Like Tree44Likes
Old 09-20-2017, 04:15 PM   #12511
suzukipro's Avatar
Trader Rating: 22 (100%+)
I'm not sure if this has been tried or tested before but I inverted the RR +2 hanger to lower the roll center of the hinge pins searching for rear grip. I measured with calipers and believe doing this gets the RR hinge plate 1mm lower than with the standard (Non+2mm) RR hanger. I was previously running the +2 RF & RR hangers and now switched it up to the standard RF & RR+2 brass hanger (upside down).
I'll have to wait until this weekend to see how/if it works running on low to med bite hard packed dirt, but it seems functional on the bench.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 09-20-2017, 07:50 PM   #12512
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by symmetricon View Post
I'm using the Jconcepts 22-4 rims front and rear... will let you know which hexes when I get home, can't remember off the top of my head.
1 stripe front and 2 stripe in the rear...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 09-22-2017, 10:19 AM   #12513
I am going to give my daughter my XB4 2017 and will be putting a 17.5 in it. What spur and pinion size would be good? This would be on a large clay track(OCRC).
AJrollin is offline   Reply With Quote
Old 09-22-2017, 12:22 PM   #12514
Originally Posted by 92Mracing View Post
I read some previous comments in this thread about the X-ray wheels not holding up well, and a lot of people using different hexes with TLR wheels.. My LHS stocks JConcepts Wheels so I'd like to use what he carries on my 2016 XB4, does anyone know which JConcept wheels with which hexes would be best? Thanks in advance.
Been using xb4 with Xray wheels for a few seasons and never had an issue breaking them.. Wheels tested on various conditions with 6.5t motor, indoor carpet, rough outdoor 1/8 offroad tracks with huge jumps (unfortunately dont have any proper 1/10 offroad tracks around). Never, i mean never have broken a single xray wheel.
JanisK is offline   Reply With Quote
Old 09-22-2017, 01:09 PM   #12515
Trader Rating: 33 (100%+)
ive never broken any wheels.. although i will agree, they are softer than most.. however.. i believe bent made a comment saying the wheels are soft for a reason..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 09-24-2017, 03:48 AM   #12516
Blue 31's Avatar
I'm running 69/31 in my daughters 2017 in 17.5. TO get the 69 tooth spur I've got at Bezerk slipper eliminator. Gives a FDR of 5.565.
The problem is not the problem. Your attitude to the problem is the problem!
www.adelaiderc.com.au - Team Driver
[email protected]
ARCR Member
TLR 22 3.0 Mod, TLR 22T 3.0 Mod, AE B5M Stock, XRay 17 XB4 Stock.
Blue 31 is offline   Reply With Quote
Old 09-25-2017, 09:36 AM   #12517
suzukipro's Avatar
So it didn't work out as expected, I found that the setup above gave too much anti squat and it was still loose. running minimal anti squat seemed to help things out considerably though. I ended up using the standard RF toe plate and the +2mm RR toe plate and it reduced the loose rear my car was having on lower to mid bite.
Eric
Old 09-28-2017, 05:35 AM   #12518
snwchris's Avatar
Are most of you running or using the Slipper for running on Carpet?
Our local indoor dirt track changed over to carpet and will start running soon and so used to using the Center Diff. I'll be running Mod 4w with a 6.5 motor as well.
snwchris is offline   Reply With Quote
Old 09-28-2017, 06:03 AM   #12519
I found the slipper to feel more stable while the c diff allows for more off power steering and also allows for you to land on power with more confidence. I actually prefer the the slipper however I have switched to 13.5t (gaining a ton of popularity) and a slipper delete or C diff are the best options due to a significant weight reduction over the slipper.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 09-29-2017, 05:12 AM   #12520
When I bought my kit I bought 12mm 0mm F/R wheel hex's. What hexs do you guys like for indoor med/high grip clay. I use xray wheels as well. Wondering what is the stock width and what width folks are liking. Thanks
racingnewb is offline   Reply With Quote
Old 09-29-2017, 05:26 AM   #12521
snwchris's Avatar
First page of this thread has a listing and PNs of 12mm hexes and common wheels to use with them as well.
Most who have gone to the 12mm hexes are using the +0.75mm (#365355) on the front and +1.5mm (#365356) on the rear using
standard 12mm rear wheels and TLR 22-4 front wheels. Car becomes very stable with this combination.
Old 09-29-2017, 12:52 PM   #12522
I checked the first page before posting but wanted to hear others opinions on the width. Thanks for the your recommendation chris. I'm thinking about going w/ 1 stripe all around. I guess the way my car is now i'm running 243 rear and 243.5 front. I've never fooled w/ track width so I'm not sure what running a narrower rear end is doing. I'm trying to decide if it's worth spending 40 bucks to get the front and rear the same width. As well as if running .5mm narrower in the rear is hurting the cars performance on indoor clay. I am happy w/ xray wheels and have a fair amount of them so I will be sticking w/ xray wheels.
Old 09-30-2017, 03:06 PM   #12523
I use the 12mm +0.75mm front +1.5mmrear with kyoshozx6 fronts w5201w rims and TLR22 tlr7100 rears, the kyosho fronts give a little more thread sticking through than the tlr fronts.
BiLL77 is offline   Reply With Quote
Old 10-01-2017, 07:36 AM   #12524
Thanks Bill77
Old 10-01-2017, 01:38 PM   #12525
Low_E's Avatar
Send a message via MSN to Low_E
Two questions:
How can you recognise the type of chassis guard that is mounted on a car? I bought a second hand car and would like to know which chassis guard: medium of hard, is mounted on the car. Is there a marking somewhere?
Why use a “slipper delete” in stock-classes? Could you not just tighten the slipper to a rock-hard non-slip position?
Low_E is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
