Like Tree39Likes
Old 04-16-2016, 01:29 PM   #10846
Poppin Fresh's Avatar
Originally Posted by lyons238 View Post
Can someone help me with a couple things? I just got a xb4 2016 and I will be running it on both med-high bite clay, indoor med-high bite carpet, and outdoor Astro, with a 5.5t motor.
1. What diff oils should I run? Right now I only have the 8000cst hudy oil from the kit. What's a good all around front center and rear oil setup? Something I can start with? If carpet and clay are much diff, what's a good setup for each for each surface to start? When is the slipper best to run?
2. What shock setup is good for clay and carpet? I usually run 2x1.6 front and 2x 1.7 rear, any recommendations for me to try? What oil for each surfaces should I start with?
3. I have both medium and hard side guards and chassis braces. Which composite would be best for all surfaces I run on if doable without swapping each time?
1. I run 7k front, 40K center and 5k rear for clay surface and it works great for me.
2. I use the same pistons and use AE 35wt front 3 line front spring and 30wt. rear 1 line spring for neutral feeling; 32.5wt. in the rear is i want more turn in.
3. I have medium side guards all around but I took out 1 screw underneath for both front and rear chassis for grip.
The car's set-up will also rely on what kind of tires you use. If your clay track produces plenty of grip, then I would run bar style tires in a soft compound. Iff you need more grip then go softer in tire compound. Good luck and have fun.
"Nothin says luvin like fresh baked muffins, woohoo!"
Cruizin With R/C, RCBZ, Xray, Hudy, Novarossi USA, Futaba, Avid RC
Poppin Fresh is offline   Reply With Quote
Old 04-16-2016, 03:40 PM   #10847
thank you!
the hudy oils come in like 450cst, is that the same as 45wt oil?
i was thinking of running 8000 60000 8000 for diff oils, would this work for all around setup clay/carpet just to start then i can adjust later?
lastly my clay is pretty high bite, most people run slicks when the track has been there for a while, second tire choice is electrons when its a bit looser.
so im thinking of running the hard compound stuff so i can run on carpet too.
also what are ya'll running for motor position? back or forward? i have both cenral drive shafts...
| XRAY XB8E 16' | XRAY XB4 16' | XRAY XB2 CE 17' |
| New England | RCE | RCM |
lyons238 is offline   Reply With Quote
Old 04-16-2016, 04:26 PM   #10848
avaldes's Avatar
Go here for a conversion chart for oil and springs. the CST scale and SAE oil weight scales are different.
http://site.petitrc.com/reglages/Uni...pringChart.htm
avaldes is offline   Reply With Quote
Old 04-16-2016, 07:01 PM   #10849
thanks, so does anyone know how many mm's i have to space my ball stud when using aluminum rear uprights? it looks like 2-3mm PLUS the tapered ball stud washers??
side note: i have had about 5 TLR cars and Losi's before that and this is BY FAR the easiest, best building, most quality car I have ever laid hands and eyes on!!!! amazing!!
Old 04-17-2016, 08:18 AM   #10850
Trader Rating: 483 (100%+)
I run the stock set up with a few minor changes. I changed the oils to 37.5/32.5 in the shocks and 5/5/3 in the diffs. If traction is low I put the stock center slipper in. I also went down 1 degree in rear anti squat. I tried different combos of diff oils and unless traction is ridiculously high anything more that 8/100/5 is too much.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-18-2016, 01:58 PM   #10851
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
So true!!!
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 04-18-2016, 02:25 PM   #10852
gticlay's Avatar
The plastic stock hubs = 4mm in case you ever need to know that.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 04-18-2016, 07:10 PM   #10853
my new XB4 16' build is going swell. man this kit is quality! much nicer than TLR's stuff and i thought TLR was awesome!
any tips on alum servo horns? i cant find one to fit, especially with the floating servo mount.
blaat blaat murda murda
Old 04-18-2016, 07:21 PM   #10854
I have the floating servo mount. I just ordered the hudy one that the manual recommends. Works perfect. Don't have the part number at the moment.
4s losi is offline   Reply With Quote
Old 04-18-2016, 08:04 PM   #10855
it has like 2-3 adjustment holes? does it rub on the body at all?
Old 04-18-2016, 09:02 PM   #10856
I've only ran it once so far. I think it did just a bit. I put a little dab of sho gu so it wouldn't rub the paint off.
Old 04-18-2016, 09:30 PM   #10857
todb's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to todb
My favorite radio.
OVA Neo. HW, Motiv.
Orange is faster.
todb is offline   Reply With Quote
Old 04-18-2016, 10:54 PM   #10858
Cory98604's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Cory98604
Can anyone tell me if the XB4 2015 Chassis is suppose to be completely flat (besides the kick up end) or does it suppose to have a arch. I took apart one that I got on trade and the chassis has a arch in the middle?
Cory98604 is offline   Reply With Quote
Old 04-19-2016, 12:19 AM   #10859
TPR 1's Avatar
Trader Rating: 26 (100%+)
When you run the 15 without top decks the chassis can develop a bend.
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Old 04-19-2016, 04:23 AM   #10860
Originally Posted by todb View Post
My favorite radio.
The KO propo ex-1 with all the goodies?
It's amazing. I had a motocross accident and have nerve damage to my right hand and the aftermarket adjustable trigger, drop down wheel and stuff have helped SO much.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
