Like Tree39Likes
Old 12-31-2015, 09:14 PM   #9811
Slapjack's Avatar
Trader Rating: 19 (100%+)
Originally Posted by UK.hardcore View Post
Kyosho front AE rear.
If you could do me a huge favor and send me part numbers or links for each wheel I would want (for 5.5mm/9mm exotek) for front and rear in 2.2 and 2.4 I would really apreciate it. There are just too many different options and I want to make sure I get this right this time.
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 12-31-2015, 09:31 PM   #9812
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by RobsRacin View Post
Well last night I tried put 7,100,5 as well as 2x1.6 and 2x1.7's in the shocks as well as moving the ballstud to the forward hole of the steering plate and WOW the car was 10x better. Handles the bumps better and felt like it accelerated more linearly. We are still in between tires at the track and I made the wrong choice in the the main, but the car was still able to best hot laps I had set earlier in the day because of how easy it is to drive. Didnt get hotlap for the field but atleast another xray did. Now I just need to focus on my driving and making fine adjustments to the car, I am very happy with how it feels
Glad those changes helped you in the right direction. You will find that very small changes go along way with the xb4.
suby723 is offline   Reply With Quote
Old 12-31-2015, 09:49 PM   #9813
Trader Rating: 32 (100%+)
Originally Posted by Slapjack View Post
I really wish people would know te information they give is correct before posting an answer to someones question. I was told 22-4 would give me the correct width with 5.5 hexes. So if I'm understanding you correctly with what I have now (22-4) front and rear my front is going to be 2mm wider than in the rear? Is that necessarily a bad thing? Those are the only wheels I have currently and was planning on racing Saturday. So idk if I should glue up the tires and run as is or if I skip a race and order the kyosho fronts. You do mean DE speedline kyosho 2.4/60mm wheels is what I want right?
And what about my rear? I have 22-4 rears with exotek 9mm. Is that even correct?
I measure mine with hudy set up table with un-glued tires is 247mm front and rear If you using exotek 12mm 5.5 hex Front and 12mm hex exotek 9.0 wheels DE speedline 22-4/D413/B44.3
raved007 is offline   Reply With Quote
Old 12-31-2015, 10:30 PM   #9814
gticlay's Avatar
The Exotek are 2mm too wide, as your testing shows, (again).
gticlay is offline   Reply With Quote
Old 12-31-2015, 10:35 PM   #9815
gticlay's Avatar
The Exotek are too wide. Go read the post where Bent measures the stock 14mm width at 245mm. Get the wider X-ray 12mm hexes he recommended for the same 245mm track width and use X-ray 12mm rims. The 22-4 TLR offset rims are the same track width as well. Kyosho are a bit different.
Old 12-31-2015, 10:54 PM   #9816
rcgod's Avatar
Trader Rating: 27 (100%+)
Like the guys are saying I just measured my car with stock rims and hexes and 5.5mm exotek hexes and 22-4 rims and stock is 2mm narrower. I found these hexes in my parts box, not sure but I think they came from a kyosho, and they are 4mm wide and fit perfect. You can get the correct track width with a couple of shims or hex spacers and use 22-4 rims. Sorry not sure what they came from I'm a pack rat and keep everything for situations like this.
Fyi kyosho wheels with exotek hexes are in the middle at 1mm wider than stock.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 12-31-2015, 11:06 PM   #9817
Originally Posted by John Myall View Post
Just knock yourself up something like this, I've not broken a bulkhead or a shock tower since in got it back in 2013.
this is just what all the prev 16 models need, no one makes anything like this,do you have a couple extras you could sell? what did you use for the rear?
ResultsRC is offline   Reply With Quote
Old 12-31-2015, 11:56 PM   #9818
That's the only one I have, but a friend has it at the moment to knock some more up as most of the 4wds at my local club are XB4s of some sort. Maybe when he's done them, he could sell you some.
I never had a problem with the rear bulkhead, so never used anything extra. The only different thing I did when I made mine & ones for others, was to use washers & some flanged nuts on the inner ballstuds, as I thought there was the chance that in a crash, it could twist the stud, which was why the towers would snap there.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 01-01-2016, 01:47 AM   #9819
UK.hardcore's Avatar
as far as DE Racing wheel go there is only one type of 4wd front in 2.4, for 2.2 you have to choice of ZX5 or TLR 22.4, i asked him and he said ZX5 is closest to the avaible 2.4 wheel.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 01-01-2016, 09:27 AM   #9820
that would be cool,id buy a few,have a couple xb4 cars and they both have had the same issue a few times,its a pita to switch them out. ive never broke a tower so they are deff not the weak link. with the reinforcement of the 16 on the back side and this type reinforcement on the front side,would be really bullet proof. when will you have it back?
Old 01-01-2016, 10:09 AM   #9821
STLNLST's Avatar
Originally Posted by QDRHRSE View Post
My 2016 has been incredible. Nobody for 400 miles has parts but I haven't needed any. Still the fastest thing on the track with just a 13.5. I hardly need to get off the throttle. I was really worried about the car not working on a lower traction surface but its like cheating. I bought the car to run in 1 event over this next summer but I'm going to continue to use it for club racing. Its been the best car I've bought in a while.
What track do you race at?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-01-2016, 10:44 AM   #9822
Nope is not i've been running 3 races one of the best upgrade of my xb4
Old 01-01-2016, 10:56 AM   #9823
gticlay's Avatar
* For people trying to get the stock width with different wheels.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
Old 01-01-2016, 11:58 AM   #9824
PLUS 1 on this. I was told the same thing. I bought the hexs and then went out and got the 22-4 wheels. now to find out they were not right.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 01-01-2016, 12:07 PM   #9825
also on the 1st page it says you can use exotek 5.5mm and 7mm hex with tlr wheels. is this right or not. if it isnt then it should be taken down, if it is then thank god because thats what i ordered...
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
