Like Tree45Likes
Old 12-11-2015, 05:11 PM   #9586
Trader Rating: 32 (100%+)
Originally Posted by randy0025 View Post
hate to double guess you but i run a 20 tooth pinion on my xb4 and have since the 14spec. 20/81 with the 81 spur gear being the stock one. so 20 seems alittle off being he is getting a 75 tooth spur????
but then again I guess it depends on what size motor. I run the orion r10.1 / Orion 6.5t combo
We have same ESC and motor the 20 pinion is not little off but 19 is off it will strip the spur gear.
raved007 is offline   Reply With Quote
Old 12-11-2015, 05:44 PM   #9587
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Any special fixes for a leaky rear diff? Rebuilt it and it still leaks, with a new gasket.
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING
Chris Kemper
Osiris 75 is online now   Reply With Quote
Old 12-11-2015, 07:36 PM   #9588
yeah I have the same issue with my center diff. Ive tried just about everything, I have tried and new blueseal/gasket, One with grease, and another one without. I have tried filling the diff at the cross pins and alittle under and still within 3-4 12min runs and its almost empty. I just ordered new orings and new plastics as thats the only left that can be it. btw 2 of my other friends who run the same car and basically the same setup have no issues with there diffs leaking at all. one of them has even built mine with a new gasket and yet again leaked.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 12-11-2015, 09:19 PM   #9589
Trader Rating: 114 (100%+)
Do *not* over tighten the diff case screws, that will make it leak out.
Do *not* over fill, as the pressure will make it seep out.
Try black grease or green slime on O-rings.
Chris Furman is offline   Reply With Quote
Old 12-12-2015, 04:23 PM   #9590
blwaz23's Avatar
What kind of grease can I use from home depot or Lowes that will substitute for black grease while the local hobby shop is out of black grease?
blwaz23 is offline   Reply With Quote
Old 12-12-2015, 05:02 PM   #9591
Black synthetic bearing grease.... Auto Zone, etc...
Old 12-12-2015, 05:36 PM   #9592
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
I use white lithium grease in parts, too.. Like the pinion and crown gear on the diff, instead of black. Don't know how it will work in the diff though.
kuruption is offline   Reply With Quote
Old 12-12-2015, 09:14 PM   #9593
Has anybody gone from the base carpet setup to the worlds setup on the 2016? The base setup is really good but i'm just wondering if its worth it to try it.
Edit: Also what would getting the 12 degree caster blocks do?
Kyle616 is offline   Reply With Quote
Old 12-12-2015, 09:33 PM   #9594
suby723's Avatar
Trader Rating: 21 (100%+)
The worlds setup is night and day better. I highly suggest trying the exact setup. The 12 degree blocks are a must have IMO. It will calm the steering down, you can push the car harder into the corner and takes away the twitchy feeling.
suby723 is offline   Reply With Quote
Old 12-12-2015, 09:49 PM   #9595
Alright I'll have to give the setup a try. I wish they weren't as expensive. I have to say the car was AMAZING compared to any other wheeler I have ever driven. I've never had a buggy be so smooth and consistent through the turns.
Old 12-12-2015, 10:25 PM   #9596
HSV427's Avatar
Trader Rating: 22 (96%+)
The 12 degree caster blocks are expensive, but once you drive the car with them on you will see its the best hop up you can buy, you will love it, its a night and day difference to the stock ones
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 12-12-2015, 10:32 PM   #9597
Edit: Nevermind
Old 12-13-2015, 02:43 PM   #9598
Trader Rating: 25 (100%+)
Default 12mm Hex
I am just ordering my firs Xray XB4. I have tried to search but can not find the exact answer. I want to run 12mm from my lost 22-4. I searched Xray info and Exotek but still not sure which I need to order. Anyone have exact answer to this? Thank you
mconway is offline   Reply With Quote
Old 12-13-2015, 02:44 PM   #9599
kuruption's Avatar
It's a few pages back...
+0.75 on the front
+1.5 on the rear
I also use TLR wheels on my buggy... but consider your overall width a tuning option, too.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
Old 12-13-2015, 05:35 PM   #9600
My xb4's front end comes up when I blip the throttle, do I calm that down by changing the front or rear kick? I'm running the book setup.
sealander is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
