Like Tree52Likes
Old 06-23-2016, 12:58 PM   #11101
Pville Stig's Avatar
Originally Posted by HollywoodRC View Post
Thanks Lance. I looked at the X-Ray setup site but did not see Ethan's name. Do you have another link?
I can show you at the track on Saturday. I had a hard time finding it as well. I also have it printed out that i can give you.
RC America/XRAY
LRP America
AKA Products
Pville Stig is offline   Reply With Quote
Old 06-23-2016, 05:46 PM   #11102
HollywoodRC's Avatar
Awesome. Also, two of many, questions. What pinion for 13.5T SS class at Thornhill and are the hubs really 14mm? I hated that Losi front wheels were different, and you were forced to use them, I always was a fan of DE Racing wheels for all the different colors.
HollywoodRC is offline   Reply With Quote
Old 06-24-2016, 12:10 PM   #11103
suzukipro's Avatar
Trader Rating: 23 (100%+)
Originally Posted by suzukipro View Post
Any idea on the difference in length between these and the Xray shock ends? from a cost perspective these are certainly worth a try
I picked up a set of the Mugen shock ends and they are 22.5mm long and seem to be ok, but the ball ends have a tad more slop than the stock Xray shock ends.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 06-24-2016, 05:45 PM   #11104
I think i'm running 18/81 and i'll going to up on pinion 20 and lower on spur 78.
I would definitely go to the 12mm Hexes from exotek. Hooligan has them in stock.
RC America/XRAY
LRP America
AKA Products
Old 06-24-2016, 07:03 PM   #11105
Sweet! I'll hit Jerry up tomorrow! Thanks
Old 06-24-2016, 11:27 PM   #11106
Trader Rating: 42 (100%+)
Looking for a little set up help. I run my xb4 2016 on a loose outdoor track...actually a fairly tame 1/8th scale track. I am in the process of switching to the medium side guards, medium front and rear chassis braces and moving the motor/center diff to the rearward position. I have been running 2 dot spring but am switching to one dot per recommendations here.
My question is what are good front and rear shock oils and what diff fluids would be a good start (I am running a center gear diff)?
Thanks everyone.
rccars4scott is offline   Reply With Quote
Old 06-25-2016, 12:07 AM   #11107
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
C'mon Lance! I don't believe 18/81 with that 13.5T. LOL. I'm running 28/78, but I might drop down a tooth or two on the pinion.
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: XRay & XRay
Rodarbal is offline   Reply With Quote
Old 06-25-2016, 03:37 PM   #11108
Maybe i need to take another look. i know the spur is 81 about to be 78.....
RC America/XRAY
LRP America
AKA Products
Old 06-25-2016, 11:43 PM   #11109
Anyone able to help?
Thanks everyone.
Old 06-26-2016, 01:43 AM   #11110
GregerL's Avatar
You can try this setup: http://forum.teamxray.com/xform/inde...setup=xb4_2016
You could probably go down on center diff fluid to 500K compared to this one.
/Greger
GregerL is offline   Reply With Quote
Old 06-26-2016, 12:52 PM   #11111
Grab the Avid 2+2 pistons. 1.5x1.1 front with 35-37.5wt and 1.6x1.1 30-32.5wt
As for the diff oils you can do 7k front, 200k center and 5k rear or make the car super easy to drive by doing 5k front, 100k center and 3k rear.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 06-29-2016, 12:12 AM   #11112
Well I have decided to run a FDR of 7.79 with an 81/26 for 13.5T SS 4WD buggy. What are you guys running? I'm kinda in the dark here! I have a Tekin Gen 3 high torque motor with Tekin Gen 2 ESC. My 17.5T 2WD buggy I'm running 50deg of timing and it's stupid fast and not coming off hot. What timing are you guys running in 13.5T SS?
Old 06-29-2016, 10:29 AM   #11113
26/81 should be good for Thornhill. I do run a motor fan. No timing.
RC America/XRAY
LRP America
AKA Products
Old 06-29-2016, 05:41 PM   #11114
I am really torn between what i want to get next. I am looking at the xb4 2016, dex410v5 or a 2wd buggy. For now, my question below
Has anyone driven both the xb4 2016 and the dex410v5? if you have, which would you consider to be nicer kit and better value? They are basically the same price, and i dont have a local hobby shop or a local track so parts availability is not a concern and i dont have the ability to drive other cars other than what i own myself.
rekim is offline   Reply With Quote
Old 06-29-2016, 08:19 PM   #11115
durango stuff is killer. but i prever the xray stuff. the xray is an excellent performing buggy with tons of tuning options and its durable. they both could perform well and be durable.
the reason i would choose an XB4 is because with the XRAY you can change each diff in 4 screws each, along with many other things. the buggy was designed with maintenance in mind. this saves so much time and headache. and to have such a top notch buggy in all other aspects also be the quickest and best buggy to maintain, its a no brainer. get the XRAY you wont be dissapointed.
i would also get the xb4 over the xb2 (i have both). simpy because a 4wd buggy is so versatile and fast, if i had to choose one it would def be the 4 wheel. get the 2wd if you need to save money though. 4wd costs more up front and more to maintain. but again if you only have one buggy it could be fun to maintain just one 4wd. also with the xray you dont need many if any upgrades.
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
