Like Tree45Likes
Old 11-07-2016, 06:42 AM   #11626
Zerodefect's Avatar
AE oils have the CST# on the bottle. But I use PTRC oils.
Zerodefect is offline   Reply With Quote
Old 11-07-2016, 06:49 AM   #11627
Originally Posted by randy0025 View Post
here is the one I use. It is flush mounted to the chassis with the same screw that holds the side guard on. Some people use tape but I rather use this as I know its not going anywhere. it fits a 30x30 fan perfect with 2 screws
what fan mount is this? my fan comes unstuck fairly often
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 11-07-2016, 02:52 PM   #11628
I use AE shock oil and springs 35f 30r red f blackr, not the best quality but they work really good for me.
BiLL77 is offline   Reply With Quote
Old 11-08-2016, 09:38 AM   #11629
savageboy69's Avatar
Trader Rating: 88 (100%+)
results of a 4x4 sc goin the wrong way and hitting you full power
savageboy69 is offline   Reply With Quote
Old 11-08-2016, 11:51 AM   #11630
hoyt1967's Avatar
Trader Rating: 34 (100%+)
Oh boy!! Thats a bad hit. Mutter any words under your breath?
hoyt1967 is offline   Reply With Quote
Old 11-08-2016, 12:04 PM   #11631
may have been a hair above a mutter
Old 11-08-2016, 03:36 PM   #11632
Ive had this happen just not that bad, i only practice when its controlled and if its only open practice i watch for a few minutes to see who's on the track.
Old 11-08-2016, 07:00 PM   #11633
My buddy makes them, he also makes front shock protectors for people that run on carpet. It goes over the top of the front shock tower so it doesnt hit when on its lid or get stuck/grab the carpet or astro. I can link you up with him on facebook if you want. add me Randy Schroeder in michigan
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 11-09-2016, 03:23 AM   #11634
Thanks randy0025 i freinds requested you, william weeks.
Old 11-09-2016, 09:32 PM   #11635
I am brand new to Xray and just bought an XB4 2016 and am in the process of building. I need help with the rear hubs. I purchased the Xray rear aluminum hubs but not sure on the proper setup. The aluminum hubs are not as wide as the stock hubs so I'm unsure how many spacers to use and where to put them (in front of or back of the hubs). The stock setup for dirt has you put a 2mm spacer in front of the hubs however with the aluminum I need probably another 4mm or so of spacers and don't know where to put them. Also, what is the stock setting (assuming rear middle hole) and is 4mm or 5mm of spacers on top the stock setting? Thanks for your help in advance.
Team Associated - Reedy - Hobbywing - Airtronics - JConcepts
Trackside
"Put it in easy and drive it out hard!"
"I never lost it, I just ran outta room to save it...."
KahrsRacing is offline   Reply With Quote
Old 11-10-2016, 03:24 AM   #11636
Can these XB4 bearing seals be removed to clean and re oil?
Old 11-10-2016, 04:14 AM   #11637
jmcelroy42's Avatar
Yes, just pry it up from the inside with the tip of an Xacto knife.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 11-10-2016, 05:17 AM   #11638
Zerodefect's Avatar
I use grease.
Old 11-10-2016, 05:20 AM   #11639
Zerodefect's Avatar
Put it in the middle. No worries. You'll need to play with this your 1st practice day anyways. Err towards the rear.
You could just install the plastic ones, then eyeball the tie rod angle, then replicate it with the Al hub carries.
Rearward, more steering, more oversteer.
Forward, more grip, less steering and sliding.
Old 11-10-2016, 05:25 AM   #11640
Trader Rating: 50 (100%+)
Any eta on the 2017 car?
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
