Like Tree37Likes
Old 07-04-2016, 06:37 PM   #11131
Pville Stig's Avatar
Originally Posted by Emmett751 View Post
Need some help with getting a base line gearing for my new XB4, running a 6.5 on carpet. I've tried multiple different combinations but the darn thing still get screaming hot FAST! Last combo i tried was 18/84, and after 2 minutes the motor was around 185. I've tried going down in pinion, going up in spur, up in pinion... Seems the popular 18/81 is just too tall for this track, as were some other combos i tried, so far the best feeling was 16/84 but even that was getting super hot... Im kind of at a loss with what to do and where to go with it.
Track: Small, tight very high grip. 10-11 second lap times.
Temp: Southern Alabama so right now were looking at 100+ ambient temps.
Electronics: SMC 160A, SMC 6.5 (did have RSX and Gen 3 6.5 but epic meltdown happened)
Kit: Brand new, super free drive train nothing binding, gear mesh properly set. Fan on ESC, Fan on motor. Schumacher minipins/cut staggers
Can you run a fan and go down on spur gear size?
RC America/XRAY
LRP America
AKA Products
Pville Stig is offline   Reply With Quote
Old 07-04-2016, 09:33 PM   #11132
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
Emmett, what's your timing on your motor? Any boost added in the ESC?
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: Losi & XRay
Rodarbal is offline   Reply With Quote
Old 07-05-2016, 04:12 AM   #11133
Suspended
Timing on the motor is set to 20 I believe, and I run the ESC in blinky.
Emmett751 is offline   Reply With Quote
Old 07-05-2016, 11:02 AM   #11134
i am just about finished building my xb4. i find that the servo horn slightly rubs against the body when turning the wheels. has anyone else seen this or have i messed something up
rekim is offline   Reply With Quote
Old 07-05-2016, 11:06 AM   #11135
suby723's Avatar
Trader Rating: 21 (100%+)
That is normal. Mine also rubs slightly but it doesn't affect anything. I used a little chassis protector in the area to protect the paint.
suby723 is offline   Reply With Quote
Old 07-05-2016, 12:55 PM   #11136
OK thanks
Old 07-05-2016, 01:18 PM   #11137
depending on which servo horn you use you may need to cut a hole in the body. I use the 3 hole hudy servo horn and had to cut a hole and dremel an aesthetically pleasing shape for the servo horn to move in.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 07-05-2016, 01:56 PM   #11138
bd581's Avatar
I just ground down the Hudy servo horn, basically removed the outer hole.
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 07-05-2016, 02:03 PM   #11139
You can do that as well but at the time I had to cut a hole in the body with a body reamer because I was at the track and did not have a dremel to grind it down at that moment. Either method works. Kind of lame that you have to do that but not a deal breaker, that's for sure...just use some sharpy on the ground down servo horn tip
Any pics of yours? I wanna see how it came out...and did you use a cutting wheel or a grinding stone?
Old 07-05-2016, 04:46 PM   #11140
i finished building now and it is really tight fit for the wires when trying to put the body on. i had to tie down every wire because they were hitting the body and it wasnt sitting flush. i did eventually get it. i put a 13.5 motor in it and it feels a bit slow to me.
overall though i love the buggy. it seems to handle pretty well. a little better than my xb2 but i have my xb2 pretty dialed for my driving style.
hopefully it doesnt rain tomorrow and i get to drive it. it was so late by the time i finished building it that i only got to drive for 10 minutes or so.
1 addtional thing i wanted to ask. i hit the throttle with all 4 wheels in the air and one wheel moved up and down. it drives fine when its on the ground, just when the arms are fully extended down, did it do this
Old 07-05-2016, 06:32 PM   #11141
suzukipro's Avatar
If you are running a slipper make sure it isn't too loose, I had the same issue and gearing changes didn't make a difference until I tightened it. Be carefull not to go too tight though or you'll start breaking expensive items...
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 07-05-2016, 06:53 PM   #11142
Check to make sure the out drive on the wheel that shake has the small pin in the right hole. When I built mine I put the pin in the larger hole on part number 365230 and the wheel shook a lot
G Wood
Gorden
light is offline   Reply With Quote
Old 07-06-2016, 05:53 AM   #11143
really? my slipper is set to 0mm (all the way loose) and I NEVER hear it slip with a 5.5t motor on carpet and clay...
taking the slipper apart shows very very minimal and light scuffing. it's noticeably barely ever slipping. and since i never hear it im sure it only slips for a split second.
Old 07-06-2016, 08:38 AM   #11144
symmetricon's Avatar
Trader Rating: 27 (100%+)
Yeah, mine is at 0mm also. I run on high bite clay and my car will pop wheelies.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is online now   Reply With Quote
Old 07-06-2016, 10:32 AM   #11145
yeah that has been my experience as well. i've never seen an XB4 that could have a loose slipper. it would be nice if we had a little more adjust ability considering even 0mm seems too tight...
i have the mckune pads, do you think those would allow for more slip or less? i have yet to try them...
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
