Like Tree52Likes
Old 01-04-2013, 12:14 AM   #931
racene1's Avatar
Trader Rating: 27 (100%+)
Originally Posted by CarlCrocco View Post
Here are my fixes for the intial issues with the XB4.
For the front bulkhead, I made a brace. My frontbulk head is actually broken, but with the brace is working fine. I attached a picture of the brace, it was handmade so its not perfect.
For the CVD plastic pin retainers, I have been using some DEX410 parts.
Team Durango Driveshaft Bushing
Team Durango B-Type Driveshaft Pin Set (2.0mm)
These pins use a set screw and will not fly out.
For the leaky shocks I have been using the DEX410 Orings.
Team Durango 10x1mm Shock Cap O-Ring Set
Hope this helps some people.
I am hoping Team SR looks at my brace and makes a nice one.
Hmmm, been following this thread to see the progression... maybe a durango is in order instead of just their parts to fix this one. Im normally not one to insite riots but 2 years in testing should have shown some of these problems, no? Or they are just willing to allow us to buy parts that they know will brake?
Hmmm, doritos for the brain.
JT
Las Vegas, NV
702 RC Raceway; Just off the Strip Come check it out!
racene1 is offline   Reply With Quote
Old 01-04-2013, 12:25 AM   #932
asc6000's Avatar
Trader Rating: 15 (100%+)
I also have a durango. This is the car for me. What are we talking about ? A few parts ? A bad batch ? Too early to tell.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 01-04-2013, 01:05 AM   #933
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by asc6000 View Post
rear shafts in the front ?, man you like some droop
Found the issue. If u switch the spindle bushings for higher roll center as given in the manual, then the shaft is not parallel to the arm causing the bind.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-04-2013, 02:26 AM   #934
Built myself a B44.2 FT as I was waiting for parts for the xb4, and the maiden was yesterday, cool car and nice to drive, but nothing compared to the Xray´s smoothness and balance straight out of the build/box. I must say i did never think there was gonna that much difference. ( 5 ball-cups broke the first 2 hours of driving, talk about bad parts. i guess you could say that they saved the tension from something else but still they broke like flies and I did not do much crashing or rolling. One hard landing was enough.)
The track shop had the back bulkheads for the xb4, and they worked perfect in front with a little shimming( tips from the shop owner and some guys at the track). So i drove them back to back.
Im not a pro, just trying to keep consistent lap times and not wreck them to much.
Not talking about very tuned-in cars here but stock setup on both.
The biggest difference for me was when I punched a lot of throttle on the straights, the b44.2 seemed to bounce around and the grip was slipping compared to xb4´s smooth traction all-around the track. also in the air the xb4 is well balanced and harder to get out of balance than the b44.2. I have my favorite now, no question about it.
AlekB is offline   Reply With Quote
Old 01-04-2013, 03:09 AM   #935
Trader Rating: 65 (100%+)
Well, I got my xb4 today. I'm slowly building the car. I've been reading this thread from day 1. So far it seems the shock towers, bulkheads, composite diff gears are breaking. I understand 4wd buggy you tend to break parts but, in this situation I've come to the conclusion that these parts are deficits.
Now, I'm curious to see what xray will do. I'm sure they are hearing about the few issues a lot of people are having. Once they do address the issues at hand. I'm wondering will folks that purchased the first batches get replacement parts?
Again I'm sure Xray will address the issues at hand. Way too many people having the same issue. Driver error ...well...it doesn't seem like the case. It kinda sucks that i spent 425.00 on this kit and I won't be able to race it until we find a solution to the issues at hand. Lastly I can't wait to race this bad boy!
nrm1977 is offline   Reply With Quote
Old 01-04-2013, 03:25 AM   #936
I don`t understand your problems.
I build the diffs exactly like the manual says, with the right amount of oil, using the Hudy scale.
No Problems with the Diffs - running on Carpet, with Schumacher Mini Pins. Tons of grip. Slipper on the tight side.
As I wrote before - too much oil will cause die gears to brake. So just do not overfill.
Shock Towers/Diff Case: No problems here - and I had some bad crashes. I run Durango and Kyosho before, these cars did break very often. Durango broke the arms.....Kyosho the diff case.
The XB4 nothing...until now. Same track, same electronics.
florianlaux is offline   Reply With Quote
Old 01-04-2013, 03:47 AM   #937
doorz's Avatar
Do team SR deliver international [australia] ?
I'm after a set of their xb4 shock towers,,
Cheers,,BAGGZ:
________________
ACE HOBBIES:ASSOCIATED:
REEDY:ORION:JCONCEPTS:
doorz is offline   Reply With Quote
Old 01-04-2013, 04:23 AM   #938
Dos Andos's Avatar
Trader Rating: 32 (100%+)
I don't get it. A dozen people have had problems from thousands of kits world wide... All this talk about shelving the car till X ray comes up with a fix, even before they run it...
BUILD YOUR CARS TO THE INSTRUCTIONS SETUP AND ALL. SET YOUR SLIPPER AT 6.3 to 6.4 THEN GO TO THE TRACK AND DRIVE THE THING.
The slipper will be loose but after 2 packs it will be bedded in and tighten up a bit by itself.
"Andy T"
www.adelaiderc.com.au - Team Driver
[email protected]
www.modelflight.com.au
*ARCR* member
Dos Andos is offline   Reply With Quote
Old 01-04-2013, 05:40 AM   #939
Try tapping the m3 screws in the bulkhead for the shock tower first with a tap not a screw. a few guys in the uk have noticed some of the bulkheads have been tapped when they bought the spare one. I know when i get mine i will be tapping most screw holes just incase
Radio Race Car International Contributor
Speedy Steve is offline   Reply With Quote
Old 01-04-2013, 06:18 AM   #940
Originally Posted by Autocratic View Post
I don't remember them being labeled.
There's a call out in the manual. Oh yeah, you don't read manuals. lol
losi b is offline   Reply With Quote
Old 01-04-2013, 06:33 AM   #941
BRSracing's Avatar
Trader Rating: 55 (100%+)
broke the camber rod part of the rear tower off... I had been wondering how you could do that, heres my story. Simple, accelerate 5 feet over a small double to an immediate 180 at the finish line. The 180 is around a pvc rail stacked two high and held by a spike pounded in the ground... well I landed on top of the pipe and slid... right into the spike head. Looked like the front hit as it slid off the rail (keep in mind this all happens in a ten foot space so the speed was slow) and I looked down to check and it looked okay so I took off but it was apparent after a couple turns something was wrong.
SO.... we looked carefully at the arms and could not see the impact mark so we could not confirm what I thought i saw (the front hit) but it must have caught the right rear arm. So a nice sharp (not big at all) shot broke that off ? Where does it get the angle or force ? hmmmm Not the cars fault at all, track maintainence would have cured that for me and many others.
Anyway I still love it.
Out of curiosity at your local indoor clay track do they stop watering the track a week before rebuilding ?
I seen two others break the same part first run. seems odd to not water a week before a rebuild. must make for a pretty bad racing surface during that week.
BRSracing is offline   Reply With Quote
Old 01-04-2013, 06:41 AM   #942
BRSracing's Avatar
I am confident the ones i have seen break were too manaul specs. the car has flaws and xray needs to step up and fix them. Have not heard a single story of xray helping people out. I hate seeing people get ripped off.
Old 01-04-2013, 07:36 AM   #943
Dos Andos's Avatar
You probably won't hear anything since they are still on holidays I'd imagine...
No one likes seeing people get ripped off but I hardly think X ray is guilty of that.
"Andy T"
[email protected]
*ARCR* member
Old 01-04-2013, 07:40 AM   #944
sickpuppy1's Avatar
There are some areas that need to be addressed, but nobody has mentioned feeling like they got ripped off. Upset,yes, ripped off,no one has mentioned that but you,and you dont own one....... be constructive not destructive.
If you cant fix it with a hammer, you have an electrical problem...
TeknoSCT410,Losi 22 2.0 & Eight-B 2.0,Losi LST2 , losi LXT circa 1990, it's a runner!
sickpuppy1 is online now   Reply With Quote
Old 01-04-2013, 08:10 AM   #945
reg
i remember when the new T2 008 came out,Xray sent out free parts to fix a problem,they sure arnt into ripping people off
reg is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-31-2016 12:53 AM
