Like Tree38Likes
Old 01-16-2013, 04:00 PM   #1261
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Edumakated View Post
so I bought all three sets the had just to be safe.
my brother from another mother
I've had the motor screws come loose twice. Must be those pancake landings.
Suggest loctite on those.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 01-16-2013, 04:09 PM   #1262
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Yep the motor screws got me too. Bought out all the spur gears amain had (only two ).
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-16-2013, 09:45 PM   #1263
Xyzzy's Avatar
Trader Rating: 28 (100%+)
This is the first kit I have ever built (and I have built too many) that purposely does not include a cap for the antenna tube.
I'd love to hear the engineering/bean-counter discussion on that one!
Xyzzy is offline   Reply With Quote
Old 01-16-2013, 10:43 PM   #1264
Odin544's Avatar
Trader Rating: 93 (100%+)
What do you need one for? Antennas are increasingly shorter and shorter I just bought a new micro rx for my 4PL that has the antenna inside the rx. I haven't had an antenna stick out of any of my cars in 2 years.
Save on cost I would imagine.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 01-16-2013, 10:54 PM   #1265
Boz
Trader Rating: 23 (100%+)
Had my first issue with the car last night while practicing. The set pin for the front drive shaft managed to punch through the little plastic collar and basically stopped the drive train while going full bore down a straight away . Dug a little hole in the chassis, but nothing major.
Fortunately, the internal satellite gears stripped which probably kept it from doing more damage. Luck would have it, the hobby shop had NT1 composite gears in stock so I bought all three sets the had just to be safe. They are a direct fit.
I have noticed that the it seems the gears are absorbing the diff oil. My diffs don't leak, but when I have checked them they are nearly empty! No oil residue within the diff housing, so I am assuming the gears are some how absorbing a lot of the oil.
So, you are saying that we should marinate our diff gears in oil first?
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 01-16-2013, 10:58 PM   #1266
aloksatoor's Avatar
Easy to test. Use a digi scale, weigh the dried out gear from an old diff. Then weigh the brand new one which will come with the upgrade v2 parts.
Old 01-17-2013, 12:03 AM   #1267
Stripe's Avatar
Hope the upgrade-package will arrive this week, then we can measure.
Untill now the diffs hold up very well and run extremely smooth
Stripe is offline   Reply With Quote
Old 01-17-2013, 12:38 AM   #1268
Originally Posted by Tim Garland View Post
I would say the bone travelled beyond the limit if the outdrive causing it to break. What does the bone look like, is it bent, and can it travel the full stroke of the shock without binding in the cup? Did you have any rolling crashes before it broke?
The bone seems fine, dont think there was anything wrong with the travel, the dff case and diff is disassembled so cant really see it.. Not my day at the track so yes, had a couple of bad tumbles.
XB4, B44.2, DXR8, EXO, Sakura Zero, Sakura D3 CS, Trx Rally 1/10, Summit 1/10, E-Revo 1/10, Rustler vxl, Futaba 4PKS-R.
AlekB is offline   Reply With Quote
Old 01-17-2013, 01:00 AM   #1269
Trader Rating: 65 (100%+)
What site sells the Composite Gear Differentials? I can't find them anywhere...nt1 or/ xb4.
nrm1977 is offline   Reply With Quote
Old 01-17-2013, 02:43 AM   #1270
OleC's Avatar
I have spoken to a couple of XB4 owners who also had broken outdrives, but I think that was on the rear of the car.
One of them blamed too much uptravel.
I dont know, but I see that Martin Bayer used 2mm washer + o-ring on the damper shaft on his latest setup (DHI race in Denmark). Maybe he was worried about the same thing?
I checked my driveshafts and they have small scuffings from the outdrives, so I guess I`ve been pretty close myself. I think I`ll add an extra o-ring on the damper shafts.
JQ The Car Black Edition - O.S. - BUKU - AKA - Byron - Sanwa - Sav÷x
No sponsors. I drive what I like, and so should you
OleC is offline   Reply With Quote
Old 01-17-2013, 09:50 AM   #1271
Suspended
Default the xb4 is for real.....
ive been racing a cat sx3, and a b44.2, and my track record was 19.00, but last night i raced my xb4 with the same tires and electronics and i turned a 18.6 during the race and my top 5 average laps were 18.7 and i didnt break the harder i pushed the xray the better it stuck....
the xb4 is super nice...
ill tear my diff apart and see if the permatex 2 stopped them from leaking and let you guys know.
has anyone tried any o rings on the shock caps to keep them from leaking and if so which ones fit good.
poorboy racing is offline   Reply With Quote
Old 01-17-2013, 10:10 AM   #1272
Trader Rating: 19 (100%+)
I had the same experience with my xb4. Literally cut my lap times from my Dex by about .5 second by the time I ran a second pack through the car. Freaking amazing. The car is so easy to drive it is scary.
I just put a little black grease on the shock body threads and I haven't had any further leaking.
Cars I've Owned: Tekno EB48 & SCT410, AE 8.2e, AE SC10 4x4, MBX6e Tekno V4, Xray 808e, Xray 8Te, Losi 810e, Losi SCTE 4x4, Losi 22, Hot Bodies Ve8, Losi 8te, and plenty of Traxxas
Sponsors: Visa, Mastercard, Amex, and my wife's bank account.
Edumakated is offline   Reply With Quote
Old 01-17-2013, 11:44 AM   #1273
Suspended
Default xb4
k thanks ill try that with the shock caps....
Old 01-17-2013, 12:02 PM   #1274
aloksatoor's Avatar
Another glowing review. THe schumacher I had was fast but too difficult to keep running with all those belts and bearings and not knowing what went wrong. The xb4 on first outing was like WOW this is a shrunken down ebuggy .
Old 01-17-2013, 01:28 PM   #1275
Trader Rating: 55 (100%+)
Ready for Saturday
Jamison R is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
