Like Tree45Likes
Old 01-10-2016, 04:26 AM   #9961
Jones Auto's Avatar
Is there a major delay on the stock bodies? XRA 369702? Seems no one has had them in stock for weeks.
Tekno EB 48.3- Tekno ET48.3 -Xray XB4 Team Associated RC10 T5M
Jones Auto is offline   Reply With Quote
Old 01-10-2016, 06:27 AM   #9962
rcgod's Avatar
Trader Rating: 27 (100%+)
Have you tried calling Rc America?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-10-2016, 06:28 AM   #9963
BentKa thanks for sharing all the info.Im from Spain and I purchased a Xray XB4 16 recently and I applied some changes that you said before.My track is of clay,tight and with bumpy sections,low traction.I have some questions,what stabilizer bars recommend or no bars is better for this conditions? how much camber its a good point? I have 0 rollcenter excentrics,its better more? what rebound of shocks is a good point?
atipowered is offline   Reply With Quote
Old 01-10-2016, 06:38 AM   #9964
UK.hardcore's Avatar
i know it's a CAT but what is your opinion on the fan and the way it's been mounted?
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 01-10-2016, 12:16 PM   #9965
Originally Posted by gticlay View Post
I am not aware of an X-ray specific rim from Pro-Line.
not rim, but a 12mm hex at half the cost of xray and cheaper then the exotek. they same it also keeps the width the same as stock
http://www.stormerhobbies.com/cgi-bi...=ns&pn=JCI2340
and
http://www.stormerhobbies.com/cgi-bi...=ns&pn=JCI2339
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 01-10-2016, 12:22 PM   #9966
Originally Posted by crusty View Post
What are you guys using for a fan mount on the xb4?
someone on facebook i have been talking to is making one and should be ready for orde any day if not out
This is what the design looks like. If my info is correct it will fit XB4 2016 when running shorty pack. It fits 30x30 fan with 24x24 hole pattern and M2.5 screws. Measurements taken from an orca 30x30x7 fan
Old 01-10-2016, 02:29 PM   #9967
Trader Rating: 30 (100%+)
Originally Posted by rcgod View Post
I made some changes to the car and it would blow your mind how much better it is now compared to when you drove it. This car is like cheating.
I went to 3 hole pistons, took the front top deck off, went to 2 dot front springs, gear diffs with 7k/3k, and moved shocks out on arms. It's like a slot car now. Car is amazing.
RC God,
Did you go with 3 hole 1.3 all around? Are you running the medium composite side chassis rails? Regarding the composite chassis stiffeners are you using th optional medium front and rear or the hard front and rear?
Norse is offline   Reply With Quote
Old 01-10-2016, 04:08 PM   #9968
rcgod's Avatar
Originally Posted by Norse View Post
RC God,
Yes 3 hole with 40/30 losi oil. I was running the hard braces and side rails with all of the stiffening screws removed except 1 in the front. I just got the medium flex parts yesterday.
Dialed RC Hobbies
Old 01-10-2016, 04:40 PM   #9969
Thanks my friend much appreciated.
Did you go with kit 1.3 Pistons or aftermarket shelle or avid?
I just ordered the medium flex side rails and medium flex braces. Thinking if one needed to go stiff due to hitting a high bite track you could obviously switch back the hard braces and hard rails or possibly just put on the graphite brace stiffeners.
Thanks again
Old 01-10-2016, 04:51 PM   #9970
Thanks again
Where did you order the Med parts from? I haven't found them in stock anywhere online. (At least cont US)
Kyosho: 2x-RB6.6, ZX6.6, RT6, SC6
HW XR-StockSpec x4
Sanwa MT4S
wrutherf is offline   Reply With Quote
Old 01-10-2016, 05:08 PM   #9971
rcgod's Avatar
Thanks again
I used the kit pistons. They seem to fit the shock body better than the older models did. Maybe the new shock bodies are slightly smaller in ID.
That's what I was thinking. Our indoor track is low to med bite but when we go outdoors it's high bite sugar so I can switch back to hard parts then.
Dialed RC Hobbies
Old 01-10-2016, 05:09 PM   #9972
rcgod's Avatar
I ordered mine from RC America.
Dialed RC Hobbies
Old 01-10-2016, 05:28 PM   #9973
Thanks my friend.
Do you think one could just slap the graphite chassis brace stiffener over the medium braces, thus a super quick possible way to stiffen up the chassis.
I sound lazy as swapping the medium to hard braces is not hard but wondering if the above would provide enough rigidity as just adding the cf brace stiffer would be really quick.
Old 01-10-2016, 06:05 PM   #9974
amain.com had them but sold out in 2 days. they go more coming. try calling rc America
Old 01-10-2016, 06:12 PM   #9975
rcgod's Avatar
Thanks my friend.
From what Bent has said, the 2015 car was medium flex out of the box and it worked fine for me on high bite. I'm hoping that running the med flex parts and tuning with the stiffening screws I will be able to run it on all surfaces. From Bent's experience it sounds to me that it should work fine.
Dialed RC Hobbies
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
