Like Tree39Likes
Old 08-14-2016, 07:52 PM   #11221
Originally Posted by randy0025 View Post
1k or 10k in the rear, I have never ran anything under 3k in the rear on a normal bases. I think I tried 2k once but never again. I would love to know what the rest of your oils are if your running 1k in the rear. I am normally at 7k,200k,5k or 5k,300k,3k with sometime going up to 500k in the center diff.
I love the 1k in the rear really helped the handling in mine. I'm running 10k front 80k center
4s losi is offline   Reply With Quote
Old 08-14-2016, 09:45 PM   #11222
Pville Stig's Avatar
Default Setup
Originally Posted by lyons238 View Post
i run 10k 500k 10k
think of going 8k in the rear
also i run the steel diff gears
on med-high bite clay (primes or electrons)
I would highly suggest Ethan Lefebvre's setup for Thornhill jr or for med to high bite clay. 7k 500k 3k in the rear. Avid Pistons and springs. I would also suggest dirt webs to add aggressiveness to driving and to avoid traction roll. The flatter the profile of the tire the better off you will be.
RC America/XRAY
LRP America
AKA Products
Pville Stig is offline   Reply With Quote
Old 08-14-2016, 10:05 PM   #11223
JAE
Trader Rating: 28 (100%+)
I've never been able to find this setup. Googled, typed name at X-ray site... Nothing. Would you happen to have a link? Looking to build on my setup. Using Randy's as baseline since worked so well.
JAE is offline   Reply With Quote
Old 08-14-2016, 10:58 PM   #11224
Woulvesbaine's Avatar
JAE, here, assuming it's the '015. Couldn't find one for the 016: http://forum.teamxray.com/xform/inde...setup=xb4_2015
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 08-14-2016, 11:19 PM   #11225
JAE
Thx! That's 5 degrees toe in. I'm at 3. I may try the shocks on the rear but don't know if this will mess things up for me when running at a hi bite track close by. I'm hoping it doesn't require any additional parts to mount the shocks on the rear
Old 08-15-2016, 07:03 AM   #11226
Trader Rating: 41 (100%+)
When moving the shocks to the rear, do you move the entire tower to the back side if the diff case boss or just move the shocks to the back side of the tower and arms? Does anyone happen to have a picture of theirs set up with the shocks moved to the back?
rccars4scott is offline   Reply With Quote
Old 08-15-2016, 09:58 AM   #11227
Default Setup
Yes, that's the correct one. Sorry i keep forgetting its an older setup but it still works great for most people on high bite tracks.
There aren't any additional parts needed to change the shock positions. Everything needed for it was in the kit. I think the only things that you will need to change is the block on the shock tower.
RC America/XRAY
LRP America
AKA Products
Old 08-15-2016, 12:03 PM   #11228
JAE
Thanks! My high bite track is on a whole 'nother' level for clay. A lot of people talk about high bite but here is an understatement. Sometimes take traction away and adjust roll centers to avoid traction rolling. In any event, if I'm running 13.5, is there any benefit in medium bite or hi bite in running the center gear diff? thx
JAE
Old 08-15-2016, 12:17 PM   #11229
thanks I might try that out but my setup has been working quite well. but i may implement some things.
Why the avid springs over xray springs? doesn't seem they offer that many more useful options. i've been happy with 2 dot and 3 dot on clay and 4 dot and 3 dot on astro...
also as far as the diffs, these cars seem to want to have more balance to them with thicker and more even oils like 10 5 10 or 10 5 8r...at least in my experience and Bentka's...
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 08-15-2016, 12:59 PM   #11230
Yeah your right. If the oils are to far apart you will notice with the xb4 as you punch it to give it power it will rock back and forth. Also like a loose rear end effect where the front end will turn left and then right and then go straight. I am always 2k way front to rear, so 7k front,5k rear, or 5k front and 3k rear. for me that seems to me best.
As for running 1k in the rear, I bet it makes the car super easy to drive but its dogsh1t low like that. if you went up it might be alittle more of a handful but i promise you will turn faster lap time.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 08-15-2016, 01:05 PM   #11231
yeah thats exactly my experience. except i use 10k front 500k center 10k rear. i might go down to 8k rear, but that's probably about it.
the car seems to handle pretty good even with 10k and 10k, especially when i take it on carpet and dont want to switch fluids.
Old 08-15-2016, 01:46 PM   #11232
JAE, do you have Mike's (from OCRC) setup? His cars look pretty dialed in.
And Orange.
Old 08-15-2016, 03:36 PM   #11233
JAE
I don't. I've only seen him drive an xb4 1 time. Regarding the 4dot 3dot or 3dot2dot setup, those both worked for me on high bite running slicks. On medium bite, I was way better off with softer springs and the higher oil with alittle rebound. No more chassis slapping. I chassis slapped more with 4 dot front 3 dot rear. Must be the rebound
JAE
Old 08-15-2016, 04:18 PM   #11234
Default setup
The Avid springs feel more consistent, easier to drive.
RC America/XRAY
LRP America
AKA Products
Old 08-15-2016, 04:23 PM   #11235
Default setup
The gear diff makes it easier to drive the car more aggressively and helps if traction starts to go away. I also run 13.5 exclusively at our track and our lap times are only just slightly slower than the guys who run Mod.
RC America/XRAY
LRP America
AKA Products
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
