Like Tree36Likes
Old 12-09-2015, 10:39 PM   #9571
Nat Maniac's Avatar
Originally Posted by suby723 View Post
The gears in the diffs have never been an issue. Nobody has ever stripped out the plastic gears. You can't even compare the xb4 to a d413. The 413 is a sloppy mess! You should have gotten the yz4 to compare to the xb4. IMO no wheeler comes close to how well the xb4 performs. Now your going to need to get a xb2 while your at it.
Is it safe to assume all of the above is sarcasm?
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 12-09-2015, 10:52 PM   #9572
gticlay's Avatar
Originally Posted by QDRHRSE View Post
Building my xb4 2016. The gears in the diffs are plastic? Do they hold up? I've heard that these cars are the best. So far, I'm not impressed. I picked up a D413 so that I could compare them head to head. Those diffs are not all plastic.
They do hold up. I have them in my 2016 XB4 and have been racing it on very high bite astro and carpet 20K front and 10K rear. No issues whatsoever. I have something like 25 or 35 packs through it so far. I do have the metal gears and pins, but that is supposed to be more for inertia and feel landing off jumps.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 12-10-2015, 06:21 AM   #9573
suby723's Avatar
Trader Rating: 21 (100%+)
Lets not get too far ahead of ourselves. I'm very happy with my AE cars. I even liked my b44.3 but got tired of carrying std hardware. People recommended both the D413 and the xb4. I'm ok at setting up a car and have friends that are pros. I'll let you know what I think after I run them both.
Sounds good. I'll be interested to hear your feedback about the car. The 16 has been the best wheeler I've ever owned.
suby723 is offline   Reply With Quote
Old 12-10-2015, 07:13 AM   #9574
symmetricon's Avatar
Trader Rating: 27 (100%+)
There is a huge difference in the way both these cars handle. I've owned both, and in fact most all wheeler except the zx6 and yz4. I am 100 % confident after a couple weeks comparing the two you'll realise how awesome the xb4 16 is. If you need setup help for high bit clay I have an awesome setup...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 12-10-2015, 07:54 AM   #9575
Originally Posted by RCHamburg View Post
Yes, I agree. And with the 2015 version you can use shorty lipos so the car is not too heavy. Furthermore some teams like Losi or Durango drove cars in that configuration at the world championships in Japan this year, so also a Xray XB4 2WD will work very well on high grip surfaces.
On super high grip stuff (carpet/dry astro) I prefer my XB4/2 with a 6.5 to anything else I have, it is very easy to drive fast and feels very "locked in"
Zak
PRS1 V3 (FM), Mugen MBX7 Eco
Team Absima UK
PR Racing UK
fivepointnine is offline   Reply With Quote
Old 12-10-2015, 04:44 PM   #9576
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default gearing for XB416
Hi Guys..
Has anyone tested or know what is the min and max gearing combinations for xb416
Example I'm buying the 75 spur.. but I need to know what the lowest and max pinion I can use
Brad
OHBRAD is offline   Reply With Quote
Old 12-10-2015, 04:52 PM   #9577
freakshow__'s Avatar
So quick question...
When I land from jumps...particularly when I overshoot triples and land on the flat, My car bounces a lot and it's a 50/50 chance that I'll land on my wheels when it's all said and done. Can anyone make a setup suggestion? Here's more info on my setup:
Surface is short cut Astro-turf....med/high traction
60wt fr oil, 40wt rr oil, 1.7 x 2 pistons f+r, 4 dot front springs, 3 dot rear springs. Basically I kinda mimic the Coelho and Bayer astro-turf setups.
freakshow__ is offline   Reply With Quote
Old 12-10-2015, 05:29 PM   #9578
I have never tried the 1.7 pistons but i did have that issue with my buggy where either it was chassis slap and bounce or bounce and flip. i switched to the Avid 2+2 pistons and it helped a ton. check them out on avid's site. they also helped the car drive so much better.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 12-10-2015, 05:44 PM   #9579
Trader Rating: 32 (100%+)
Originally Posted by OHBRAD View Post
Hi Guys..
Brad
You need 20 pinion and 19 pinion will not catch the spur gear.
raved007 is offline   Reply With Quote
Old 12-10-2015, 05:51 PM   #9580
hate to double guess you but i run a 20 tooth pinion on my xb4 and have since the 14spec. 20/81 with the 81 spur gear being the stock one. so 20 seems alittle off being he is getting a 75 tooth spur????
but then again I guess it depends on what size motor. I run the orion r10.1 / Orion 6.5t combo
Old 12-10-2015, 08:24 PM   #9581
suby723's Avatar
It's going to be a give or take. With heavy oil with stiff springs and at 15mm ride height that's just going to happen. You need to focus on landing on the downsides of the jumps. That setup is a big advantage in the corners. You can drive a lot more aggressive and carry more corner speed. I would prefer a better handling car over one that jumps better IMO.
Old 12-10-2015, 08:36 PM   #9582
Volition's Avatar
Hi Guys,
Need a favour - I race 4wd stock 17.5t in Australia its a reasonably popular class here. So weight is important. To compare the 4wd's on the market;
Could someone weigh there car - ideally as close to stock as possible with electronics and a shorty and body on.
Would be much appreciated? There is no prize for anyone who can post a reply the fastest. Thanks.
Volition is offline   Reply With Quote
Old 12-11-2015, 01:01 AM   #9583
OHBRAD's Avatar
hi again..
I'm running 17.5 .... One of the guys told me he couldn't get a FDR of 5.5.. So he got a 69 Associated and bore hole out...
they didn't have the 75 then..He now says that I can use a 75/ 33 pinion .. I need to know can I get a 33 pinion to mesh properly.
Old 12-11-2015, 04:21 PM   #9584
Cody102's Avatar
Originally Posted by Volition View Post
Hi Guys,
My XB4'15 weighed in at 1645g, running the following electrics:
- Orion R10.1 ESC
- Trinity D4 17.5
- Savox 1251 Servo
- Futaba RX
- 40mm Fan on the motor
- Transponder
only thing that isnt stock is the Diff gears, ring and pinion i changed to Composite, but even at that weight on Low-Med grip clay it needs some added back into it unless you can get a setup to suit the conditions with a car as light as mine, in high grip it shouldnt be too bad
if the Ball diffs were used, it could possibly be under weight... not 100% sure
Cody102 is offline   Reply With Quote
Old 12-11-2015, 04:34 PM   #9585
Cody102's Avatar
hi again..
i also run the 75t spur, can confirm at 33 WILL fit, it just max's out the motor mount adjustment, but mesh's perfect. seems a 33 will be as far you could go with a 75 spur, it will give you a 5.68FDR, although i run 75/31 on our track here in Perth for a 6.04FDR
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
