Like Tree39Likes
Old 05-18-2016, 10:09 AM   #11026
JAE
Trader Rating: 28 (100%+)
Cool - Trying to get 2 sticker sheets. I'm finding $40-$50 is the going rate. Stickers are expensive!!! ?
JAE
JAE is online now   Reply With Quote
Old 05-18-2016, 02:16 PM   #11027
advpball's Avatar
Trader Rating: 27 (100%+)
92zero designs
xray xb2 de and xsc2,eb410
eb 48.3 for sale artr 500
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 05-18-2016, 02:23 PM   #11028
Originally Posted by grifind View Post
Astro came here to stay!
Our private track in Katerini - Greece
Opinions on set ups?
In general high roll center works well.
+ YouTube Video
What tyres are you on , here in uk we use either Schumacher yellow mini spike rear,medium insert,front either 2 wd spike tyres stretched on 4wd front or the 4wd stagger cut...wet tyres are ballistic buggy spike greens medium insert
Quietman is offline   Reply With Quote
Old 05-18-2016, 03:15 PM   #11029
Boz
Trader Rating: 23 (100%+)
Thank you for the input guys (Zerodefect, symmetricon,randy0025 and punkracer24).
I had a productive night practicing, 3 steps forward, 1 back. That's racing for you.
25.1sec down to 24.4sec.
Cheers again.
PS. I still have a few more of the adjustments the try.
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 05-19-2016, 07:12 AM   #11030
Cheers again.
Sweet, what changes did you do that seemed to help. also if you hvae the chance grab some avid 2+2 pistons, they are so badazz, I was 32.5 and 37.5 in mine most of the time.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 05-20-2016, 05:31 PM   #11031
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Man im so sick of breaking drive shafts and centre shafts. Hudy metal is brittle as frozen toffee.
Dang!!
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 05-20-2016, 09:01 PM   #11032
Dang!!
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 05-21-2016, 01:44 AM   #11033
FSimi's Avatar
Trader Rating: 16 (100%+)
Send a message via Skype™ to FSimi
I haven't used a '15 around the new layout. Start with my '16 setup. The only thing I would recommend will be to remove the upper front top plate and install the chassis brass
Thanks Chris,
It helps a lot.
Regards
Simon
DEX210
FSimi is offline   Reply With Quote
Old 05-21-2016, 02:40 AM   #11034
GregerL's Avatar
Originally Posted by lyons238 View Post
unless you have tons of 12mm spares i see no reason to not use the 14mm. theyre just as light with the holes in them and they feel really solid and since theyre bigger they are a bit easier to pop the wheel on quickly and they also feel like they would just never have problems slipping or wearing wheels out.
The 12 mm wheels are much softer, so we tend to use them most of the time since they produce overall more traction. They are also less prone to crack on heavy impacts....
GregerL is online now   Reply With Quote
Old 05-21-2016, 07:04 AM   #11035
Zerodefect's Avatar
Dang!!
The CVD's in my XB9 are likely stronger than the monster sized CVD's in my Losi 5ive.
If they dry up and sieze, any CVD will snap like a twig. Make sure you lube them often.
Zerodefect is offline   Reply With Quote
Old 05-21-2016, 07:23 AM   #11036
Trader Rating: 41 (100%+)
Good morning, I am looking for tire selection help. My son and I both have xb4's now (mine 2016, his 2015) and we will be running on a fairly dry, dusty , relatively smooth layout with minimal large jumps. A friend uses impacts with decent success but I was wondering if there are other, similar tires that may work. At nearly $50 a set experimentation is expensive. Lol.
Thanks in advance.
rccars4scott is offline   Reply With Quote
Old 05-21-2016, 08:15 AM   #11037
Zerodefect's Avatar
JConcepts Reflex on 60mm wheels.
JC 3d's:
If your wheels are true and uncracked, wire brush the disk so it looks new, cut off the old tire, remove the foam, and toss the wheel in a bucket of acetone so the rest of the tire comes unglued. Reuse the wheel. $30 then. Tires are always a good investment. Try to burn up as many as possible.
You'll need a 12mm hex adapter for the 60mm wheels. Get a good assortment, hex width is a critical tuning option.
Old 05-21-2016, 10:06 AM   #11038
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
has anyone tried the Yokomo Yatabe Arena Turf/Carpet Springs on the Xray? Do I need different cups? Yokomo or AE cups?
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 05-21-2016, 10:59 AM   #11039
Thanks Zerodefects. I have the adapters on both buggies and the JConcepts work out cheaper than the impacts which will help now that my tire bill is doubled with my son learning.
Old 05-21-2016, 02:52 PM   #11040
Zerodefect's Avatar
Xray cups should be fine with the 4dot/3dot worlds setup.
But when I go stiffer, I like to have aluminum cups, either the Xray or Exotech, should be fine.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
