Like Tree45Likes
Old 12-19-2015, 06:24 PM   #9661
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Originally Posted by anthonyjesmond View Post
I installed the xray 12 degree caster and the xray aluminium rear hubs. I couldn't get my car to stop snap rolling. Big money upgraded, I don't want to take them off. How can I settled down the steering?
Thanks, anthony
Did you try changing your ackermann?
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 12-19-2015, 06:52 PM   #9662
Trader Rating: 32 (100%+)
Thanks, anthony
I have same problem like your also i upgrade 2.4mm wheels and rubbing the wheels inside the arm. I did down EPA steering from 100% to 85%
raved007 is offline   Reply With Quote
Old 12-19-2015, 08:12 PM   #9663
symmetricon's Avatar
Trader Rating: 27 (100%+)
My clay high bite setup where clay primes are choice.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 12-19-2015, 10:40 PM   #9664
BentKa's Avatar
Originally Posted by OliOC View Post
Hi Bent,
Sorry - just to clarify, you run 12mm hexes on both cars but run the 2wd fronts on the xb2 and 4wd fronts on the xb4?
Thanks,
Oli
Yep
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | Futaba | FX-Engines | Hudy | G-Force | Maxima Fuel
Hiro Seiko | DubiDesign | Maugrafix | YeahRacing | rcMart | LapMonitor | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 12-19-2015, 10:43 PM   #9665
BentKa's Avatar
Originally Posted by Nat Maniac View Post
Is there an XB8 thread and what is the release cycle for this car? Or perhaps more specifically will there be a 2016 released anytime soon?
Thanks v much.
Xray XB8Ethread:
http://www.rctech.net/forum/electric...8e-thread.html
Xray XB8 thread:
Xray XB8
1/8 OR kits are usually updated in the spring in time for the European outdoor season
Bent
Old 12-19-2015, 10:45 PM   #9666
BentKa's Avatar
BentKa I went with the box setup, I run on a high traction carpet. The car was on rails before but it seems really twitchy. Its very quick but very nimble and really sensitive to steering moments. Mostly on power coming out of turns. Thanks
Originally Posted by Franzchise View Post
I'm having the same issue as well. With the snap rolling, using the same ups, I'm not sure his setup but I believe he's running the same track as me, which is carpet and pretty high traction.
My setup is book stock aside from the 12 degree casters and aluminum hubs. Also my Shock position is 1 and 1 up front and 2 and 1 in rear.
EDIT: Just saw he posted above so I will follow your answers to his question. Thanks again Bent, big time appreciation for your continuing to share your tuning knowledge
For high grip carpet we use Malin's Worlds setup as a base:
http://forum.teamxray.com/xform/inde...setup=xb4_2016
What tires do you run ?
Bent
Old 12-19-2015, 10:49 PM   #9667
BentKa's Avatar
Originally Posted by blwaz23 View Post
What do you recommend for front and rear shock stroke?
For the '14 car we used either like the setup with 0mm internal limiters and no threads showing above shock rod ends or with 2mm limiters inside shocks for more on-power steering and a bit better rear grip coming into corners.
Bent
Old 12-19-2015, 11:02 PM   #9668
likea45's Avatar
One thing I notice on my '16 car is that the front arms have quite a bit more droop than my '15 car even with the stock limiters in. Was this intentional in the design? Honestly I like the way my 15 is handling better. 16 seems twitchy a bit even with the 12* blocks on and shocks stood up. It bears mentioning that my 15 car is running no top decks with the CF chassis stiffener kit, similar to the box setup that comes with the 16. Cars behave very differently though. I'm having trouble bonding with this car and that sucks. I want the car to be easy to drive and I'm not sure how to calm it down. Currently running 7kF-Slipper-7kR and shocks are two hole 1.6F and 1.7R with 40wt up front and 35R.
Current Rides: Kyosho ZX6 - Kyosho RB6 - Kyosho RT6 - Kyosho SC6.
likea45 is offline   Reply With Quote
Old 12-19-2015, 11:12 PM   #9669
BentKa's Avatar
Yes this is intentional.
This lets the suspension work much better at lower ride heights like 15-16mm and adds overall grip to the car.
What you refer to as twitchy we refer to as added steering
Standing the shocks up will make it more twitchy.
To calm it down we lay the shocks down, not stand them up
What surface are you running on and with what tires ?
Bent
Old 12-20-2015, 01:02 AM   #9670
Nat Maniac's Avatar
Originally Posted by BentKa View Post
Xray XB8Ethread:
Xray XB8 thread:
Xray XB8
Bent
Thanks very much.
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 12-20-2015, 06:02 AM   #9671
What kind of traction levels are you racing on? Going up in your diff fluids will calm down the "twitchyness" or what I like to call responsiveness. With the lighter diff fluids the car will rotate faster off the center point of the car.
Tell us what exactly the car is or isn't doing and let's see if we can dial it in for you a bit.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 12-20-2015, 08:23 AM   #9672
this might be a dumb question but can someone go into detail about the ISS inserts. The book trys to explain it but i still do understand 100%. also can someone explain what each setting will do and how it affects the car. thanks a ton as i am sure there will be a long reply.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 12-20-2015, 09:56 AM   #9673
BentKa's Avatar
Values for the different positions are all in the manual (except for the inbetween 0.5 positions).
The effect of all the different positions can be found here in the Hudy Offroad Book:
http://www.hudy.net/xhudy/showfile.php?file_id=692&crt=e555ebe0ce426f7f9b2be f0706315e0c
Bent
Old 12-20-2015, 10:50 AM   #9674
So higher diff oils will cause it to "push" into the corner a bit more. In the carpet it seems to hook and turn. Makes exiting the corner feel loose. I cant drive into the corner near as hard as i would like to
racesanything is offline   Reply With Quote
Old 12-20-2015, 11:02 AM   #9675
http://www.hudy.net/xhudy/showfile.p...2bef0706315e0c
Bent
yes i have read page in the book like 10 tens and i still dont understand it.
I guess where I get lost is if for example, if you get the inserts that have the dots in the middle but toward the inside it say -1.5 track, well what would the Anti Squat and Roll Center and Toe In? sorry if this is a really dumb question i am normally good at this stuff but just dont get there system. thank
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
