Like Tree39Likes
Old 11-26-2015, 01:32 PM   #9466
Nat Maniac's Avatar
Can someone please confirm if the front and rear diff cases are the same
I see that the part numbers are different but are they actually different
Perhaps going even further perhaps the top case is the same but the main section is different
Cheers
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 11-26-2015, 02:13 PM   #9467
Boz
Trader Rating: 23 (100%+)
Cheers
It was just the mounting point for the top plates on the old car. Due to the bulkhead being mounted on the rack, where the top plate was mount was angled so the top plate or x brace would sits flat. You could use the front on the rear, but the body post would be on a angle (that's if you are using one).
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
Old 11-26-2015, 02:13 PM   #9468
symmetricon's Avatar
Trader Rating: 27 (100%+)
Cheers
They are different.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-27-2015, 01:52 AM   #9469
Send a message via Skype™ to djbxp
Anybody running 3S Lipo using lower KV motor ? Can be done to achieve better efficiency and runtime ? Will it be race class legal ?
djbxp is offline   Reply With Quote
Old 11-27-2015, 02:43 AM   #9470
Why would you need more run time? A race is a little over 5 minutes long & with modern lipos, you can last 15 minutes easy with a 5.5, so I don't see the need
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 11-27-2015, 02:59 AM   #9471
HSV427's Avatar
Trader Rating: 21 (96%+)
Wow put the car on the track today with the 12 degree c-hubs and people were right its a night and day difference, yes they are expensive but with how much it improved the car it was worth every cent.
Serpent 977 35th anniversary. Serpent 977 evo2, Shepherd Velox, Motonica p81rs2, OS speed shimo edition.
HSV427 is offline   Reply With Quote
Old 11-27-2015, 05:22 AM   #9472
Higher voltage will give lower current for the same power and this will give better efficiency overall and also lower C rating on batteries. This is not purely for run time but also for practice reasons. Faster charges between batteries and 3S lower C rating are cheaper batteries.
Also am asking this :
1. to know if it is possible from technical point of view on the XB4.
2. to learn if it is race class legal to run on 3S Lipo.
Thanks for the support anyway.
Old 11-27-2015, 05:50 AM   #9473
tony montana's Avatar
Trader Rating: 65 (100%+)
Raced my 15 last weekend, car was not very good, basically stock setup with shorty, and 100k in the center diff, I basically just need the car to calm down some and be more predictable. Don't really wanna loose the steering, but need a tick more rear grip. Do not wanna run saddles either, suggestions?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 11-27-2015, 05:53 AM   #9474
Someone else might know if you can fit a 3S lipo in, I've not looked at one to know for sure, but you might need a '13-15 spec car, as they can take saddles.
Not sure about Cyprus if it's legal there or not, but here in the UK & I'd imagine most places, but it's 2S only.
A club might let you run 3S though.
Old 11-27-2015, 06:15 AM   #9475
cokemaster's Avatar
Trader Rating: 18 (100%+)
1. The XB4 is designed to take a shorty battery, so you will need to find a 3s battery with the same physical dimension. Even though most ESCs can handle 3S, not all modified motors can. e.g. only Tekin 10.5T and up can handle this voltage.
2. According to ROAR, IFMAR, etc. it will not be legal. However, you local club can make exemptions.
cokemaster is offline   Reply With Quote
Old 11-27-2015, 09:22 AM   #9476
rcgod's Avatar
3 dot front springs 1 dot rear. Rear arms and hubs forward.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 11-27-2015, 03:42 PM   #9477
Originally Posted by Boz View Post
Center ball diff! That must be new?
Are you sure?
sorry bout that . It's front or rear . I am wondering if there coming out with a center ball diff though . Oops😊
Losi57 is offline   Reply With Quote
Old 11-28-2015, 05:48 AM   #9478
Trader Rating: 114 (100%+)
Efficiency is relative.
1. not without major custom modifications, actually all of the 10th scale competition cars would need major custom modifications.
2. *not* race legal
Chris Furman is offline   Reply With Quote
Old 11-28-2015, 08:01 AM   #9479
Originally Posted by seth556 View Post
Move the arms forward, this will shift the weight of the car more towards the rear. Should give you less overall steering, but I find it's still a lot.
As mentioned, the 12* caster blocks will do wonders but they are expensive.
I was wondering about this because he said he has his 16spec setup to the book, and you suggested to move the arms forward. I was just wondering about this because isnt the book setup with the arms all the way forward? I mean they have it in the book so the 2mm is behind the hub pushing to forward correct? or are you not talking about that but talking about putting the 2mm shim in the back of the a arm where it connects to the diff case. thanks for clearing this up.
Kyosho Mp9E TKI3, Orion R8.1 with Orion 1900kv, Savox Tessman Edition
Losi 4.0E Orion r8.1 with Orion MR8 1750KV, Savox Tessman Edition
Xray Xb4 16spec Orion r10.1 with Orion 5.5t, Spectrum S6240
randy0025 is offline   Reply With Quote
Old 11-28-2015, 09:48 AM   #9480
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
The '16 manual has you put the shim behind the front A-arm, but depending if you want to use the default clay setup, it recommends in front of the A-Arm. I think the book may be based on the default carpet setup, so depending on your surface, when you build the car, you may want to watch the setup sheets.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
nudge2325
