Like Tree52Likes
Old 03-24-2016, 08:18 PM   #10756
A2Racing's Avatar
Originally Posted by suzukipro View Post
In my 14 XB4 I found that adding a shim (not sure of the size at the moment)between the 14 tooth bevel gear and bearing helped a bunch. Also adjusting the slipper looser than the manual recommends helped with rear grip and prevented toasted driveline gears.
Thanks for the suggestions guys, I will look into that as well as possibly adding a center diff since I am running a slipper clutch right now.
Kevin Thomas
Sponsors - XRAY / RC America | Pro-Line Racing | Maclan | Venom | Xpert | Boca Bearings |
Boom RC Graphics | Sticky Kicks | World of RC Parts - Wilson, NC
A2Racing is offline   Reply With Quote
Old 03-24-2016, 09:18 PM   #10757
blarks's Avatar
Trader Rating: 29 (100%+)
xb4 '15. Can't seem to find anything about this problem, when I have the short bushings in the top position in the steering blocks, the arm that goes to the steering rod is hitting the lower arm, is this something that anyone else has encountered or have I done something wrong? I have switched the blocks around but I figured it would make no difference as they are identical.
I like rc cars big whoop wanna fight about it.
blarks is offline   Reply With Quote
Old 03-25-2016, 06:38 AM   #10758
I am mostly using B5 Rims allover my cars. Can I use Xray 365353 for all tires and use all my standard rims/wheels? Or would I mess up something? (I am asking, because my local hobby shop just has the standard Xray 12mm hexes and none of the Exotek. I'd have to order them seperately and pay another 7$ in shipping...
Or do I get this right:
Xray XB4 thread
As stated here I would have +1mm allover (which I do not want to have?)? Or 1mm less?
man1ac is offline   Reply With Quote
Old 03-25-2016, 09:42 AM   #10759
Originally Posted by 4s losi View Post
How did you you washers? The only way I could get my servo to work is to drill a new hole in the chassis. Something just seems odd here.
no dont drill anything. the 1258 fits just fine in all the xb4's I have all 3 of them and have used the 1258 in all mine. If the holes are not lining up just loose the 2 screw on each side of the servo so that the holes on the chassis line up then tighten them down. trust me it fits prefect
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 03-25-2016, 02:29 PM   #10760
I have Xray xb4 2016 version.
I'm using DE Racing Borrego ZX5 wheels with 12MM hexes (5mm wide in front and 7mm wide in rear). I noticed my rear shock ball ends have a groove worn into them (on the underside of the suspension arm) and the inside edge of my rear wheels is black from rubbing against the ball ends. Anyone else have this issue?
Arbane408 is offline   Reply With Quote
Old 03-25-2016, 03:15 PM   #10761
Thanks for the input. I went ahead and ordered the floating servo mount so I hope it won't be an issue now
4s losi is offline   Reply With Quote
Old 03-25-2016, 04:26 PM   #10762
yeah i had the floating mount on my 15 and now on my 16spec. it will work the same way with the 1258 servo and the floating mount.
Old 03-25-2016, 05:20 PM   #10763
blarks's Avatar
anybody?
Old 03-26-2016, 09:19 AM   #10764
CCristo's Avatar
Trader Rating: 55 (100%+)
Are the 363352/363351 rear uprights the same geometry as the 2016 363353 uprights aside from the vertical ball stud? Xray lists them as an option part for both the 2015 & 2016, but the stock hubs are different between those models.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is online now   Reply With Quote
Old 03-26-2016, 12:38 PM   #10765
I haven't got mine yet. Am I correct in saying that the mount is held to the chassis on one side...towards the center of the car and not on the outside? Hence the floating servo.
Old 03-26-2016, 02:00 PM   #10766
yes, it uses 3 screws on the middle of the chassis and none on the side. If you are using that then I hope you are using the medium side guards and medium chassis braces. plus the steering x brace as that way you really get the most out of the floating mount.
Old 03-26-2016, 08:49 PM   #10767
blarks's Avatar
Ok here is a pic of what I am talking about. I have the thicker bushes in at the top here and you can see it is already close, if I have the thinner ones up top then it hits the arm. Surely this cannot be right?
Old 03-26-2016, 10:43 PM   #10768
That's what I'm doing. Can't wait to get this car on the track.
Old 03-28-2016, 01:30 PM   #10769
fast-ho-cars's Avatar
on your XB4's shocks curious if most racers use stock xray pistons or go with aftermarket like Schelle?
are the Xb2 shocks same?
fast-ho-cars is offline   Reply With Quote
Old 03-28-2016, 01:35 PM   #10770
rcgod's Avatar
Trader Rating: 27 (100%+)
On my 2014 and 15 cars I only used schelle or avid. The 16 pistons fit better so I've been switching back and forth between stock and Schelle.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bprc10T3
