Like Tree38Likes
Old 05-05-2016, 02:16 PM   #10981
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
http://www.exotekracing.com/xb4-12mm...ar-2-9mm-wide/
Using Kyo/AE rear wheels and ZX6 front wheels. Going by the stated width from the Exo site.
Dan is offline   Reply With Quote
Old 05-07-2016, 10:55 AM   #10982
3srcracing's Avatar
Trader Rating: 25 (100%+)
Shocked I still have my Xb4, and still losing this much money. Whats going on haha.
A Main Hobbies | Protek R/C | Team Powers R/C | Cheater Racing
3srcracing is offline   Reply With Quote
Old 05-08-2016, 10:46 AM   #10983
JAE
Trader Rating: 26 (100%+)
Default Outdrives
How often do outdrives need to be replaced on this buggy.? New to 4wd buggy and would like to know the cost of maintaining in a season? I'm not a wrenched to say the least which is most the reason I have run 2wd. Level run all one brand for ease the brain damage. Just switched to Xray xb2 carpet and dirt. How much will I be spending maintaining this thing? Love Xray but this vehicle will rarely get raced - mostly for fun. Thx all!
QUOTE=Dan;14519761]http://www.exotekracing.com/xb4-12mm...ar-2-9mm-wide/
Using Kyo/AE rear wheels and ZX6 front wheels. Going by the stated width from the Exo site.[/QUOTE]
JAE is online now   Reply With Quote
Old 05-08-2016, 10:50 AM   #10984
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by JAE View Post
How often do outdrives need to be replaced on this buggy.? New to 4wd buggy and would like to know the cost of maintaining in a season? I'm not a wrenched to say the least which is most the reason I have run 2wd. Level run all one brand for ease the brain damage. Just switched to Xray xb2 carpet and dirt. How much will I be spending maintaining this thing? Thx all!
[/QUOTE]
Outdrives are $38 a pair. For me they usually last about 1 year. That's running a 5.5 on high bite. Ymmv.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-08-2016, 12:01 PM   #10985
Zerodefect's Avatar
Get the Hudy pin tool. if it's ever in stock at amain ever again. Regular pin replacement should make your outdrives last a year at least.
Zerodefect is offline   Reply With Quote
Old 05-08-2016, 02:30 PM   #10986
i got the last one
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 05-08-2016, 03:36 PM   #10987
JAE
Old 05-08-2016, 06:22 PM   #10988
timannnn6's Avatar
Trader Rating: 124 (100%+)
I have an early 2015 running a 5.5t every week on clay. Still on original outdrives. Change pins frequently, clean and lube with moly grease after every race(very thin layer).
timannnn6 is offline   Reply With Quote
Old 05-08-2016, 07:04 PM   #10989
JAE
Are most here using the Hudy pin tool and changing the pins or are there other options? How often? Thx
Old 05-08-2016, 09:58 PM   #10990
timannnn6's Avatar
I use the Hudy tool. Hard to say when to change them. I just check them every time I clean them. If they look a little flat I put new pins in.
Old 05-09-2016, 04:38 AM   #10991
Zerodefect's Avatar
I use an arbor press for the Losi 5ive pins. Works for little cars as well. But the Hudy tool can be taken to the track where I have plenty of time to waste.
Old 05-09-2016, 05:57 AM   #10992
For those of you who run the same XB4 on carpet and med-high bite clay (electrons or slicks - depending on track maintenance)
1. What plastic hardness are you using?
2. What setup changes are you making for each? Ride height, shock oils, diff oils, slipper/gear diff, etc - Any setup sheets for each?
3. What's the easiest way to set the car up for both and/or make changes.
Old 05-09-2016, 06:12 AM   #10993
[QUOTE=JAE;14523528]Are most here using the Hudy pin tool and changing the pins or are there other options? How often? Thx[/QUOTE
I use the tool by Rc renew- works awesome! And cheaper than the hudy.
Rich D is offline   Reply With Quote
Old 05-09-2016, 07:26 AM   #10994
Zerodefect's Avatar
You might want to look at Bruno's Worlds setup for ideas.
http://forum.teamxray.com/xform/inde...setup=xb4_2016
http://forum.teamxray.com/xsheets-se...p?mode=results
High grip is mostly stiffer springs and sway bars, with the slipper. The graphite composite parts are nice if you're running clean.
Old 05-09-2016, 09:50 AM   #10995
Trader Rating: 22 (100%+)
If you have a vise you can try to use this method.
https://youtu.be/uTE6GCa-ipU
littleZEN is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
