Like Tree36Likes
Old 12-27-2015, 04:39 PM   #9736
Regional Moderator
RobsRacin's Avatar
Originally Posted by suby723 View Post
Yeah 7 5 should be good. Try the slipper set to 0mm (all the way loose) also. For the Ackerman run the front hole, that will smooth out the steering.
Gotcha, I will make those changes and try them on Wednesday when I am at the track again. Thank you
RobsRacin is offline   Reply With Quote
Old 12-28-2015, 12:56 AM   #9737
BentKa's Avatar
Originally Posted by RobsRacin View Post
So ive been trying to dial my car in the past 2 days at the track, which is a medium bite hardpacked soil track, so far im running the kit setup as far as shock package goes, and have tried 8,60,8 for the diffs. I am after getting the rear of the car to be more locked in and the front to be a little less twitchy. I also noticed that I wanted more low speed steering for getting around the tight 180's as I would need to slide the car to get it pointed around the inside of the corner. The 7 up front helped with the low speed steering and I feel like the rear hasnt improved(although theoretically I may have gone backwards with the fluid to try and correct my issue?) I need to drill a set of pistons for 2x1.6 and 2x1.7 as I think that will soften the rear up as well as smooth out the front of the car. Any other suggestions? Thanks guys
For low to medium grip dirt / clay we run 1 dot springs front and rear, 2x1.6 / 600 cst front and 2x1.7 / 500 cst rear.
Get your center diff oil up to at least 300.000 cst or preferably 500.000 cst (we run 1.000.000 cst most of the time).
If you are running the '16 model also get the medium side guards (#361265) and medium front and rear chassis braces (front #361294 / rear #361295) as this will give you more chassis flex and much better traction for low to medium grip tracks.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 12-28-2015, 12:59 AM   #9738
BentKa's Avatar
Originally Posted by wheres_yogi View Post
Just picked up a '14 from a member on here.
Then you have plenty of carpet and astro setups here:
http://forum.teamxray.com/xsheets-search.php
Select XB4 '14 and click "Team Drivers" "YES" in the bottom right.
Bent
Old 12-28-2015, 01:02 AM   #9739
BentKa's Avatar
Originally Posted by Chartos View Post
Having a hard time getting slipper to slip at all on hard packed dirt with med. to med. high traction. Any suggestions?
Bob
Which model year do you have ?
Bent
Old 12-28-2015, 04:21 AM   #9740
jmcelroy42's Avatar
Bent
Does anyone know where to get these in the US? or anywhere?
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is online now   Reply With Quote
Old 12-28-2015, 04:56 AM   #9741
BentKa's Avatar
All of these parts are in good stock all over Europe and have been for quite some time now.
Why they are so hard to get hold of in the US you will have to ask RcAmerica.
They have been in stock at Xray for order for months.
Send them an email or put in an order from one of the European shops/distributors.
I know several US customers have had nothing but good experiences dealing with Gerhard at X-ray-shop.at
http://www.xray-shop.at/shop/product...5psqcrpb7tu1q4
Bent
Old 12-28-2015, 07:29 AM   #9742
RC America's Avatar
Hi,
We have them in stock. Any RC America dealer can order them for you, or you can contact us directly.
- Bryan
RC America is offline   Reply With Quote
Old 12-28-2015, 08:17 AM   #9743
BentKa's Avatar
Originally Posted by RC America View Post
Hi,
- Bryan
There you go
Thanks for the update Bryan
Bent
Old 12-28-2015, 08:43 AM   #9744
Slapjack's Avatar
Trader Rating: 19 (100%+)
What should I be running for med bite clay track with my '15 as far as slipper, ball diff, gear diff?
What about outdoor loose dirt track?
I assumed gear diff would be more for carpet and ball diff for dirt/clay? Is that right? Is the xray ball diff a good upgrade to the slipper or is it not much improvement?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 12-28-2015, 08:49 AM   #9745
Trader Rating: 18 (100%+)
Default 2016
Bent
I have the 2016 car.
Bob Chartos
Chartos is offline   Reply With Quote
Old 12-28-2015, 09:03 AM   #9746
BentKa's Avatar
This is an awesome setup for medium grip clay that we used on the '15 for Euros this year
http://forum.teamxray.com/xform/inde...setup=xb4_2015
+ YouTube Video
Bent
Old 12-28-2015, 09:06 AM   #9747
BentKa's Avatar
Okay.
We run the slipper at 0 - 0.4mm on the '16 which gives a good amount of slip.
Take the spring out and compress it a few times with a set of pliers.
Bent
Old 12-28-2015, 10:29 AM   #9748
jmcelroy42's Avatar
Hi,
- Bryan
Great, I sent you an Email.
Old 12-28-2015, 06:33 PM   #9749
Default Slipper
Okay.
Bent
Thanks, will try this week.
Bob Chartos
Old 12-28-2015, 08:29 PM   #9750
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default tightening motor mount screw
Hi guys...
how tight do I tighten the motor mount screw. .. I noticed the tighter I go the more the motor moves Towards motor
OHBRAD is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
