Like Tree38Likes
Old 05-22-2016, 07:20 AM   #11041
Originally Posted by 13Maschine View Post
has anyone tried the Yokomo Yatabe Arena Turf/Carpet Springs on the Xray? Do I need different cups? Yokomo or AE cups?
stock cups are fine with the yok springs.
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 05-22-2016, 09:58 AM   #11042
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
@punkracer24: THanks! Can you make some suggestions on which rate Yatabe springs I should pick up for Carpet? Green or ?
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 05-22-2016, 10:00 AM   #11043
13Maschine's Avatar
@zerodefect: why alum cups when stiffer? Lower CG? Seems like that might be more unsprung weight?
Old 05-22-2016, 11:29 AM   #11044
suby723's Avatar
Trader Rating: 21 (100%+)
Purple or black fronts and green rear. Your also going to need to go lower cst on the oils. 550cst front and 350cst rear is pretty good.
suby723 is offline   Reply With Quote
Old 05-22-2016, 03:12 PM   #11045
13Maschine's Avatar
I think stock on the CE is 500CST in the front and 350CST in the rear. 550 CST would be heavier. Is that what you meant?
Old 05-23-2016, 03:47 AM   #11046
is the shock oil from hudy a big difference between say losi or associated
bassbusta01 is offline   Reply With Quote
Old 05-23-2016, 03:59 AM   #11047
Zerodefect's Avatar
In hard hits the plastic cups can spread apart and pop off or wiggle crooked.
Not usually a problem with Xrays, always a problem with Losis's.
Zerodefect is offline   Reply With Quote
Old 05-23-2016, 05:35 PM   #11048
blwaz23's Avatar
I have not noticed a difference except in price.
blwaz23 is offline   Reply With Quote
Old 05-23-2016, 05:48 PM   #11049
advpball's Avatar
Trader Rating: 27 (100%+)
Anyone convert xb2 to a oval car just wondering if someone makes a kit for it ?
tekno sct-410.3,xray xb2 de and xsc2?
eb 48.3 for sale artr 600
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 05-24-2016, 03:01 PM   #11050
advpball's Avatar
Sorry wrong thread..
Old 05-25-2016, 11:06 AM   #11051
JAE
Trader Rating: 26 (100%+)
I've read here people are using the 12 degree castor hubs to calm the steering down. What other benefits do they provide?
JAE
JAE is online now   Reply With Quote
Old 05-25-2016, 11:09 AM   #11052
symmetricon's Avatar
More overall on power steering and stability in the sweepers... I still prefer the stock setup personally.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 05-25-2016, 11:21 AM   #11053
more overall on power steering??? I have a set and if anything it takes steering away on power and off. So i dont understand how it gives more on power steering, maybe for other cars which i dont know but ill tell you this the 12 degree hubs didnt help my car get more steering, if anything it smooths it out and takes away steering. If I am wrong and others havent had the same experience as me please let me know as I would love to know how to get more on power steering while smoothing the car out with the 12 degree hubs. I myself had to remove them and go back to the 9 degree ones
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 05-25-2016, 11:22 AM   #11054
JAE
Does it inhibit the tight turning radius with 180's on the track?
Old 05-25-2016, 11:39 AM   #11055
http://site.petitrc.com/setup/HowToSuspensionSetup/
There are plenty more articles that explains how caster affects on power steering.
From the hudy offroad setup manual.
"Camber is all about contact patch – keeping as much tire on the ground as possible.
Camber and caster are related in that caster can afford an amount of EFFECTIVE CAMBER
change when the front wheels are turned in a corner.
Caster has the effect of progressively leaning the front tires into the direction of the
corner. The more the caster angle is laid-back, the greater the effective camber change
when the wheels are turned. This happens because the tops of the wheels BOTH TILT
towards the inside of the corner; the wheels “dig in” more, counteracting the centrifugal
forces pushing the car to the outside."
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
