I can admit I didn't grease mine and sure enough it popped out. I remember forgetting to grease it during the build. Funny how following instructions seems to solve most issues...
I bet Exotek or someone comes out with blinged out aluminum ones though.
Cars I've Owned: Tekno EB48 & SCT410, AE 8.2e, AE SC10 4x4, MBX6e Tekno V4, Xray 808e, Xray 8Te, Losi 810e, Losi SCTE 4x4, Losi 22, Hot Bodies Ve8, Losi 8te, and plenty of Traxxas
Sponsors: Visa, Mastercard, Amex, and my wife's bank account.
Edumakated is offline   Reply With Quote
Old 01-18-2013, 12:03 PM   #1293
Odin544's Avatar
I agree. I was surprised when I built the first one (a friends) that they were plastic. If a metal one comes out I think I would get them just for piece of mind. I ordered a bunch of little things for mine and am in the process of building it now. Looking forward to running it, but that wont be for a month or so.
TriCitiesRC.com
Old 01-18-2013, 01:43 PM   #1294
CarlCrocco's Avatar
Trader Rating: 88 (100%+)
I use the barrels and pins from the durango dex410. The pins have a flat spot and a set screw. They won't come out.
You can also use the dex410 o rings from the big bore shocks to prevent the shocks from leaking.
Andrew Crocco "The Hammer"
Viper R/C
XB9E XSCT
CarlCrocco is offline   Reply With Quote
Old 01-18-2013, 02:14 PM   #1295
Thanks for the tip! I'll have to pick up some of those.
Old 01-18-2013, 04:28 PM   #1296
Originally Posted by OleC View Post
I have spoken to a couple of XB4 owners who also had broken outdrives, but I think that was on the rear of the car.
One of them blamed too much uptravel.
I dont know, but I see that Martin Bayer used 2mm washer + o-ring on the damper shaft on his latest setup (DHI race in Denmark). Maybe he was worried about the same thing?
I checked my driveshafts and they have small scuffings from the outdrives, so I guess I`ve been pretty close myself. I think I`ll add an extra o-ring on the damper shafts.
I'll try an extra o-ring there, thanks! Nice tip, the out drives are $37 in the lhs here in Norway, so looking at 1/4 of a new car in spare parts already. Considering.....
XB4, B44.2, DXR8, EXO, Sakura Zero, Sakura D3 CS, Trx Rally 1/10, Summit 1/10, E-Revo 1/10, Rustler vxl, Futaba 4PKS-R.
AlekB is offline   Reply With Quote
Old 01-18-2013, 07:17 PM   #1297
Suspended
Default just broke.....
just broke my outdrive on the rear diff ....
poorboy racing is offline   Reply With Quote
Old 01-18-2013, 07:19 PM   #1298
kman16jr's Avatar
Trader Rating: 53 (100%+)
did you have limiters in the shock retainer to decrease uptravel?
Kevin Welfley
AE rc8b3-AE rc8b3e-AE b64d-AE b6d-AE b6
Sponsors:|DDHrc|Team Trinity|Jconcepts|Rc Adiction Products|NitroPro Fuel|M2c racing|Ultimate racing engines|Highest servos|Bellgate Distibutors|
kman16jr is offline   Reply With Quote
Old 01-18-2013, 07:27 PM   #1299
just got a tamiya trf502x & im really kicking myself for not buying the xray...... the real difference its how easy the parts are to go for the xray. both have great quality but support on parts xray is everywhere not so with the tamiya. so you maybe looking at a new xray owner very soon.
Kakenballs is offline   Reply With Quote
Old 01-18-2013, 08:34 PM   #1300
Xyzzy's Avatar
Trader Rating: 28 (100%+)
I have noticed that the it seems the gears are absorbing the diff oil. My diffs don't leak, but when I have checked them they are nearly empty! No oil residue within the diff housing, so I am assuming the gears are some how absorbing a lot of the oil.
I haven't had a chance to run mine yet but I did open one of the diffs to check the oil level and it was low. I don't have a before/after weight for the gears but your assumption that they absorb oil seems possible, although it is something that seems odd.
That said, I'm going to just throw in NT1 metal gears and pins and call it a done deal. I know they will work and there won't be any weirdness with them.
I imagine there is a good reason why XRAY would go to the effort to use composite gears but after thinking about it for a real long time the little engineer in me isn't able to come up with a compelling reason.
Satellite gears - they are made by purpose from composite, they are lighter and have better dynamic performance. They are molded from very special composite mixture and have very good reliability. The same gears from same special material are used in the T4 and NT1 gear diff and the traction on foam tires on asphalt is several times higher than on a buggy track. Since there are no problems with the NT1 gear diffs at all there is absolutely no need for any worry about the composite gears for XB4. However if you want to feel more safe you can use the NT1 metallic optional gears #335030, they are direct fit.
I'm assuming "better dynamic performance" means "lighter rotating weight". If so, we are not talking about much given the weight of the drive train, wheels and tires. My only concern might be where the new weak link in the system will be. Hopefully proper adjustment of the slipper clutch will mitigate that.
PS - If anyone decides to produce heavy-duty CVD caps I'll be first in line to buy them.
Xyzzy is offline   Reply With Quote
Old 01-18-2013, 09:29 PM   #1301
Default Metal ring
Dont know if it will hold but Im giving it a try. Wil report after the weekend. Its a snug fit over the plastic cover. I put CA glue to help hold it in place.
Part # is on the tag.
Sponsers: Schumacher, Santiam Hobbies, Fantom Racing, Racing-cars.com, Flawless RC, Discountrcstore.com
Theroc is offline   Reply With Quote
Old 01-18-2013, 11:12 PM   #1302
doorz's Avatar
I did the same thing using assc collars from the 44,,then held the soldering iron on the collar for a little bit,,seems to have seated nicely,,will be trying tomorrow,,
Someone will bring out ally ones,,
Cheers,,BAGGZ:
________________
ACE HOBBIES:ASSOCIATED:
REEDY:ORION:JCONCEPTS:
doorz is offline   Reply With Quote
Old 01-19-2013, 06:22 AM   #1303
GMartinez's Avatar
Trader Rating: 85 (100%+)
Attachment 1019549
Another method & might be less expensive I did this fix on my tamiya off road
cut some heatshrink place it over the cap I used a thicker shrink & never had an issue afterwards.
I have not had any issue so far but this is what I would of done
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-19-2013, 08:12 AM   #1304
j0pp3's Avatar
Broke the front tower today and not a single seller seem to have it in stock in my country
The car runs like a dream though (when it's not broken). Seven packs through now. Still looks new underneath since I'm running on carpet.
j0pp3 is offline   Reply With Quote
Old 01-19-2013, 09:05 AM   #1305
BentKa's Avatar
I have a few brand new spare sets of front & rear towers if you want a set
PM me for a low price including shipping to you.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
