Like Tree52Likes
Old 12-31-2015, 07:41 AM   #9781
UK.hardcore's Avatar
does anybody run a boosted 7.5 in a '16? if so what gearing and how much boost... ? thanks.
UK.hardcore is offline   Reply With Quote
Old 12-31-2015, 07:43 AM   #9782
BentKa's Avatar
Originally Posted by kuruption View Post
To make them 100% indestructible would just move the force of the impact to some other part that would break or bend (like a chassis!).
But then it wouldn't pr definition be 100% indestructible would it
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 12-31-2015, 07:47 AM   #9783
BentKa's Avatar
Originally Posted by rraden View Post
On what type of track conditions do the medium chassis braces and side guards begin to make a difference in improving vehicle grip?
And what disadvantages does it create on tracks with med-high grip?
Just looking to see if it makes sense to purchase these for setup options.
We run them on low to medium grip dirt or clay tracks.
On medium to high grip clay, astro or carpet we run the stock hard parts.
And on really high grip astro and carpet we run the additional carbon braces.
On high grip tracks the medium parts make the car more unpredictable as you will have unwanted flex in the chassis.
Bent
Old 12-31-2015, 07:52 AM   #9784
BentKa's Avatar
22-23 pinion for a 7.5T motor.
Amount of boost depends on motor, ESC, gearing and length of the straight on your track.
Find your preferable gearing for the rest of the track and if needed add a bit of boost to reach the wanted top speed on the straight.
If it tops out about 3/4 down the straight you are usually close to a manageable top speed.
Too much boost will just make it hard to control right before braking.
Bent
Old 12-31-2015, 08:05 AM   #9785
rraden's Avatar
Trader Rating: 234 (100%+)
Bent
Thanks Bent, just the type of advice I was looking for!
Xray XB8E 2016 | Xray XB4 2017 | Xray XB2 DE 2017 | Xray XB8 2017
Dirt Burners - Livonia, Mi
The Track - Carleton, MI
rraden is offline   Reply With Quote
Old 12-31-2015, 08:07 AM   #9786
BentKa's Avatar
Thanks Bent, just the type of advice I was looking!
Bent
Old 12-31-2015, 08:11 AM   #9787
rraden's Avatar
Originally Posted by Troyster View Post
The track I run at just changed the layout which means low grip for awhile. I installed the medium braces and side guards along with 500k in the center diff. Rest of the setup is basically stock until I run it at the track; waiting on new electronics to arrive.
I'd be curious to learn how your car performed on the lower bite track with the medium parts on it. I have a similar situation when the track changes here.
Old 12-31-2015, 09:19 AM   #9788
Slapjack's Avatar
Trader Rating: 19 (100%+)
What springs & fluid is a good starting point for '15 on low-med traction tracks?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 12-31-2015, 09:29 AM   #9789
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Can you run rear shocks in the rear for the '16? If so, do most people run that setup?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 12-31-2015, 09:44 AM   #9790
BentKa's Avatar
This is what we use:
http://forum.teamxray.com/xform/index.php?act=view&ID=85&setup=xb4_2015
Bent
Old 12-31-2015, 09:45 AM   #9791
BentKa's Avatar
Yes you can.....and no we don't
Bent
Old 12-31-2015, 09:56 AM   #9792
Slapjack's Avatar
Bent
I had the same question sorta... running in the front of the towers gives better traction? What would be the benefit of running behind the towers?
Old 12-31-2015, 09:59 AM   #9793
teeforb's Avatar
Bent
Can you elaborate why not
Old 12-31-2015, 10:00 AM   #9794
BentKa's Avatar
Running behind the tower gives slightly better bump handling and a bit slower rotation through corners.
Bent
Old 12-31-2015, 10:03 AM   #9795
BentKa's Avatar
You loose rotation in corners and you can't run as much droop (due to angle of the rear arms / anti squat) when running them behind.
For lower grip or bumpy tracks where it would be a benefit to run them in the rear we prefer to run added droop with the shocks in front instead.
Bent
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
