Like Tree36Likes
Old 01-28-2016, 12:13 PM   #10261
Trader Rating: 30 (100%+)
Originally Posted by bounced View Post
What can I do to make this drive more like a 2wd/or easier to drive?
Currently it just wants to traction role/flip easy, and you can't really push it that hard.
Tried associated springs just to make shock package stiffer, and it's still the same thing.
Check your camber on all your wheels. you definitely don't want positive camber but you don't want to much negative camber.
As Symmetricon replied with a very important question which would help in providing better suggestions. "what kind of track conditions are you running on?'
Norse is offline   Reply With Quote
Old 01-28-2016, 10:00 PM   #10262
timannnn6's Avatar
Trader Rating: 124 (100%+)
Originally Posted by randy0025 View Post
I ordered one from him and got it yesterday. took about 8 days total to get so thats prety fast being its overseas. much cheaper then buying from xray or amain if you ask me
Where are you guys ordering the body from?
Edit: N/M found it http://www.ebay.com/itm/X-Ray-Xb4-4w...EAAOSw14xWLRVE
timannnn6 is offline   Reply With Quote
Old 01-28-2016, 10:36 PM   #10263
Trader Rating: 478 (100%+)
My car dos great on low-med traction wet dirt. With the book set up and lighter diff and shock oils my car makes our wet dirt feel dry. I think I used 5 & 3 for the diffs and 30/25 for the shocks. Other than that the only other change from stock is the lack of the 3 mm up travel limiter on the shocks. There is not a faster car on our track and I only have a 13.5. My indoor/dry car uses the book set up and a center gear diff w/100k. Its perfect for med-high traction dirt/clay. I cannot say enough good things about the XB4 2016. Its a miracle car.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 01-28-2016, 10:44 PM   #10264
I don't mean to be a jerk but if you want your car to feel like a 2wd you should get an XB2. You can tune your car to not turn over but its never going to feel like a 2 wheeler. I would stiffen it up and take a little droop out if its flipping. I can drive mine much harder than any of my 2wd buggies so I'm not sure why you'd want your wheeler to be something its not.
Old 01-28-2016, 11:51 PM   #10265
UK.hardcore's Avatar
in the rear with stock position you must use 2mm up travel limiter or your driveshaft will catch the pin slot on full compression.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 01-29-2016, 04:59 AM   #10266
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
And snap goes your outdrive. 35.99 a pair 😢
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 01-29-2016, 07:08 AM   #10267
When you mean drive shaft, are you referring to the CV/dogbone/swingshaft? I'll have to check that out. I guess that I've been lucky for the last couple of months. I run a TBone rear skid which is at least 2mm thick. That might be what has been keeping my car from bottoming out and breaking.....I'll definitely look into adding the the limiters in the rear.
Old 01-29-2016, 07:26 AM   #10268
I went ahead and looked at my car, and you're right, the dogbone bottoms out in the outdrive under full compression. I'll add the limiters right away.
Old 01-29-2016, 09:12 AM   #10269
I am glad you said this aswell. Because I have been running no uptravel shim in the rear or front. Guess I will be adding 2mm tot he rear asap.. thanks
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 01-29-2016, 09:16 AM   #10270
You can also go wideron your eccentric bushing settings, thus out being little wider width. I only use one o-ring and no up travel limiters, thus having no issues with dog bones bottoming out within the diff out drives.
Old 01-29-2016, 09:24 AM   #10271
Has anyone ran their XB4 rear shock tower on the backside of the rear diff, thus allowing for the rear shocks to be placed on the backside of the shock tower and the backside of the rear a-arms. If so what was the outcome as far as how it affected the buggies performance.
Old 01-29-2016, 09:37 AM   #10272
rcgod's Avatar
Trader Rating: 27 (100%+)
I tried it and the main problem is reduced droop because the back of the arm is lower than the front due to anti squat. You would have to use longer shock ends to get the lost droop back for lower bite tracks.
rcgod is offline   Reply With Quote
Old 01-29-2016, 10:04 AM   #10273
Trader Rating: 48 (100%+)
Thinking of picking up this car, had the 2014 version a few years ago and really liked the car, my question is the only problem I had with the car were the shocks they got dirty very quickly, have they updated the shocks?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-29-2016, 10:13 AM   #10274
Thanks RCGod, Just trying to understand why many say rear shocks behind the rear shock tower and thus attached on the backside of the rear a-arms is better for low traction.
If you had the droop you needed would you think that would be better for low bite.
thanks my friend
Old 01-29-2016, 10:35 AM   #10275
rcgod's Avatar
thanks my friend
Hard to say. It will put more weight at the back of the car which would be good for forward traction on low bite, but then again would increase the pendulum effect in the corners which might make the car loose. Would have to try it to find out for sure.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
