Like Tree39Likes
Old 03-02-2016, 08:41 PM   #10606
likea45's Avatar
Put in new ECS shafts all the way around on my 16 car. Ran it for the first time in a heat of qualifying and one of the screws, barrel and pin came out of one of the rear shafts. I found the shaft, but it looks like the stock barrel is a different size than these use. I was very careful to not allow the barrel to touch the black grease when lock-tite was applied. The others have held fine. My question is does anyone know the part numbers for the barrel, set screw and pins if those are different than the stock pin as well? Thanks.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 03-03-2016, 06:36 AM   #10607
this is the 3rd time ive heard that about those shafts. 2 on here and once on facebook. I dont have my installed yet but and wondering if i should even do it. I would hate to lose crap and not be able to use them after spending $80 bucks.
my question Likea45 is did you notice a difference when running it.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 03-03-2016, 06:52 AM   #10608
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Guys... HUDY has been selling ECSs for touring cars since 2010 or 2011, this is nothing new. There is nothing wrong with the *design* but with how they are built. The trick a lot of onroad guys use, though, is to put heatshrink over the built ECS to help reduce the risk of losing pins.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 03-03-2016, 07:09 AM   #10609
symmetricon's Avatar
Trader Rating: 27 (100%+)
Make sure to de-grease the barrel and set screw and then use red loctite.....if you want to take them apart use s soldering iron to un-cure the red loctite....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 03-03-2016, 07:13 AM   #10610
kuruption's Avatar
Blue locktite is all that is needed.. don't needred locktite. Locktite does need cure time though, overnight would be best.
Ray Sundland
Old 03-03-2016, 09:07 PM   #10611
likea45's Avatar
They may have been out for touring cars for awhile but I'm thinking perhaps they take more strain on a car that can be landing consistently from a few feet in the air. I applied lock-tite to the screw/barrel before greasing it and placing it in the shaft. Luckily as mine came out I was able to find the shaft so as to not be out $45. I'm still trying to locate the correct parts to replace the barrel, pin and set screw as most part numbers point to the T2 touring car and am not sure if they are compatible.
On the track I have to say I did instantly notice a positive difference. The car was able to enter and exit corners much faster and landed jumps on power astonishingly well. It was like a new car to me. Although this was quickly crushed by losing parts and the shaft causing a DNF for the round.
Old 03-03-2016, 10:13 PM   #10612
Trader Rating: 32 (100%+)
Waiting xb4 '16 come out wish all upgrade xb4 parts will be standard for next xb4
raved007 is offline   Reply With Quote
Old 03-04-2016, 02:50 AM   #10613
what does 5mm of spacers on the aluminum steering plate equal on the stock plastic steering plate? the stock plate thicker I think?
sealander is offline   Reply With Quote
Old 03-04-2016, 05:40 AM   #10614
Honestly, the car needs nothing out of the box. I bought a bunch of tuning parts and found I always go back to the stock components. The only thing I'd recommend getting are springs.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 03-04-2016, 07:57 AM   #10615
I am pretty sure it equal 1mm. I the stock plastic one if 4mm and then you add 2mm shim onto that. I myself run the aluminum plate with 6mm on it.
Old 03-04-2016, 12:47 PM   #10616
wisconsinbasher's Avatar
Trader Rating: 29 (100%+)
Almost finished putting my 16 kit together and to be honest it's my first kit I have ever put together. I'm cheap and have always bought used. All I can say is this kit has went together perfectly and the fit and finish goes above and beyond any of my expectations. Can some one recommend a good pininion and servo arm I'm running a 6.5 on a smaller tight indoor track with gear diff with stock spur thanks .
wisconsinbasher is offline   Reply With Quote
Old 03-04-2016, 01:12 PM   #10617
jmcelroy42's Avatar
Im running a 20t pinion on a medium size indoor track.
jmcelroy42 is offline   Reply With Quote
Old 03-04-2016, 02:07 PM   #10618
suby723's Avatar
Trader Rating: 21 (100%+)
http://www.exotekracing.com/xb4-12-a...aster-hub-set/
About time somebody makes 12 degree castor blocks for a fair price!
suby723 is offline   Reply With Quote
Old 03-04-2016, 02:35 PM   #10619
handyman77's Avatar
Trader Rating: 25 (100%+)
I need help, I have a 15' and it just won't turn, jumps great and all but it pushes like crazy so any help will be appreciated
set up
6K FRONT
100K CENTER
4K REAR
NO SWAY BARS
20MM RIDE HEIGHT
600 SHOCK OIL FRONT
450 SHOCK REAR
CHANGED THE ACKERMAN AND IT DIDN'T DO ANYTHING.
Any suggestions??
MBX7TR....O.S. SPEC 3 .NOVAROSSI PALOMA 7
MUGEN SCTE CONV. TEKIN 4600 HD HOBBYWING XR8
MBX7R..NOVAROSSI DRAKE MOTOR
HOT BODIES D413 LRP VECTOR 6.5T
LRHhobbies.com in placentia, CA.
handyman77 is offline   Reply With Quote
Old 03-04-2016, 03:53 PM   #10620
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default ??
set up
6K FRONT
100K CENTER
4K REAR
NO SWAY BARS
20MM RIDE HEIGHT
600 SHOCK OIL FRONT
450 SHOCK REAR
Any suggestions??
is it set to box stock settings otherwise ?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
