Xray XB4 thread
#1187
This is the level of customer support that the rest of the industry should aspire to.......
Talking about standing by your reputation!
#1188
anybody have thoughts on favorite set-up for moderate sized clay tracks...using an orion 8.5t...
-pinion?
-oil?
-slipper?
-ride height?
-chassis stiffness?
-etc?
I haven't gotten mine to the track yet...but the only changes I've heard of from the base setup at my track is 23 for ride height and a weird combo on the chassis mixing up the screws...not sure on the slipper
-pinion?
-oil?
-slipper?
-ride height?
-chassis stiffness?
-etc?
Slipper is just little loose by feel. 26mm rear 25mm front rideheight. I took all the screws out o the bottom for flex. I removed both swaybars. Went to 4k diff oil in front, 1k diff oil in rear. Car was best its been yet!! First time I could push the car hard I've not had problems w/gears stripping, or shocks leaking. But I did break rear shock tower @ camberlink ball. I've since replaced them w/ TeamSR CF 4mm and it seems bullit proof now! Glad Xray addressed the issues.
#1190
Despite the long term performance and durability testing to which the XRAY XB4 was subjected by the factory and R&D team, several XB4 customers have reported minor issues in crash situations. XRAY has been well known to fully stand behind their products and is known for providing first class customer service and support. Even though the reported issues have affected only a small portion of XB4 owners, XRAY felt that it would be prudent to provide a free XB4 upgrade package to all XB4 owners through the shop where the kit was originally purchased.
The set includes:
- Reinforced Front Bulkhead V2
- Differential Bevel Gear 35T Front & Rear - V2
- Front Shock Tower Protector
- Rear Shock Tower Roll Center Reinforcement
- Replacement Diff Satelitte Gears (no change, just free spare)
Read here for more details and some important Tech Tips: http://www.teamxray.com/teamxray/new...kategoria=2995
The set includes:
#1192
The box clay setup is pretty dialed out the box. Only changes I made was increasing the track width and running 1.6 sway bars front and rear. Outside hole on rear up hub carriers. I went down to 1.2 in front which gave a little bit better steering. My home track has a ton of traction. So much we race on slicks now. Slipper set about 6.75mm.
I will be testing a few changes on Sunday though. Went back to standard track width, 5k in rear diff and 1.2 all around.
This car is so easy to drive it ain't funny. Extremely stable for a wheeler, at least compared to my Dex. On my DEX I was running like 75% Dual Rate, Expo was like -50 and the car still was really twitchy.
I'm pretty much running at 0 dual rate and -10 expo. Car still drove like it was a slot car. Rear was planted to track. About the only thing I was trying to correct was get slightly more on power steering in a chicane as I felt it was pushing a bit too much in that of the track.
#1195
Are you all mounting the servo directly with the 3×8 screws or are you putting a 3×7×1 washer on top? (The XRAY washers under the front ballstud are 3×6×1)
The head on the 3×8 screw doesn't have much area to bite onto the servo ear so it looks like it could mangle up the plastic. I'm just used to using washers.
#1196
Kudos to XRAY for this. They worked hard to get everyone's kits to them before Christmas, took a well earned break, and upon returning to work in the new year re-tooled and remoulded new parts to fix the issues some people have had. I have to say, I think the issues have been few and far between in the grand scheme of things, but what xray has done in a week would have taken some companies months to do. Rumor has it parts are making their way out of the factory anytime soon.
#1197
This makes me feel good to be on the X-ray team for 2013 , glad they addressed the issues
#1198
yep truly outstanding support. I am used to sending back broken parts with proof of purchase etc for defective stuff!! This is awesome.
So just to reiterate, the ball stud support is only for the rear? Is it not also for the fronts? And the shock reinforcement also only for fronts? Guess what I want is to order a spare ballstud support for the front as well once they got part # if they not supplying them....
