Like Tree45Likes
Old 01-14-2016, 12:17 PM   #10036
gticlay's Avatar
Originally Posted by BentKa View Post
Video of Malin's Xray XB4 in qualifying @ 2016 DHI Cup in Denmark with Bruno Coelho, Martin Bayer, Jörn Neumann, Michal Orlowski, David Ronnefalk etc.
She ended up qualifying as #8 for the A-final using this setup:
http://forum.teamxray.com/xform/inde...setup=xb4_2016
Bent
Thanks for sharing all the setups, I know most appreciate it very much. One thing that would be helpful for me, and I've seen a few other people mention it, is the measurement for shock shaft length. I assume you always measure the shock length anyway when you build shocks to ensure they are matched in length and perhaps you **always** run the lower eyelet screwed fully on, but I'm pretty used to playing with those a t least a little bit to easily change droop a mm or 2 while testing the car. I prefer to start with the eyelet 1mm out so that I can easily reduce droop if I want to try that out.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 01-14-2016, 12:21 PM   #10037
Thumbs up
And I'm always happy to help anyone at the track no matter what brand you run or what level of driver you are.
I have no secrets and share everything to everyone.
Bent
Edit: a "couple" of laps from last January on the very track you test and practice on running a prototype 2WD and '15 4WD with different chassis and center diff.
You have been a tremendous help to me, I really appreciate all you do on here to help with setups and such.
Amazing driver you have in the videos, very smooth style.
two shoes is online now   Reply With Quote
Old 01-14-2016, 12:24 PM   #10038
BentKa's Avatar
I will start filling out that info for the setups from now on.
And yes you are correct I always measure the shocks to make sure they are exactly the same.
Very rarely do we use extra droop indoors, but outside we use it quite often
It's a great tuning aid.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 01-14-2016, 12:27 PM   #10039
BentKa's Avatar
I'm just glad to be of help and share some of the information we acquire through all the testing.
And yes she gets around quite well for her age
Bent
Old 01-14-2016, 05:32 PM   #10040
Does anyone know if the HUD105520 wheel adapter is compatible with the wheels on this car for balancing? My xb4 is in the mail and i'm ordering the tools I need to properly set it up (never done this before). Thanks!
bleomycin is offline   Reply With Quote
Old 01-14-2016, 05:47 PM   #10041
timannnn6's Avatar
Trader Rating: 124 (100%+)
You would want the 105525 for 14mm wheels.
timannnn6 is offline   Reply With Quote
Old 01-14-2016, 06:05 PM   #10042
Thanks for clearing that up! That part seems to be completely unavailable online in north america at least from what i've been able to find. If I switch to the 12mm hex's and get 12mm wheels what part would I use for those?
Also, I see in the set-up sheets they use #107711 droop gauge, #107701 support blocks and #107720 ride height gauge. Are these the correct tools to order? Also, I don't see a droop measurement in any of the set-up sheets, only ride height?
Sorry for the dumb questions this is my first time setting up a car.
Old 01-14-2016, 06:20 PM   #10043
spu83's Avatar
http://www.hudy.net/xhudy/products/p...132a46b4101dda
Download the setup book. It will tell you what tools and how to use it.
Pak Lee
XB8E, XB4'15, 410.3, T4'16, XB2de, X1'16, XT2de
spu83 is offline   Reply With Quote
Old 01-14-2016, 07:59 PM   #10044
Awesome, those are exactly what I needed! I must have missed reference to them in the instruction manual when I read through it.
What is everyone using to balance the wheels for this thing? I can't seem to find a wheel balancer compatible with 14mm or 12mm hex anywhere online in the US.
Old 01-14-2016, 10:39 PM   #10045
BentKa's Avatar
Wheel balancing station:
http://www.hudy.net/xhudy/products/p...4&kategoria=69
Adapter for 14mm hex:
http://www.hudy.net/xhudy/products/p...5&kategoria=69
Adapter for 12mm hex:
http://www.hudy.net/xhudy/products/p...6&kategoria=69
Bent
Old 01-14-2016, 10:41 PM   #10046
timannnn6's Avatar
Hi Bent,
The 12mm adapter will not work with rear buggy wheels. The shaft is just not long enough. I modified mine to work. I've put in a request on the site but no response as of yet.
Old 01-14-2016, 10:42 PM   #10047
BentKa's Avatar
Yes those are the ones we use.
Most only measure shock length for 1/10 since you don't have droop screws.
Bent
Old 01-15-2016, 05:34 AM   #10048
Bentka how much rebound you use? My track is very bumpy and low traction.Thanks
atipowered is offline   Reply With Quote
Old 01-15-2016, 06:39 AM   #10049
Slapjack's Avatar
Trader Rating: 19 (100%+)
Bentka, I asked about the center diff yesterday (For running on clay track low to med grip) and I am just wondering why you use such thick oil in them. Using the 500,000 basically locks it up right? Why is that the way to go with these 1/10 buggies? Just trying to understand... Thanks
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 01-15-2016, 08:41 AM   #10050
BentKa's Avatar
I don't know why people have this misconception and won't even try it.
Center diff with 500.000 cst has a ton of diff action.
We run 1.000.000 95% of the time and only use 500.000 on really blown out dirt tracks or slippery and greasy astro tracks.
Running lower weights is easier to drive for sure, but it's way too inconsistent and lacks a lot of forward traction when you start pushing.
It's just slow…….safe…..but slow.
People generally running the center diff with lower weight oils find the XB4 easier to drive and faster when they swap back to a center diff.
Unfortunately a lot of bad setups are masked by the forgiveness of the center diff.
We always test both slipper and center diff before deciding on what to run.
I always carry 3 sets of front and rear diffs + 3 sets of center diffs to be able to quickly swap between them and get comparable results in identical conditions.
And we always warm up the diffs to running temperature before starting a heat.
Hold front and rear wheels on one side and apply throttle for a few seconds, then just the front or rear set of wheels to warm up the center.
Bent
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
