Like Tree38Likes
Old 01-27-2016, 11:35 AM   #10246
gticlay's Avatar
Do any of you know if the B5 front caster block bushings will fit the Xray? I seem to have lost one...
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 01-27-2016, 12:16 PM   #10247
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by RichD View Post
Does anyone know the theoretical lb/in rating of the 1 dot front springs?
Going by the spread between 2 dot and 3 dot, they should be around 3.31 lbs/in.
rcgod is offline   Reply With Quote
Old 01-27-2016, 12:19 PM   #10248
STLNLST's Avatar
Trader Rating: 19 (100%+)
You practicing Friday? Curious how that puppy feels now.....lol.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-27-2016, 02:31 PM   #10249
Originally Posted by LAGuy View Post
Hi Bent, finished putting my XB2 together. Beautiful kit!
What roll center holes were you using on Malins Buggy?
Could you please post a pic of the homemade chassis stiffener that attaches to the battery brace? Thanks!
Sorry! Wrong thread! Was late 😴
LAGuy is offline   Reply With Quote
Old 01-27-2016, 04:31 PM   #10250
avaldes's Avatar
Look here for spring rates. It cross references different mfgs against rate.
http://site.petitrc.com/reglages/Uni...pringChart.htm
avaldes is offline   Reply With Quote
Old 01-27-2016, 06:44 PM   #10251
rcgod's Avatar
I'll be there at 1 to drop off the losi to Dujuan. Not planning on practicing though have other stuff going on.
Old 01-27-2016, 06:46 PM   #10252
Cheers
RichD is offline   Reply With Quote
Old 01-28-2016, 08:37 AM   #10253
gticlay's Avatar
Originally Posted by BentKa View Post
5K / 500K / 3K
1.2mm sway bars front and rear
1 dot springs front and rear
Bent
Same pill setup as the Trencin carpet setup?
Old 01-28-2016, 09:01 AM   #10254
BentKa for low grip and tight track do you recommend the ECS drive shaft front and rear and the independent servo mount?
atipowered is offline   Reply With Quote
Old 01-28-2016, 09:08 AM   #10255
What can I do to make this drive more like a 2wd/or easier to drive?
Currently it just wants to traction role/flip easy, and you can't really push it that hard.
Tried associated springs just to make shock package stiffer, and it's still the same thing.
bounced is offline   Reply With Quote
Old 01-28-2016, 10:38 AM   #10256
Trader Rating: 30 (100%+)
Try running a higher roll center this with your eccentric bushings. Also adjust your camber links and mounts front and rear for more roll.
Norse is online now   Reply With Quote
Old 01-28-2016, 10:42 AM   #10257
symmetricon's Avatar
What track conditions and whats your setup?
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 01-28-2016, 11:04 AM   #10258
Originally Posted by Norse View Post
Hey my friend for a 16XB4 body check out Penguin RC bodies. They have a V2 for the 16 XB4 that will cost you $17 US dollars plus another $7 to ship.
I ordered one from him and got it yesterday. took about 8 days total to get so thats prety fast being its overseas. much cheaper then buying from xray or amain if you ask me
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 01-28-2016, 11:18 AM   #10259
+1 as they are a very good deal and great option.
Old 01-28-2016, 12:05 PM   #10260
Quick question which may seem a little stupid on my part, however I need clarification.
For lower bite conditions will placing the rear shocks behind the rear a-arms provide more traction? For some reason this setting on the XB4 has been somewhat unclear to me.
The YZ4 advises for lower bite conditions to run the rear shocks behind the rear shock tower, thus behind the rear a-arms.
What rear shock position relative to the rear a-arms and rear shock tower is working best for lower bit conditions regarding the 16 XB4?
Again in owning the 15 XB4 and moving on to the 16XB4, one would think I would have a good understanding of this, however thats not the case.
Thank you for any advice pertaining to the above as always I appreciate the help from the participants in the XB4 forum.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
