Like Tree36Likes
Old 11-15-2016, 06:42 AM   #11656
Originally Posted by hoyt1967 View Post
So Lyons, do you use them? I dont see many setup sheets showing the pro's use them, fronts at times but rarely the rear.
i use them in the front. as mentioned they're not worth the cost, maintenance, and hassle for the performance gain in the rear.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 11-15-2016, 07:10 AM   #11657
They are a good option for the rear if you really need to free it up maybe for more traction in super slick situations.
otherwise the fronts eliminate some of the chattter you might get at full lock steering. thats the advantage but they do wear quickly. Particularly the barrels but you can buy just those pieces as needed.
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 11-15-2016, 07:59 AM   #11658
inner barrel inserts or outer barrels?
i find if you shrink wrap them and use dry lube and replace pins frequently - wear isn't too bad
Old 11-15-2016, 02:50 PM   #11659
Boz
Trader Rating: 23 (100%+)
Originally Posted by Lonestar View Post
You mean you have not found it on the web yet?
I didn't even get my info the our Australian import, because some clown from Europe posted it first, when he probably shouldn't have.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 11-15-2016, 04:37 PM   #11660
Did someone say 2017 XB4?!
Go ahead and google : x360004
aspiringracer is offline   Reply With Quote
Old 11-15-2016, 05:45 PM   #11661
looks identical
scoobyrs25 is offline   Reply With Quote
Old 11-15-2016, 06:10 PM   #11662
timannnn6's Avatar
Trader Rating: 124 (100%+)
XB4 All-new 2017 Specs:
� Currently the best performing 1/10 4WD off-road car: World Champion, European Champion, EOS Champion and dozens of National champion titles
� Platform remains the same with almost all parts being compatible
� 2017 version was focused on fine improvement of small details making the car an absolute winner straight out of the box
� Supsension parts: arms, uprights and c-hubs are now moulded from hard material for increased stability and increased corner speed
� Independent servo mount to eliminate chassis tweak and to increase traction of the car
� New front shock tower with extra inner shock position for even more fine set-up tuning
� Graphite rear chassis brace will strenghten the rear of the car that increases stability and rotation in corners
� New 12mm alu wheel hubs instead of 14mm
� New front and rear wheels with 12mm hex instead of 14mm
� Velcro tape for dust-free mounting of body to the car
� New center upper deck with new design to improve center flex of the car
� New shorter shock springs for increased ride height adjustment range necessary especially for carpet tracks
� New Delrin shock pistons 1.6 and 1.7mm like recently included in the XB2C
timannnn6 is offline   Reply With Quote
Old 11-15-2016, 08:48 PM   #11663
suby723's Avatar
Trader Rating: 21 (100%+)
Well all I need is the new front tower and I'll have a 17 car.
suby723 is offline   Reply With Quote
Old 11-16-2016, 04:47 AM   #11664
seth556's Avatar
Trader Rating: 42 (100%+)
And upper deck, rear chassis brace, and hard plastics.
seth556 is offline   Reply With Quote
Old 11-16-2016, 06:38 AM   #11665
suby723's Avatar
The rear chassis brace and hard plastics are already option parts that I have. I believe the rear chassis brace is the carbon fiber piece but I might be wrong.
Old 11-16-2016, 07:02 AM   #11666
Trader Rating: 29 (100%+)
and factory velcro
DustinEich is offline   Reply With Quote
Old 11-16-2016, 05:00 PM   #11667
just the outter barrels. They wear pretty quickly.
Leon McIntosh
Old 11-16-2016, 08:49 PM   #11668
Bent, any chance you can confirm the post above regarding the 2017 edition? Any dates yet?
MrLean is offline   Reply With Quote
Old 11-17-2016, 01:21 PM   #11669
if anything hard plastics arent really an upgrade to me. i run medium plastics on clay and graphite on carpet - and i will continue to do so. ill still probably get the car anyway.
Old 11-17-2016, 04:10 PM   #11670
Djchow85's Avatar
funny how they've only now made 12mm hexes as standard ...
Lancer Corolla 3 Impreza
Djchow85 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
