Xray XB4 thread
LMAO.... yea and the constant what wheels and hex questions for 59pages, LOL
Team Tekin
Pink & Blue seems to be a trend
Joe's Cabin Fever TQ /\ up there
do you use chassis protectors on your '17s ? i dont for now because i play on astroturf but im too intimidated of scratching it :P That black is neat!
These 2 barrel-washers which go inside the plastic are ultra-tight on my new '17 when i tight the screws from beneath with the anckerman and the servo is not steering so freely. Is it normal? or shall i trim the inner holes a little?
Is the steering smooth?
It should be effortlessly free to move when not connected to the servo. If it's not I would verify you have everything assembled correctly. Remove any and all flashing. If that doesn't fix it. Start filing.
And this happens only when i fully tighten the screw. But obviously i cannot run with not fully tightened screws on anckerman.
And this happens only when i fully tighten the screw. But obviously i cannot run with not fully tightened screws on anckerman.[/QUOTE]
I wouldn't grease them. I would say that if it happens fully tight that either they were over tightened and deformed either the barrel or the Ackerman plate or the plate is just a hair too thick and getting a bit of a bind. I'd pull it off and scrape/ file it flat again. I can't remember if the plate is aluminum or composite...
the anckerman is composite but i also have an exotek aluminum and it does the same on both.
I would take a little material off of the steering arms that the barrel slides through so the barrel has a touch of play up and down. Just to verify, you have the T end of the barrel washer above the steering arm and below the Ackerman plate? Ackerman is not rubbing on the upper chassis brace?
