Like Tree54Likes
Old 02-26-2016, 12:23 PM   #10561
Default ECS drive shaft review
Initially I was on the fence about these because of the price, but if you break down each piece for what's in the package, it's basically the same price as the stock driveshaft/barrel/pins/axle, etc. I also found a youtube video that showed the differences with the regular vs. ecs drive shaft and I figured what the heck, lets give them a try.
After I installed the ECS, I put some tires on the car and gave it a little throttle as a bench test to see if there was any difference. I was skeptical of any real difference, but you can see an improved smoothness. The ecs does eliminate the wheel chatter(especially at wheel lock), but that doesn't really matter to me as much as actual results on the track so I went to the track.
At the track(which is SCVRC medium to medium high traction indoor clay) the difference is noticeable. I only have the front ecs and the car just had a little more turning when compared to stock. The car is more settled when coming off of a jump and if you happen to have a jump with a turn right after, this is where I noticed the biggest difference. The car settles quicker and you can initiate the turn quicker. Other than a little more turning and settling the car quicker/better I didn't notice any other difference.
So having the car give a little more steering is great. Being able to not have to wait as long for the car to settle down and get into a turn quicker (especially on a turn right after a jump) is great. What isn't great is losing one of the pins that holds the drive shaft together. The instructions are clear and I used loctite as instructed, but with grease so close to the area where loctite is applied, it's a bit tough to make sure the set screws lock in place. I double checked to make sure the pins were well secured, but as you can guess, I lost a pin. I had to go back to the stock drive shafts and that's when I noticed how much better the ecs were.
At the end of the day, the ecs design requires you to make sure your loctite game is on point. Make sure you don't have grease interfering with the loctite bond or else you will be waiting for your pin order like me. For those wanting to eek out every last bit out of their car, this would probably be a good option to have. But, items like the floating servo mount and graphite stiffeners that allow you to remove the top decks(for ex 2015 xb4) are probably a better bang for your buck just as a couple of examples.
Hope this helps someone.
Freeski is offline   Reply With Quote
Old 02-26-2016, 04:22 PM   #10562
jakeb's Avatar
Hey Everyone,
Quick question(s) about running the rear aluminum uprights. By the looks of it they need quite a few spacers under the ball studs to raise the ball stud up to the same height as the plastic uprights.
With that said for a medium traction dirt/clay setup how many spacers should I be running under the ball stud and should I get longer ball studs? If so what length?
Thanks,
Jake
jakeb is offline   Reply With Quote
Old 02-26-2016, 05:53 PM   #10563
suby723's Avatar
Trader Rating: 21 (100%+)
You need 6mm in washers and you need 10mm ballstuds.
suby723 is offline   Reply With Quote
Old 02-26-2016, 07:01 PM   #10564
gticlay's Avatar
Originally Posted by jakeb View Post
Hey Everyone,
Thanks,
Jake
The stock plastic hubs and the aftermarket aluminum hubs that are horizontal ball studs are the same as putting 4mm under the vertical ballstuds on the authentic X-ray aluminum hubs. Astro and carpet setups tend to use 6mm and the longest ballstud thread is 10mm - that is what the team uses. If you are on medium traction, I would start at 4mm height like the stock hubs are. If you want to loosen up the rear end a little bit like you need to on astro/carpet add spacers 1mm at a time and see how it feels. If you want to lock the rear end up a little bit while cornering, remove washers and see how that feels. I think you'll end up at 3mm to 4mm with the aluminum hubs on truly medium traction clay conditions but my car feels good with 5mm to 6mm on what I would say is medium-high to high traction (for clay). Just make sure if you put the 10mm ballstud in there that you don't have too much thread when you go down in spacers and strip out something or have play between the ballstud and hub! Hope that helps.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 02-27-2016, 11:05 AM   #10565
Hello,
Can someone explain to me exactly the gains-loses from the eccentric roll center bushings on the different positions? or if there is a good link to read about it?
Thank you in advance,
Nick
grifind is offline   Reply With Quote
Old 02-27-2016, 10:46 PM   #10566
Customworksking's Avatar
Trader Rating: 73 (100%+)
what other brand other than kyosho $$$$$ springs can i use ?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-27-2016, 11:04 PM   #10567
Originally Posted by grifind View Post
Hello,
Nick
bent just posted about this in the XB2 forum as well.
pin out = less roll/less traction
pin in = more roll/ more traction
obvsiously more to it, but good base knowledge
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 02-28-2016, 07:19 AM   #10568
I've used Associated springs on mine in the past.
You need to get the Associated spring cups to go along with them, use the middle height ones.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 02-28-2016, 08:25 AM   #10569
suby723's Avatar
I use yokomo yatabe springs on both my Xray cars. Never cared for Xray springs,needing to cut them shorter to get low ride height and they rub on the shock bodies..no thanks. I tested yatabe springs vs. Xray springs and cut .3 off my fastest lap only changing springs. Green rear/ black and purple fronts are all you need. Also you will need to go lower weight on oil.
Old 02-28-2016, 08:41 AM   #10570
What i would like to know is the diagonal in and outs :P but thank you
Old 02-28-2016, 10:10 AM   #10571
Default size
so their shorter than the stock xray springs I run on dirt so i need full motion
Old 02-28-2016, 10:39 AM   #10572
suby723's Avatar
I just race on carpet these days so yatabe springs are great. When I was running on dirt surface I really liked ae springs. Medium bite clay black/green rear springs worked great with yellow/red front springs. Use the ae spring cups and you will be dialed.
Old 02-28-2016, 01:15 PM   #10573
Last night i rebuilt my shocks on my xb4 and one of my rear shocks no matter what or how many times i tried, it doesnt work properly,even on 0 or 100% rebound. it juststands still wherever i press it. any ideas what it might be? damaged o-ring, central pin? or..?
Old 02-28-2016, 01:25 PM   #10574
advpball's Avatar
Trader Rating: 28 (100%+)
Bent shock shaft? take out and roll on flat surface.
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and Motiv motors
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 02-28-2016, 01:32 PM   #10575
i did but it seem fine :/
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
Currently Active Users Viewing This Thread: 14 (1 members and 13 guests)
dabear
