Like Tree36Likes
Old 10-19-2016, 05:54 AM   #11491
Originally Posted by mustangkillaz View Post
US distributor says stock should be on hand very soon. I'm waiting myself. Looks like I'm getting 2 in the family. A 2wd and 4wd.
Still researching motors and esc units to buy. Any advice?
hobbywing xr10 pro with the v10 motor combo is excellent. i came from a Tekin RSX and gen 3 combo before that - so it's not like i dont have perspective. the hobbywing is so smooth and fast it's unbelievable.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 10-19-2016, 05:55 AM   #11492
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Originally Posted by suzukipro View Post
Curious to see how often others with the ECS shafts do maintenance on them. I've been cleaning and re greasing mine every other race outing and they still seem to wear extremely fast. I'm running on a low to med traction dirt indoor track so this type of wear seems excessive in my opinion.
I will likely go back to the regular shafts unless I am missing something on how to reduce the wear on these parts. The replacement pins and drive cases are wearing out too soon for me to continue replacing them.
Originally Posted by lyons238 View Post
try a dry lube, graphite grease turns into a dirt polish and wears things fast.
Onroad guys put heatshrink over the joint to prevent carpet fibers and other debris from getting into the joint... has anyone tried this?
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 10-19-2016, 06:00 AM   #11493
yes not to keep dirt or debris out but to keep the pins in, the shielding is an added benefit.
so yes run shrink rap over the joint (be sure to make the shrink rap go over the barrel a bit so when you shrink it it locks on. and also use dry lube in combination. i clean mine out maybe once every 4-5 days at the track (on clay - way less on carpet) and they could go longer but they get a tiny bit gritty.
Old 10-19-2016, 06:00 AM   #11494
Zerodefect's Avatar
A balloon maybe?
Zerodefect is offline   Reply With Quote
Old 10-19-2016, 06:07 AM   #11495
does anyone know if it's cool to run more front droop than rear droop for increased rear traction? will the differing droop levels mess with jump landings or anything of that nature? i was thinking of running 0-1mm limiters in the front and 1-2mm in the rear. thoughts? bent?
Old 10-19-2016, 06:10 AM   #11496
Anyone have a good setup for cqrpet/astro? Picked up a car from antti silvennoinen, run on dirt looks like. No ides whats in the shocks or diffs, but looking at a decent setup for carpet astro-cambers, ride heights, springs etc.
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 10-19-2016, 06:12 AM   #11497
there's a bunch check the xray forums or google bruno xb4 setup
Old 10-19-2016, 09:12 AM   #11498
I figured his setup is just carpet. Hard to tell with astro also involved
JDC Motorsports
Old 10-19-2016, 09:13 AM   #11499
Trader Rating: 33 (100%+)
the added weight transfer will help for rear traction.. and you shouldnt lose any performance on the jump landing.. if your having bottoming issues landing.. or slapping.. the added droop might help.
i am currently running 1mm in both front and rear..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 10-19-2016, 09:39 AM   #11500
mustangkillaz's Avatar
I keep hearing about hobbywing. Noted!
Next concern is, do I grab a carpet or dirt edition for hard packed clay with good traction.
mustangkillaz is offline   Reply With Quote
Old 10-19-2016, 10:04 AM   #11501
id say get the carpet and you can tune for clay, also if worst comes to worst you could buy the DE tranny and throw it in once it's released, but at least youll have the carbon towers and what not, i don't think the plastic towers are needed on med-high bite clay.
Old 10-19-2016, 11:40 AM   #11502
My most preferred for setup search is: http://petitrc.com/setup/xray/SetupSheetsXrayXB4.html
They have plenty of astro setups listed there.
In my opinion petitrc site provides easier navigation through setup list compared to xray site as setups are already arranged in order depending on track surface.
JanisK is offline   Reply With Quote
Old 10-19-2016, 12:31 PM   #11503
thank's daniel, should i run 0mm or 1mm? med-high bite clay (slicks) but there's a huge 40ft triple that i sometimes bottom off the huge take off and landing.
Old 10-19-2016, 01:19 PM   #11504
BentKa's Avatar
Originally Posted by MrLean View Post
Car (and driver) looks dialed!
Which setup of hers is she using?
Are all the parts on that car currently available to the public (see what I did there?)
She's using a setup close to her EOS round #1 2016/2017 setup.
And yes all parts on the car in the video are available to the public
Bent
BentKa is offline   Reply With Quote
Old 10-19-2016, 05:28 PM   #11505
knocustom's Avatar
Oh i know that triple i broke my 22-4 there twice and i sold it ill stay with xray sense it handles the crashes better lol
knocustom is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
