Like Tree38Likes
Old 11-02-2016, 06:48 AM   #11581
Originally Posted by Peakki View Post
if you are running center diff with thin diff grease, it will be easy to drive but front tires wear lot faster. with thin I mean 50-200k oil.
try it with 300k-1M and you will feel the difference in jumping, acceleration and more even tire wear.
I run 500k on indoor clay and I notice more front tire wear, i figure some of that is from steering but I also can feel the front end pulling my car and spinning a bit. I wonder if it would be worth running 1M or not?
BTW
i run a 5.5t with a WTF Windy as well - I can run 20 minutes and come off at 140. If I run 5-10 mins usually come off in the 130's. Without the fan the motor gets up to the 160-170 range during long practice sessions and about 150 during a 7 min main.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 11-02-2016, 07:05 AM   #11582
So, I have a 1st gen XB4, is there any way to convert it to a 16' edition or is it better to just buy a new?
Kebabkongen is offline   Reply With Quote
Old 11-02-2016, 07:18 AM   #11583
DEFINITELY BUY NEW.
If you upgrade the original you're going to replace practically every part besides a few and it will cost you $1,000 bucks and then you still have old bearings and drive pins and diff gears, etc...
even though the cars look similar, mostly everything has been updated now, the bulkheads, the chassis, the towers, the motor mount and position, the center driveshafts, etc etc...
Old 11-02-2016, 08:52 AM   #11584
JAE
Trader Rating: 26 (100%+)
Martin Bayer's new setup I saw online has the pills facing up in both front hangers and down in the rear hangers. I've always had somewhat matching roll centers with he pills. Has anyone tried this and what does it achieve? Thx all
JAE is online now   Reply With Quote
Old 11-02-2016, 08:57 AM   #11585
jmcelroy42's Avatar
Even when running the slipper, I have always noticed the front tires wearing significantly faster than the rears. Seems to be a wheeler thing, my 1:8 scale tires wear pretty evenly on the same track.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 11-02-2016, 09:03 AM   #11586
BentKa's Avatar
He still runs down in front and up in rear as we always do on EOS carpet.
We do however adjust from 1 to 3 degrees toe in the rear depending on track layout (tight to open).
Bent
BentKa is offline   Reply With Quote
Old 11-02-2016, 09:23 AM   #11587
hoyt1967's Avatar
Trader Rating: 34 (100%+)
Bent
Bent could you explain the rear toe on tight to open? I'm assuming you run less toe in on tight tracks?
hoyt1967 is offline   Reply With Quote
Old 11-02-2016, 09:42 AM   #11588
BentKa's Avatar
Less toe gives better corner speed and quicker rotation on high grip tracks like the ones using EOS carpet
Bent
Old 11-02-2016, 10:06 AM   #11589
JAE
Bent - this may be a loaded question but can you explain when you have the rear pills facing downward vs upward etc? Which conditions? I run anything from medium bite to super high bite clay. Thx very much
Bent
Old 11-02-2016, 10:36 AM   #11590
BentKa's Avatar
A very basic explanation would be;
Pills down gives more roll and traction.
Pills up gives less roll and takes away traction.
So we run them down in the front to add steering and up in the rear to free it up to add rotation.
Bent
Old 11-02-2016, 10:40 AM   #11591
JAE
^^ Perfect: thank you!
JAE
Old 11-02-2016, 11:20 AM   #11592
yup this is exactly what i do on carpet i found it to be the best on my own after testing.
on clay i go either 0 or up .5 in the front and down in the rear. this improves rear traction and reduces over steer. if you go from sliding out and over steering then bring the front back down to 0 and it should be good.
On a side note is anyone having trouble cracking the 12mm XRAY Aerodisk wheels?
My track added a new big triple and I started noticing all my front wheels cracking - I keep gluing them for now but I'm wondering if it's just bound to happen no matter what wheel or maybe if the XRAY wheels are a tad thinner or what.
Old 11-02-2016, 12:19 PM   #11593
JAE
On clay large shims on spindles on top or bottom for more aggressive steering mid turn?
JAE
Old 11-02-2016, 12:33 PM   #11594
mine are on top i believe so i don't think that's the issue. i think it's just hard landings - but im wondering if the xray wheels flex too much compared to other wheels or if it will happen regardless.
the add page says they wont crack lol and im cracking them left and right. granted it is a HUGE triple with very a slim margin for a smooth landing...
Old 11-02-2016, 12:47 PM   #11595
snwchris's Avatar
Center Diff question, I've been trying to read thru and follow thru the pages when I can.
I see that the Center Diff comes with Composite Gears and Composite Cross pin, is there an option for buying metal center diff gears and pins?
I run on medium-high bite tracks if that helps out.
Also contemplating switching brands, I've been running the D413 for about 1.5 yrs
snwchris is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
