Like Tree36Likes
Old 11-03-2016, 12:13 PM   #11611
BentKa's Avatar
Originally Posted by hoyt1967 View Post
It was the front acutally, I'm looking at the latest Bayer setup. I also noticed he was using a 5mm shim for the bumpsteer? I'm assuming he has to use a longer stud for that or why such a large shim.
And thanks Bent and Lyons for some of the great info on this thread! I will start dumbing up the XB2 thread pretty soon so stay tuned.
Yes you use a longer ball stud for the steering plate.
Reason for the added shims is more on-power steering.
Bent
BentKa is offline   Reply With Quote
Old 11-03-2016, 12:14 PM   #11612
BentKa's Avatar
Originally Posted by lyons238 View Post
that too hehe.
hey bent so i just ordered my medium plastics for med-high grip clay. would you recommend still using the front carbon brace and all the screws in the rear brace on bottom?
Depends entirely on the track.
But we more often than not run the front carbon stiffener and all screws on the rear bottom
Bent
Old 11-03-2016, 12:28 PM   #11613
yeah sometimes you need a longer ball stud depending but usually not.
as far as 4mm on the outer front camber link, that's typically for high grip surfaces like carpet or astro - that in affect raises the roll center - meaning the car will not roll as much in the corners - which is good for carpet so you don't traction roll. this is done by lowering the inner ball studs and raising the outer ball studs.
however if you are on clay you want a much lower roll center because you want to car to roll to get traction so yo don't slide out. this means raising the inner ball studs and lowering the outer ones.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 11-04-2016, 05:50 AM   #11614
Hey Bent, so I put on the medium plastics like we spoke about and I removed the front bulkhead brace for the steering brace instead. there's a good amount of flex on front now, have you guys ever had any problems with this? what parts are stressed/potential brakes under heavy hits? i've been crashing less lately, but my track has a very big triple and sometimes there's collisions with lap traffic.
Old 11-04-2016, 04:28 PM   #11615
Im running the same chassis brace setup on mine with the middle lower front and rear chassis screws removed and no front bulkhead brace on medium bite clay and a big double to triple center jump, i haven't had any issues with flex causing damage to anything.
BiLL77 is offline   Reply With Quote
Old 11-04-2016, 08:42 PM   #11616
TPR 1's Avatar
Trader Rating: 26 (100%+)
Hey guys
On the topic of chassis flex , i got a friend to make me a 2.3mm carbon fibre chassis to use at my local track which is a low traction outdoor clay surface.
With slightly more flex than the standard alloy chassis it will be interesting to compare them, oh yeah its also 35% lighter!
Ill let you guys know how it goes after my next club day.
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 11-05-2016, 02:36 AM   #11617
I want one, please take my money.
Old 11-05-2016, 09:01 AM   #11618
thanks man
Old 11-05-2016, 11:29 AM   #11619
How are you guys mounting your fans behind the motor? theres not much room for a fan mount or heatsink on the top or side with the body and rear shaft so close.
here is the one I use. It is flush mounted to the chassis with the same screw that holds the side guard on. Some people use tape but I rather use this as I know its not going anywhere. it fits a 30x30 fan perfect with 2 screws
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 11-05-2016, 06:04 PM   #11620
Djchow85's Avatar
I've had best experience by gluing a YR 30mm fan to some lexan which is then stuck down with double sided tape. I add a bit of extra ca glue at the points where the fan is held up on the frame of the fan.
I've used a wtf fan that broke on me within one pack.
Lancer Corolla 3 Impreza
Djchow85 is offline   Reply With Quote
Old 11-05-2016, 06:40 PM   #11621
randy 0025 where can i get that fan mount?
Old 11-06-2016, 05:46 PM   #11622
Trader Rating: 478 (100%+)
I have not been following this thread like I use to. Are there plans for an XB4 2017 anytime soon?
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 11-06-2016, 06:02 PM   #11623
tony montana's Avatar
Trader Rating: 65 (100%+)
+1. I was looking to get a 16 but everyone is out of stock
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 11-07-2016, 05:20 AM   #11624
jmcelroy42's Avatar
IIRC a few months back BentKA said that it would be released after the XT2 so I am hoping its within the next few weeks.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 11-07-2016, 05:37 AM   #11625
Anybody using associated oils? Or losi?
If so I'd like to try Bruno last eos setup.
But can't figure what wt.oils to use.
hyperdive08 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
carpetburner
