Xray XB4 thread
Also looked at Hitec but this time it's gonna be KO Propo, maybe I will try Hitec on my 1/8 buggy.
http://tboneracing.net/brands-n-z/xray/xb4-4wd/
or
I use this one personally:
http://www.bugleboyracing.com/index.php?productid=24
or
Should still fit the same since the '16 bulkhead fits the '15. Its mounted using the 2 fronts screws going through the chassis to the bulkhead. Looks like the bugle boy bumper is out of stock though.
The bugle boy bumper only fits the 13 and 14 cars correctly. You have to modify it to fit the 15 and 16 cars and only use the 2 front holes to mount it. Which leaves the 2 rear holes to catch dirt and it looks half assed imo. Wish I would have read the description better before I ordered one.
Or build your own =)
Dremel, hammer, vice and some heat:
Found a cracked chassi at the track
Holes matched my RB6 bumper, just luck =)
Aluminium bumper = greater risk for damaged turf or similar so to calm the track police..
Bought the largest shrink tubing with glue I could find
After some work with the Dremel it became a tight fit
here is the spectrum shorty servo spec;
Torque: 208 oz-in (15.0kg-cm) @ 6.0V
Speed: 0.08 sec/60 deg @ 6v (no load)
Aluminum hard anodized output shaft/main gear with steel internal gears
Aluminum case for good heat dissipation
Aluminum mounting tabs
HERE IS THE SAVOX
Speed @ 6.0V: 0.08 sec/60°
Torque @ 6.0V: 166 oz-in / 12 kg-cm
the spectrum is not only smaller but is rated for more torque then the normal savox servos that alot of people
can someone help me out with shock oil? I have 2x1.6 front pistons and 2x1.7 rears. i am setting the car up for carpet right now but i will swtch from med-high bite clay and carpet.
What would be a good starting oil for the carpet considering the pistons im using, also what springs? help would be cool, ive never used these cst shock oils from hudy i have 450, 500, 550, 600, 700, and 800
https://www.teamxray.com/xb4/2016/download/
I also run Yokomo Yatabe Arena Purples front and rear YAS-650...seriously the car is on rails, it almost feels like i'm cheating running this car
have fun and good luck
Bent
3 dot front and 2 dot rear.
1.6-1.8 mm front swaybar (depending on grip level and tires used)
1.4-1.8 mm rear swaybar (depending on grip level and tires used)
10' front diff
1 million in center diff outdoors on astro (usually stock slipper indoors on carpet)
10' rear diff
Bent
10' front diff
10' rear diff
Bent
then next time i will mix the oils to get the desired rate.
10' front diff
10' rear diff
Bent
10' front diff
10' rear diff
Bent
AHH, thats where i went wrong. i wasnt sure if i should mix the oil. would 700 front and 500 rear work okay for a smooth indoor small carpet track and a large ourdoor astro track thats also smooth?
1mil on outdoor astro? would 500k work good on indoor clay? how would 8 50k 8 be on clay?
If it's super high grip we go to 2 mil or slipper.
For clay and dirt we run 500K.
Bent
Yes the BBoy fits. You can either cut the back half off or just sand the countersunk hole flanges off. I actually will shave a tad off the kits front bumper thus flip it upside down in conjunction with using the BBoy front bumper/skid. Not needed but its extra protection.
Thanks for quick reply's, think I will go for KO Propo RSx2 Response No.30108, just have to figure out if that is the best they have to offer for my XB4. 3 weeks away at my dealer but if I get everything else ready before I also have 1258tg, mounted in my RB6 and it will do for sure meanwhile I wait.
