Like Tree39Likes
Old 01-17-2013, 01:58 PM   #1276
Tim Garland's Avatar
Originally Posted by Jamison R View Post
Ready for Saturday
Nice looking paint!!
RacePro Hobbies
RadioActive RC Raceway
Tim Garland is offline   Reply With Quote
Old 01-17-2013, 06:21 PM   #1277
kman16jr's Avatar
Trader Rating: 53 (100%+)
Ok so what are all of the issues with the buggy?Im going to buy one anyways just want to know what to mod/replace/and keep on top of mainly.Im not a bad driver and never usually mess up so i know that might take most of the problems away but need to know most of the issues.
So far i see:
*leaking shocks and diffs(maybe a selant?)
*possible outdrive issue(upward travel easily fixed)
*shock tower breakage(ca them and maybe flanged locknuts & countersunk washers to strengthen?)
*diff cases(maybe not land upside down so much?)
*diff gears(maybe a case issue or shimming issue?)
Anything else?I can fix most of the issues above already.
Kevin Welfley
AE rc8b3-AE rc8b3e-AE b64d-AE b6d-AE b6
Sponsors:|DDHrc|Team Trinity|Jconcepts|Rc Adiction Products|NitroPro Fuel|M2c racing|Ultimate racing engines|Highest servos|Bellgate Distibutors|
kman16jr is offline   Reply With Quote
Old 01-17-2013, 06:39 PM   #1278
asc6000's Avatar
Trader Rating: 15 (100%+)
My shocks stopped leaking after a few rebuilds, the tops of the bodies got some love.
My diffs leaked because of mechanic error, also stopped leaking after a few rebuilds.
Yup on checking shock travel VS the outdrives, like any car.
The original towers are junk, the FREE upgrade should be better, the braces should end that issue.
The diff cases need more beef or a slightly altered plastic blend. Perhaps the tower braces will help a bit.
No issues here with gears. Slipper set a little on the loose side. Do a bench test, don't trust the calipers. It will loosen a bit after a few runs but not too much.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 01-17-2013, 07:23 PM   #1279
kman16jr's Avatar
Ok so green slime for the shocks and diff orings as a precautionary measure,orings for limiting,gears should be fine with a 6.5 and i never have a super tight slipper so diff gears should get a break,And possibly of the bulkhead braces just in case and maybe the aluminum towers if the cf ones are a problem
Kevin Welfley
Old 01-17-2013, 08:36 PM   #1280
kman16jr's Avatar
Also will associated spur gears fit in this? The pads look like associated pads so the gears might work?
Kevin Welfley
Old 01-17-2013, 08:37 PM   #1281
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Nope.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-17-2013, 08:39 PM   #1282
kman16jr's Avatar
Originally Posted by aloksatoor View Post
Nope.
dang,whats so different about the 2?just curious,i have never seen the xray gear out of the car so im not sure how to compare.
Kevin Welfley
Old 01-17-2013, 08:42 PM   #1283
Autocratic's Avatar
Trader Rating: 26 (100%+)
Nope.
Actually AE type spur gears do fit.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 01-17-2013, 08:43 PM   #1284
kman16jr's Avatar
With the xray pads or with the ae pads?
Kevin Welfley
Old 01-17-2013, 08:52 PM   #1285
seth556's Avatar
I think the diameter of the hole is different. But just get a spare stock spur and you'll be fine.
When you build it get a tube of black gasket sealant for the shock cap threads and the diff gaskets and you'll be set. And some shock towers, the washers don't help. Or wait for the upgrade package to be out.
seth556 is offline   Reply With Quote
Old 01-17-2013, 08:54 PM   #1286
kman16jr's Avatar
ok that sounds good seth,ill be at holeshot this sunday if your there so i can get with you on the towers also.
Kevin Welfley
Old 01-18-2013, 12:21 AM   #1287
Does anyone have a fix for the CVD pin pushing thru the plastic cap? Mine push thru front driveshaft and chunked my composite chassis underneath the cvd. I dont think shrink wrap will work because it poked a hole clean thru the plastic.
Thanks,
Rocky
Sponsers: Schumacher, Santiam Hobbies, Fantom Racing, Racing-cars.com, Flawless RC, Discountrcstore.com
Theroc is offline   Reply With Quote
Old 01-18-2013, 12:57 AM   #1288
Rampokker's Avatar
AE spurs don't fit. The center hole is much smaller than the xray spurs. Its possible to drill the hole out to 6mm diameter, but make sure the drill is centered properly on the spur. The xray slipper pads are just a little bit too big for the AE spur, but the AE slipper pads fit fine together with the spur if you've drilled the center hole.
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
Old 01-18-2013, 12:58 AM   #1289
RShockley's Avatar
Thanks,
Rocky
I think Xray said to make sure there was plenty of black grease in the cvd should stop this.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 01-18-2013, 01:15 AM   #1290
Yah I did that. I only have about 10 packs thru the car. I broke the shock tower 2nd time out so its been siting.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
