Like Tree52Likes
Old 07-15-2016, 07:46 PM   #11176
Pville Stig's Avatar
Originally Posted by randy0025 View Post
I only see a xb4 15spec for Ethan Lefebvre on xrays site. are you running that setup on your 16 spec or is there one on a different site because like i said there isnt a xb4 16 spec for Ethan Lefebvre at thornhill that I could find
Yes, i am running his 15 setup on my 16.
RC America/XRAY
LRP America
AKA Products
Pville Stig is offline   Reply With Quote
Old 07-15-2016, 11:37 PM   #11177
me too.
scoobyrs25 is offline   Reply With Quote
Old 07-16-2016, 12:47 AM   #11178
JAE
Trader Rating: 28 (100%+)
Can someone paste a link. I cannot for the life of me find this setup. Tried the search feature on Xray site to no avail. Thx much all
JAE is offline   Reply With Quote
Old 07-16-2016, 11:35 AM   #11179
Yeah I had a issue finding it. for some reason its not on the xb4 16 page. try looking on the xb4 15spec. Or you can go to the search link on the xray like I did and just type in his first name. you will seee his xb2, xb4 and his xb8 setups.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 07-16-2016, 11:49 AM   #11180
Default his setup
here is the setup
Also if you can get or dont have the avid springs you can use AE blue front and AE black in the rear as those are super close to the avid purple and white
Old 07-16-2016, 12:12 PM   #11181
JAE
Thx! Interesting spring rates. Closest in X-ray would be 2 dot for front. Spring rate is higher than 3 dot rear, perhaps 4 dot rear. I have all these X-ray springs. A little irritating their incremental jumps in spring rate are so drastic so have to get other springs/cups for the tweener rates. Maybe I'll get some yokomo sets....
That's a pretty heavy weight oil. Then again I'm new to 4wd. This normal for the xb4 and other 4wd buggies on clay?
here is the setup
Old 07-16-2016, 12:24 PM   #11182
blwaz23's Avatar
http://www.spec-r.com/default/index....roducts_id=557
How good of quality are these compared to the xray ones?
Also does anyone know where to buy the Differential Bevel & Satellite Gears (2+4) Part:335030 and the Diff Pins Part:335080
blwaz23 is offline   Reply With Quote
Old 07-16-2016, 06:58 PM   #11183
damang999's Avatar
Trader Rating: 15 (100%+)
Originally Posted by lyons238 View Post
how do i get more slip outa my slipper yo?
seriously lol xb4 set to 0mm with std pads, barely ever slips. basically non existent with a 5.5t motor and 18/81 gearing i believe it is.
my "15" was the same. slipper backed right off and no slip at all on carpet.it would do wheelies when punched hard.. i run loose outdoors and it was giving me all types of grief.
turns out it had #364181 c=45 slipper spring as per manual . i orderd #364180 c=30 . the new spring is much smaller and softer. im able to set the slipper to suit the conditions much better now
damang999 is offline   Reply With Quote
Old 07-17-2016, 09:36 AM   #11184
I would think it would really be 1 dont front because the 2 dot is 4.11lbs and the setup I posted calls for 3.63lbs. As for the rear the xray 3dot springs are 2.57lbs and the setup I post calls for 1.84lbs. So like I posted if you want to run the setup posted above or close to it you need to run either the avid purple front and white rears or run the AE Blue front and black rears which are super close to the listed above rate.
Old 07-17-2016, 09:37 AM   #11185
also you can run the avid springs or the AE springs on the xb4, just a heads up
Old 07-17-2016, 09:50 AM   #11186
suby723's Avatar
Trader Rating: 21 (100%+)
I run yatabe springs on carpet and ae springs on dirt. Xray springs are junk IMO.
suby723 is offline   Reply With Quote
Old 07-17-2016, 10:57 AM   #11187
JAE
http://site.petitrc.com/reglages/BuggyBigBoreSpring.pdf
Must have had my spring rates way off. Going by this chart thinking Xray 2dot front is 3.71 and 1 rear is 2.0...to just experiment with what is on hand. I'll try that weight oil too.
Btw - does using the 21mm new extended rod ends help with the chassis slap? Going to Ty on my xb2 today. Could barely use them as the dog bone plunge has the bones almost coming out of the diff
Old 07-17-2016, 12:29 PM   #11188
Are there any 14mm alternatives to the 12mm 2 and 3 stripe wide hexes? Have a load of 14mm wheels that Id like to hang on to.
Glarke is offline   Reply With Quote
Old 07-17-2016, 02:35 PM   #11189
GregerL's Avatar
The +0,75 14mm hex will give you same track width as two stripe 12mm hex if you are comparing with Xray rims.
I don't believe there is a +1,5 mm hex in 14mm, but that would give you same width as a three stripe.....
/Greger
Alexander Landén RC on facebook:
https://www.facebook.com/alexanderlandenRC
GregerL is offline   Reply With Quote
Old 07-17-2016, 03:06 PM   #11190
thank you for that info!
does anyone know if theres any type of springs that fit on the xray xb4 without changing spring perches or having to mod anything? how about the kyosho springs? i spent a good amount of money on getting all the xray springs. sucks theyre not ideal :/
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Caradha
