Like Tree52Likes
Old 10-31-2016, 12:36 AM   #11551
Uga
Uga's Avatar
Originally Posted by hyperdive08 View Post
I'm new to the xray world..
I have read about rear suspension mount being incorrect, is there a revised part for this problem?
This was only on first production kits of XB4'15, all customers got a free replacement part. You shouldn't worry about it
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 10-31-2016, 12:44 AM   #11552
Uga
Uga's Avatar
Now for a rear question. New cut staggers and mini pins ,the car want to traction roll like VERY easily. Using Bruno set up from last eos.
Any tips?? Im a 2wd guy so this insane traction is different..
The track is high grip carpet track.
Few things to try:
* Harder springs
* Try getting ride height as low as possible if you don't have big jumps
* Cut the outer and inner line of pins on the rear tires
* Harder insert in the rear (AKA red inserts helps reducing traction a bit)
-=Xray XB4=-
-=Xray XB8E=-
Racing in Latvia
Old 10-31-2016, 06:49 AM   #11553
Originally Posted by mourinho View Post
good idea about the shrinkwrap. thanks
i meant to say don't put grease on the ecs until the locktite has dried and they are fully built. this way the locktite can do it's job and keep the ecs together. then shrink wrap it as i said.
good luck!
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 10-31-2016, 07:18 AM   #11554
Thank you, didn't want to look for a problem that isn't there.
hyperdive08 is offline   Reply With Quote
Old 10-31-2016, 07:21 AM   #11555
Few things to try:
* Harder springs
Was told by a team driver to ca glue the outer side wall of front tire.
Anybody hear of this?
Old 10-31-2016, 07:50 AM   #11556
I believe it was one side of the car having more toe than the other...Soemething to the effect of not being centered on chassis... Its a world champion car.......... People will find something,if you look hard enough.
Trim/Dremel the outside row or two of pins off the rear, cut/Dremel the outside row off the front tyres, I was running my YZ-4 like that on high grip astro yesterday.
Or depending on the grip & your style, maybe even run 2wd cut staggers & trim the wheels down.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 10-31-2016, 09:53 AM   #11557
BentKa's Avatar
For carpet when running the Schumacher Wide Stagger and Mini Pin combo we use CA glue and accelerator on the outside sidewall in the front and cut one row of pins off on the outside and inside of the rear tires.
No need to cut anything on the front tires.
+ YouTube Video
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 10-31-2016, 05:41 PM   #11558
Bent,
Thank you SO MUCH!!! Worked amazing!!! You do that with 2wd?
Your take on 12 degree of caster ??
Old 10-31-2016, 08:11 PM   #11559
BentKa's Avatar
Bent,
No, only the cut on the rear tires.
She's running 9 degree caster hubs and steering knuckles in graphite.
Bent
Old 10-31-2016, 08:26 PM   #11560
Bent
Bent,
One last question...
Rear carbon stiffer a noticeable change for high traction carpet with the 2016 xb4?
Old 10-31-2016, 08:53 PM   #11561
Bent,
yes
Old 11-01-2016, 12:54 AM   #11562
BentKa's Avatar
Bent,
For high traction surfaces like the EOS carpet we run the carbon stiffener with only the forward screw and the 2 rear screws for the bulkhead on top.
On bottom we run all flex screws.
Bent
Old 11-01-2016, 01:29 AM   #11563
JsK
JsK's Avatar
Did you mount them yourself or are they premounts? What inserts?
Also if you take a close look at the pics of Marlins there are 2 angled rows out or 3 depending on what way you mount them. If you have the 3 rows out it will make the front bite almost uncontrollable.
JsK is offline   Reply With Quote
Old 11-01-2016, 04:22 AM   #11564
I did mount myself. I didn't notice that at all on my tires, but makes sense!! I'll take a look at that this evening.
Old 11-01-2016, 07:06 AM   #11565
Bent
Bent, how bout for med-high grip indoor clay (slicks and electrons tire of choice - almost cement like).
What screws would you recommend removing for the hard rear center chassis brace?
Right now I just have the 1 screw in front of the 2 bulkhead screws, but I was thinking of taking the one in front of that out as well...thoughts?
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
