Like Tree39Likes
Old 01-16-2017, 11:44 AM   #11971
seth556's Avatar
Trader Rating: 42 (100%+)
You could update the chassis but you'd need a number of parts. Chassis, side pods, center bulkheads, chassis braces, steering spacers and upper plate, servo mounts, battery mount, and some hardware. Diffs and suspension should bolt on no problem.
seth556 is offline   Reply With Quote
Old 01-16-2017, 12:37 PM   #11972
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
Originally Posted by suzukipro View Post
Well my 14 TQ'd and another 14 XB4 was knocking on your door at the end of the race
That's awesome and gives me some hope. I'm not ready to give up on my '14 yet. I still have some areas where I know I can get faster. I did finish with the highest consistency percentage in our Super Stock A-main, but slow and steady doesn't get you on the podium. LOL. The A had the following finish order:
XB4 '16
XB4 '16
XB4 '16
XB4 '16
B44.3
XB4 '14 (me)
XB4 '16
Schuey K2 (broke)
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: XRay & XRay
Rodarbal is offline   Reply With Quote
Old 01-16-2017, 01:52 PM   #11973
Trader Rating: 33 (100%+)
can anyone tell me what you guys do tire wise for carpet on the front?
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 01-16-2017, 01:52 PM   #11974
XB4 '16
XB4 '16
XB4 '16
XB4 '16
B44.3
XB4 '14 (me)
XB4 '16
Schuey K2 (broke)
you did good dude.. faster each race for sure
Daniel Grobe
Sponsors:
Old 01-16-2017, 02:03 PM   #11975
Default servo horn
I'm wanting to put a 'after market" servo horn on my 2016 xb4 not sure on what to get tried exotek and it rubs on the body . Any information would be great.
Denez is offline   Reply With Quote
Old 01-16-2017, 03:49 PM   #11976
Slapjack's Avatar
Trader Rating: 19 (100%+)
I have the racers edge horn on my '16 and just ordered another for my xb2. They are the exact size as the X-ray plastic ones and the holes lines up perfect.
Leads me to a question I have about the steering setup. I ordered the exotek steering rack arm for my xb2 but I got the xray 4 hole alum one for my xb4... anyone run that?i just noticed that on the stock one there is a small section that is thicker at the end where the steering turnbuckle connects but the X-ray alum version is just a flat piece all the way across. Will I need to use some shim to get the turnbuckle at the same angle as stock or doesn't the angle of that matter? I shoulda got the exotek cause it is an exact replica of the plastic stock arm.
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 01-16-2017, 04:13 PM   #11977
suzukipro's Avatar
Trader Rating: 22 (100%+)
As mentioned above the Racers edge horn fits perfect.
https://www.amainhobbies.com/racers-...10384b/p153056
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 01-16-2017, 04:47 PM   #11978
I forgot to mention need a 25 tooth spline futaba-savox servo
Old 01-16-2017, 05:28 PM   #11979
Slapjack's Avatar
That one just posted is the one I wanted cause u can tighten it around the spline but it
Was out of stock. This is the one I got and it also fits
Perfect.
https://www.amainhobbies.com/racers-...10370bk/p37153
Old 01-16-2017, 06:31 PM   #11980
the one that suzukipro posted says it is for a hitec servo that i think is a 23 tooth spline
Old 01-16-2017, 08:09 PM   #11981
Slapjack's Avatar
That is correct. 25 tooth is for futaba savox Xpert.
Old 01-17-2017, 05:35 AM   #11982
snwchris's Avatar
Also Protek is a 25T spline
snwchris is offline   Reply With Quote
Old 01-17-2017, 05:37 AM   #11983
snwchris's Avatar
He was probably posting a link to show you the style and then you can find the one that works for 25T spline.
If you search Amain for 25T servo horn you should see quite a few choices.
or search servo horn and then on left side of screen usually to can refine the search by picking 25T
Old 01-17-2017, 07:18 AM   #11984
The problem I have is the arm is to long and it hits the body or the bell crank
Old 01-17-2017, 07:41 AM   #11985
jmcelroy42's Avatar
Use one of the inner holes, Or drill and tap a new one, and cut/grind the excess off with a dremel.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
