Like Tree39Likes
Old 09-24-2016, 05:24 AM   #11386
simmyjellers's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Joonatin View Post
Seems like I'll have to try dremeling next. A better 1,5mm didn't work after which I sanded down a 1/16" for a reeeally tight fit but even that slipped in the end. Just have to be careful with the dremel so I don't cut into the plastic too much.
i have gone straight to dremeling screws i can't get out recently. i tried so many other things, ez outs, etc... after a bunch of trial and error, the dremeling has become my first attempt...after the hex drivers of course. good luck!
simmyjellers is offline   Reply With Quote
Old 09-24-2016, 08:03 AM   #11387
Simmy Jellars are you going to the Mimi's in gaithersburg on the 8th for the fall opening race?
BiLL77 is offline   Reply With Quote
Old 09-25-2016, 06:52 AM   #11388
bill77 - i doubt it as of now. gaithersburg is a bit far for me. i have been to mimi's once, and loved it. but that 1 time is my only experience on clay. i will almost definitely be there sometime throughout the winter.
Old 09-26-2016, 01:07 AM   #11389
Originally Posted by bd581 View Post
The 75T spur will work, best if you have a high rpm motor.
Best alternative is to get a '15 spec slipper setup (2 pad) and drill out an Associated 69T spur to fit. Opens up your gearing choices. With a 75T spur, you can only fit up to a 33T pinion.
For anyone's interest regarding 17.5 in a 4WD buggy. At the recent New South Wales, Australian state titles, the fastest 17.5 drivers race times would have made A main in modified.
thanks mate . car arrived today . now to build it and keep it hidden thill xmas ...
Major Financial Sponsor of https://www.facebook.com/AdenYoungRc/
XRAY , HEI , PROLINE , MUCHMORE
TQ & 3rd 2016 Victorian State Titles Junior Stock 2wd
XRAY XB2 , XRAY XB4 2016 & XRAY T4 2016
aussie372 is offline   Reply With Quote
Old 09-26-2016, 03:48 PM   #11390
Can someone tell me what parts I need to install the center diff in 2016 xb4. The one on Amain says that it is only for the 2015 xb4 o im slightly confused. I run on clay and carpet.
Is it worth putting in?
Jzenka is offline   Reply With Quote
Old 09-26-2016, 03:54 PM   #11391
Drops right in a 2016. Just get an assortment of diff oils. I started with 300K.
Tony Vega is offline   Reply With Quote
Old 09-26-2016, 04:18 PM   #11392
Woulvesbaine's Avatar
So picked up one of these to try and even with a "carpet setup" it felt already pretty driveable on clay (medium grip: OCRC).
I'd like to try it with the center slipper that it came with for a while. It came with 7k front and rear. I've seen setups for OCRC with 8k front and rear.
Assuming I can readily find 8k oil (and given the different brands, who knows what the difference is), what will the difference be going from 7k to 8k?
Also what lubricant do people put on the metal gears from the gear diffs to the drive shaft gears?
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 09-27-2016, 05:44 AM   #11393
symmetricon's Avatar
Trader Rating: 27 (100%+)
From 7 to 8k is probably not gonna be noticeable, but should calm down the car if it feels a bit edgy. The xray cars come supplied with some hudy graphite grease that works very well, I'd recommend using it but normal black grease will do...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 09-27-2016, 05:44 PM   #11394
what's a good starting oil weight and spring to start with when running 1.6 front and 1.7 pistons in the rear I use pt oil
billsharp34 is offline   Reply With Quote
Old 09-27-2016, 05:50 PM   #11395
Djchow85's Avatar
Need more info of your track
indoor/outdoor?
smooth/bumpy?
I run a low/med outdoor bumpy clay track.
Currently stock springs, 32.5 all around (only doing this as the previous guy did this).
On a previous 4wd buggy on high traction carpet I was running 60/50wt on the hardest springs for that brand. Hope this helps.
Lancer Corolla 3 Impreza
Djchow85 is offline   Reply With Quote
Old 09-27-2016, 06:04 PM   #11396
indoor/outdoor?
smooth/bumpy?
Indoor smooth low traction
Old 09-27-2016, 08:23 PM   #11397
Phillip F's Avatar
Trader Rating: 15 (100%+)
Anybody when the 2017 XB4 is coming out?
Phillip F is online now   Reply With Quote
Old 09-27-2016, 10:36 PM   #11398
BentKa's Avatar
After the T4, XT2 and XB2 CE
Bent
BentKa is offline   Reply With Quote
Old 09-27-2016, 11:15 PM   #11399
Phillip F's Avatar
Bent
I googled 2017 XB2 CE ... and I read the new XB2 CE expectation release date is 10/10
http://www.insidelinemodels.com/insi...rpet-edition-p
... so safe to say the new XB4 is coming out this November then.
Old 09-28-2016, 01:19 AM   #11400
BentKa's Avatar
Most of them are already shipping to distributors soooooo……..
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
