Like Tree36Likes
Old 11-24-2015, 04:04 PM   #9451
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by HSV427 View Post
Does anyone know what setup changes i would look at making to lose some initial steering, l am running the book setup on a low to medium grip track. Thanks
12 degree caster blocks have a night and day difference. Makes the car way easier to drive and you can drive it a lot harder into corners.
suby723 is offline   Reply With Quote
Old 11-24-2015, 05:40 PM   #9452
Trader Rating: 32 (100%+)
Bent,
If i upgrade my xb4 '15 to xb4 '16 what parts to i need? It seems only different is chassis, differential box and center drive shaft.
raved007 is offline   Reply With Quote
Old 11-24-2015, 06:41 PM   #9453
Originally Posted by raved007 View Post
Bent,
add rear hub carriers, front & rear shock towers, front steering brace and new side gaurds.. then you are close enough.
Leon
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 11-24-2015, 06:50 PM   #9454
What gearing do you use for a 13.5 or 17.5 motor
billsharp34 is offline   Reply With Quote
Old 11-24-2015, 06:51 PM   #9455
Leon
My xray '15 also running steering top deck and aluminum rear upright part# XRA363352
Old 11-24-2015, 10:26 PM   #9456
BentKa's Avatar
Bent,
Parts that directly affect performance due to revised geometry/design or material are:
  • Front and rear shock towers (revised geometry)
  • Front and rear a-arms (revised geometry)
  • Chassis with front and rear chassis braces (revised geometry/weight balance/flex)
  • Chassis side guards (revised material/harder)
  • Front top deck (new design compared to '15 option deck = more flex/steering/front grip)
  • New 3 pad slipper (more consistent/easier to fine tune)
  • New rear uprights (revised lower roll center/alu. options are the same as '15)
It will be quite expensive to upgrade from the '15 to the '16 and I would rather suggest selling the '15 and buying a '16.
Option parts from the '15 can be carried over to the new '16.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-24-2015, 10:29 PM   #9457
BentKa's Avatar
If you fill out a setup sheet on the TeamXray site and post the link here it would be a lot easier to give suggestions as the options are quite a few
Bent
Old 11-25-2015, 12:44 AM   #9458
HSV427's Avatar
Trader Rating: 21 (96%+)
Bent
Thanks Bentka do you want me to post my setup, im running the book setup i have not changed anything at all and i run on low to medium grip track and i have far to much initial steering so any advise would be greatly appreciated.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 11-25-2015, 01:23 AM   #9459
bd581's Avatar
I run 69T associated spur with 32-33T pinion with an ORCA RX3 17.5.
Have to use the slipper assembly from a '15 spec in a '16
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 11-25-2015, 06:40 AM   #9460
Hi does anyone have a good setup sheet for for medium to loose dirt tracks with pretty big jumps for a 2015 xb4. The track we run on here is built for 1/8th scales.
Thanks for any help.
chamber is offline   Reply With Quote
Old 11-25-2015, 07:03 AM   #9461
seth556's Avatar
Trader Rating: 42 (100%+)
Move the arms forward, this will shift the weight of the car more towards the rear. Should give you less overall steering, but I find it's still a lot.
As mentioned, the 12* caster blocks will do wonders but they are expensive.
seth556 is offline   Reply With Quote
Old 11-25-2015, 08:02 AM   #9462
gticlay's Avatar
Anyone know if the 2015 and 2016 steering parts are the same?
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 11-25-2015, 08:11 AM   #9463
suby723's Avatar
Yes all that is the same.
Old 11-25-2015, 04:06 PM   #9464
Default Ball diff.
Just got the center ball diff. What would be the best way to set it. I know there's a few ways .
Losi57 is offline   Reply With Quote
Old 11-25-2015, 04:39 PM   #9465
Boz
Trader Rating: 23 (100%+)
Center ball diff! That must be new?
Are you sure?
Chris Bozich
Xray XB8 XB4 XB2
Futaba 4PX and servo's
Powered by Nosram motors and FX engines.
Many thanks to HEI and Perth RC for their support over the years.
Boz is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
