Like Tree39Likes
Old 12-31-2015, 09:04 AM   #9796
Slapjack's Avatar
Trader Rating: 19 (100%+)
Thumbs up
Originally Posted by BentKa View Post
Thanks for the setup
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 12-31-2015, 09:06 AM   #9797
UK.hardcore's Avatar
for super low grip would you increase flex or put the motor rearward first?
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 12-31-2015, 09:13 AM   #9798
BentKa's Avatar
We always run motor to the rear together with shorty battery no matter how loose.
For super loose we run medium chassis braces with medium side guards, slipper, ball diffs front and rear and 1 dot springs.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 12-31-2015, 11:25 AM   #9799
Slapjack's Avatar
So I know the DE 2.4/60mm (22-4) wheels fit with the 9mm/5.5 exotek 12mm conversion... what about 2.2 wheels? I wanted to try the proline holeshots (are they good on both dirt and clay?). Obviously xrays will work? Will proline velocity wheels or DE 2.2's for dex410 or B44 work?
http://www3.towerhobbies.com/cgi-bin...&I=LXDSPX&P=SM
Does anyone happen to have a list of 12mm wheels that will work (2.2 & 2.4)? I feel like I ask this question often. (whenever I want to try something new). Or do people just figure out what fits by trial and error?
Old 12-31-2015, 11:57 AM   #9800
If it's very slippery clay holeshots might work. You should just use DE Racing 2.2 wheels, i plan to.
Old 12-31-2015, 12:20 PM   #9801
Slapjack's Avatar
DE 2.2 for which brand rc? Durango, associated or doesn't it matter? I like the DE wheels. I use them on my 1/8 buggy
But holeshots are real good on outdoor loose right? I have never used them before.
Old 12-31-2015, 12:46 PM   #9802
Kyosho front AE rear.
Old 12-31-2015, 02:36 PM   #9803
rcgod's Avatar
Trader Rating: 27 (100%+)
You want Kyosho front wheels not 22-4. The 22-4 are wider offset and will require a hex around 4.5mm thick to be right.
rcgod is offline   Reply With Quote
Old 12-31-2015, 02:44 PM   #9804
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
does anybody run a boosted 7.5 in a '16? if so what gearing and how much boost... ? thanks.
I use a Tekin RSX with a 8.5, 21T pinion and about 5* degrees of boost on a medium length back straight... without a fan. I just put a fan on, so probably go to a 24T.
Anywhere in that range is a good starting point probably.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 12-31-2015, 02:59 PM   #9805
kuruption's Avatar
I think we need to build a wheel database for the conversion...
I am running the XRAY +0.75 in the front with AKA EVO TLR 22-4 wheels and have a track width of ~245mm when subtracting the thickness of the tire side walls. With the XRAY +1.5 in the rear and AKA EVO rear wheels (subtracting side walls), I also have a track width of 245MM. Ride height at 22mm.
Ray Sundland
Old 12-31-2015, 04:41 PM   #9806
kuruption's Avatar
So I just put the 1.6/1.7 piston combo in my car w/ 650 fr and 550 rr.... the car feels really soft... and much softer than my B5M 2wd. Anyone have a more realistic combination for medium bite clay? I'm thinking something like 750 fr / 650 rr. BTW, I typically like my cars stiff and driving like a touring car.
Ray Sundland
Old 12-31-2015, 06:22 PM   #9807
rcgod's Avatar
I just did the same and used 600/450 and my car feels about right for the low bite I'll be racing on. I used the kit 2 hole pistons and opened up the holes with drills. If I was going to a med or high bite track I would probably go up in cst
Dialed RC Hobbies
Old 12-31-2015, 08:48 PM   #9808
Slapjack's Avatar
Originally Posted by rcgod View Post
You want Kyosho front wheels not 22-4. The Kyosho wheels are the same offset with the 5.5 exotek hexes as stock X-ray 14mm. The 22-4 are wider offset and will require a hex around 3mm thick to be right.
I really wish people would know te information they give is correct before posting an answer to someones question. I was told 22-4 would give me the correct width with 5.5 hexes. So if I'm understanding you correctly with what I have now (22-4) front and rear my front is going to be 2mm wider than in the rear? Is that necessarily a bad thing? Those are the only wheels I have currently and was planning on racing Saturday. So idk if I should glue up the tires and run as is or if I skip a race and order the kyosho fronts. You do mean DE speedline kyosho 2.4/60mm wheels is what I want right?
And what about my rear? I have 22-4 rears with exotek 9mm. Is that even correct?
Old 12-31-2015, 08:51 PM   #9809
Slapjack's Avatar
We deff need a chart of what wheels work with 12mm conversions to get you back to the stock track width. I'm sure a lot of ppl would find that very helpful.
Old 12-31-2015, 08:59 PM   #9810
Regional Moderator
RobsRacin's Avatar
Well last night I tried put 7,100,5 as well as 2x1.6 and 2x1.7's in the shocks as well as moving the ballstud to the forward hole of the steering plate and WOW the car was 10x better. Handles the bumps better and felt like it accelerated more linearly. We are still in between tires at the track and I made the wrong choice in the the main, but the car was still able to best hot laps I had set earlier in the day because of how easy it is to drive. Didnt get hotlap for the field but atleast another xray did. Now I just need to focus on my driving and making fine adjustments to the car, I am very happy with how it feels
RobsRacin is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
