Like Tree54Likes
Old 11-02-2016, 01:49 PM   #11596
Originally Posted by snwchris View Post
Center Diff question, I've been trying to read thru and follow thru the pages when I can.
I see that the Center Diff comes with Composite Gears and Composite Cross pin, is there an option for buying metal center diff gears and pins?
I run on medium-high bite tracks if that helps out.
Also contemplating switching brands, I've been running the D413 for about 1.5 yrs
wait are you running the xb4 or the d413? the xb4 does have options for steel gears and hardened alum diff pins. google is your friend or the xray website.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 11-02-2016, 02:00 PM   #11597
snwchris's Avatar
I'm currently running the D413 for the last 1.5yrs
snwchris is offline   Reply With Quote
Old 11-02-2016, 02:10 PM   #11598
ok btw dont be afraid of the composite gears, they're no problems with them they infact have advantages in some cases and theres a graphite blend as well.
Old 11-02-2016, 02:11 PM   #11599
symmetricon's Avatar
Trader Rating: 27 (100%+)
I ran a d413 and it was good but got tired of bending screws at the hinge pin holder and how much work it was to change diff fluids. The XB4 imo outperforms the d413 in nearly every way. Way easier to maintain, more durable (have only broken 1 part in 9 months) and haven't had to replace any parts due to wear. It is also a better car out of the box, no option parts needed to be competitive. With hing pin inserts, you can infinitely adjust the car.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-02-2016, 02:20 PM   #11600
snwchris's Avatar
Yes, some of the issues, LOL
Good to hear about the Xb4 right out of the box. I would probably get the Center Diff, since I'm so used to having them.
Old 11-03-2016, 04:28 AM   #11601
How are you guys mounting your fans behind the motor? theres not much room for a fan mount or heatsink on the top or side with the body and rear shaft so close.
BiLL77 is offline   Reply With Quote
Old 11-03-2016, 04:31 AM   #11602
BentKa's Avatar
Quality servo tape
Bent
BentKa is offline   Reply With Quote
Old 11-03-2016, 05:38 AM   #11603
5tone's Avatar
Do you plug it directly to the receiver?
Or solder it to the ecs ?
What is the best way
5tone is offline   Reply With Quote
Old 11-03-2016, 06:09 AM   #11604
BentKa's Avatar
Solder it to the + & - terminals of the ESC.
Bent
Old 11-03-2016, 06:09 AM   #11605
Into the esc can give more voltage I plug mine into the rx depends how much cooling you need what voltage you're running your esc at and what is the safe voltage range for your fan...
Old 11-03-2016, 09:50 AM   #11606
hoyt1967's Avatar
Trader Rating: 35 (100%+)
So on the xray setup sheets, if it lists a 2mm shim under the camber link stud, is this 2mm plus the conical washer that is 2mm or is that meaning just the 2mm conical washer?
hoyt1967 is offline   Reply With Quote
Old 11-03-2016, 11:02 AM   #11607
which camber link front or rear and I assume you mean the outer
Old 11-03-2016, 11:02 AM   #11608
BentKa's Avatar
Shim is a shim
So any shim conical or not is added up.
Bent
Old 11-03-2016, 11:30 AM   #11609
Originally Posted by BentKa View Post
Shim is a shim
Bent
that too hehe.
hey bent so i just ordered my medium plastics for med-high grip clay. would you recommend still using the front carbon brace and all the screws in the rear brace on bottom?
Old 11-03-2016, 12:46 PM   #11610
hoyt1967's Avatar
It was the front acutally, I'm looking at the latest Bayer setup. I also noticed he was using a 5mm shim for the bumpsteer? I'm assuming he has to use a longer stud for that or why such a large shim.
And thanks Bent and Lyons for some of the great info on this thread! I will start dumbing up the XB2 thread pretty soon so stay tuned.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
