Like Tree52Likes
Old 01-08-2016, 01:58 AM   #9946
gticlay's Avatar
Originally Posted by avaldes View Post
Some serious first world problems posted on this thread! LOL!
I'm thinking that racing mini cars by radio control is a first world activity...
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 01-08-2016, 02:36 AM   #9947
avaldes's Avatar
Fair enough!
avaldes is offline   Reply With Quote
Old 01-08-2016, 07:13 AM   #9948
until we see a rustler with a bomb strapped to it.
Franzchise is offline   Reply With Quote
Old 01-08-2016, 10:16 AM   #9949
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Uh oh, you said the "B" word
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 01-08-2016, 02:04 PM   #9950
Slapjack's Avatar
Trader Rating: 19 (100%+)
I have a quick question regarding FDR. I bought my 15 used and the person before me said he installed metal diff gears. By doing that do I now have a different internal ratio for when I am figuring FDR? Stock internal ration is 2.5 I believe but thought I saw somewhere that the steel bevel gears were different than the plastic ones.
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 01-08-2016, 02:12 PM   #9951
BentKa's Avatar
Exactly the same just different material.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 01-08-2016, 02:14 PM   #9952
UK.hardcore's Avatar
It's the same.
UK.hardcore is offline   Reply With Quote
Old 01-08-2016, 05:41 PM   #9953
just noticed Proline makes the 12mm hex at the same size of xray so you get the right offset. also they are half the price. hate to put another brand out there as having more is even more confusing but it is half the price and in the info section it says it keeps the standard offset.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 01-08-2016, 05:50 PM   #9954
again. does anyone know if these fit the 16spec. I know the the top braces most likely dont fit since they changed things up, but what about the bottom. anyone, anyone lol
Old 01-08-2016, 07:25 PM   #9955
Slapjack's Avatar
Bent
Thank you
Old 01-09-2016, 03:54 AM   #9956
I replaced the front upper deck on my 16 with the optional brace. Now I am concerned that after hard landings the chassis at the front is more prone to bend ( at the kick-up). Does I have to worry about that ?
Is seems to me a contradiction that with the optional brace we are looking for more grip on high traction surfaces but on the other hand introduce more flex. Can someone explain the theory behind this ? Thx.
Sergel is offline   Reply With Quote
Old 01-09-2016, 06:20 AM   #9957
gticlay's Avatar
I am not aware of an X-ray specific rim from Pro-Line.
Old 01-09-2016, 06:03 PM   #9958
BDRMBULLY's Avatar
I heard ppl that have a 13/14 car that want 16 bulkhead have to modify the shock tower. But my bud says he also had to modify the top brace in order for it to fit. Is this the case for anyone else?
Hand D Flooring
Old 01-10-2016, 12:30 AM   #9959
Trader Rating: 20 (100%+)
IIRC the top brace needs to be shortened at the front to clear the newer bulkheads because they added material to the upright portion that holds the tower in place. I do not know about shock tower mods for the 16 bulkhead because I have not used that bulkhead on my '13 car.
Either way the top deck fix is super easy, just grind it down a bit to clear that area and you're done.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 01-10-2016, 02:54 AM   #9960
crusty's Avatar
What are you guys using for a fan mount on the xb4?
crusty is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
