Like Tree52Likes
Old 03-01-2017, 01:31 PM   #12136
B44
B44's Avatar
where's a good place to order online parts, looking for option parts for xb4 2017.
steering plate, rear springs, sway bars, etc THANKS
B44 is offline   Reply With Quote
Old 03-01-2017, 01:40 PM   #12137
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
Amain.com has a good selection of parts
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics |
Jeremy Potter
yzracer758 is offline   Reply With Quote
Old 03-01-2017, 02:49 PM   #12138
Originally Posted by Pville Stig View Post
My local track was a high bite clay, now we are moving to turf so if the composite gears are not strong enough ill let you know...
I have never noticed a lack of punch between a 3000 to 5000 mah battery. The reduction in weight should compensate if there is any. I corner weigh my car to give it the correct balance front to rear and side to side.
Ok thanks. I tried the Orion 3800 today and it felt great Could not note any difference in punch vs my 5000 mah
Is the car more silent with the composite gears?
benstian is offline   Reply With Quote
Old 03-01-2017, 04:37 PM   #12139
I sure am glad I gave up on the b64d and got the xb4 for christmas. There's already a few pages on how to shim your diffs. My xb4 diffs felt perfect building them to manual specs. I think it is crazy that AE's manual says to use 7 shims. To me that sounds like some crappy molds/design if you need 7 shims. Anyway I get to run mine this Sunday as long as the weather allows me to drive over to bumps/jumps.
racingnewb is offline   Reply With Quote
Old 03-01-2017, 05:24 PM   #12140
suzukipro's Avatar
Trader Rating: 23 (100%+)
Anyone ever have any issues with the stock 14 composite shock caps. The aluminum exotek ones I've always run on it have worn out inside the eyelet and have lots of slop. I have some composite ones on hand, but am concerned they might pop off or leak...
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 03-01-2017, 05:36 PM   #12141
Not a single issue nor a drop of oil out the stock ones I've had on mine.
Tony Vega is offline   Reply With Quote
Old 03-01-2017, 05:38 PM   #12142
suzukipro's Avatar
Good to hear
Eric
Old 03-01-2017, 06:27 PM   #12143
Trader Rating: 20 (100%+)
just finished up the xb4 17 and was wondering what is a good ride height to start off with it being box stock
toyota 2jz is offline   Reply With Quote
Old 03-01-2017, 06:32 PM   #12144
Trader Rating: 29 (100%+)
19-20mm
DustinEich is offline   Reply With Quote
Old 03-01-2017, 06:34 PM   #12145
Originally Posted by DustinEich View Post
19-20mm
front/rear? thank you for the response!
Old 03-01-2017, 08:36 PM   #12146
Pville Stig's Avatar
Car is pretty quiet. You will notice significant improvement in acceleration and deceleration. Car will feel more on edge though.
RC America/XRAY
LRP America
AKA Products
Pville Stig is offline   Reply With Quote
Old 03-01-2017, 09:11 PM   #12147
Slapjack's Avatar
Trader Rating: 19 (100%+)
19-20mm
What length are you running your shocks at (from the bottom of the lower cap to the top face of the shock end) to get this ride height?
Slapjack is offline   Reply With Quote
Old 03-02-2017, 05:26 AM   #12148
snwchris's Avatar
On my 16 XB4 I'm running 20mm ride height F & R
snwchris is offline   Reply With Quote
Old 03-02-2017, 08:49 PM   #12149
Slapjack's Avatar
Screwing down the shock eyelets is how I would lower the ride height tho right? I'm at like 25mm right now.
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Old 03-02-2017, 09:09 PM   #12150
suzukipro's Avatar
Be careful not to screw the shock eyelets down too tight or it can cause the ball ends to bind. To lower ride height you adjust the shock collars up (to lower) or down (to raise).
Eric
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
