Like Tree45Likes
Old 11-19-2015, 08:02 AM   #9406
gticlay's Avatar
Originally Posted by djbxp View Post
Thank you for your response, but the issue now is the motor size, rotor size and KV Selection. Too many parameters to choose
Savox says KV for their motor 6.5
http://www.savoxusa.com/Savox_6_5T_S...vblh365065.htm
Hobbywind Xerun 6.5T says KV 3650 - 5200 (???)
http://www.hobbypartz.com/07e-c-sd-6-5t-3650-blue.html
Turnigy Trackstar 6,5T IS 5150KV
http://hobbyking.com/hobbyking/store...or_5150KV.html
Reesy Sonic 6,5T is 540 size but no KV Rating.
What about size? 540 VS 550 ?
Poles?? i saw somewhere 3...
Rotor Size ? What about all that ?
Also what pinion gears i will need?
Doesn't matter - buy the 6.5 you like and they will all be approximately the same. Just look on the setup sheets and they all have gearing for 5.5, 6.5, and 7.5 motors. Get the Turnigy and see if you like that turn motor, then buy a better one once you have decided.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 11-19-2015, 08:04 AM   #9407
gticlay's Avatar
Originally Posted by BentKa View Post
Meausurements will vary with ride height, toe-in, bump steer etc.
Bent
Of course, however, I measured my car with both rims, back to back so that's about as close as I'm gonna get to comparing two kinds of rims on the car.
Old 11-19-2015, 08:07 AM   #9408
gticlay's Avatar
Originally Posted by symmetricon View Post
Bummer... first day with the car...
Oh man - I ran mine for about 30 full minutes in practice, then a full day of racing on very high bite carpet with the stock composite diff gears and zero issues for me. I used ballstud shims to set my slipper - have you tried that?
Old 11-19-2015, 08:11 AM   #9409
symmetricon's Avatar
Trader Rating: 27 (100%+)
The slipper was set fine, I can key one end of the out drive and turn the spur without much force... I simply had the brakes set too strong, and possibly I had a bad input gear, either way I had the brakes set way to strong...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-19-2015, 05:36 PM   #9410
Is there a difference between the plastic and aluminum Ackerman plate as in how the car handles
billsharp34 is offline   Reply With Quote
Old 11-19-2015, 07:30 PM   #9411
Just more holes to play with.
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 11-19-2015, 09:07 PM   #9412
The reason I ask is that it says it's for high traction but I run on clay
Old 11-19-2015, 09:21 PM   #9413
gticlay's Avatar
Aluminum will deflect less and be more consistent than the composite part. Like the difference between riding a steel tubed bicycle and one made from aluminum. Plus more holes to play with...
Old 11-19-2015, 11:34 PM   #9414
Ok I see now what changes when u use the inner vs the outer hole making the link longer or shorter
Old 11-20-2015, 05:13 PM   #9415
BigBrute_347's Avatar
Default Sway bars
Anybody else not running sway bars in their 2015 on med-high bite clay/dirt? Got this from the basic clay setup and it seems good...just curious.
BigBrute_347 is offline   Reply With Quote
Old 11-20-2015, 08:12 PM   #9416
BRSracing's Avatar
Trader Rating: 55 (100%+)
Is the 2016 car roar legal since it only uses a shorty pack
BRSracing is offline   Reply With Quote
Old 11-20-2015, 10:01 PM   #9417
gticlay's Avatar
Yes, it is ROAR legal.
Old 11-20-2015, 10:09 PM   #9418
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
You could technically stack saddles where the shorty sits, soooo..., yeah, it should be legal.
I think the rule will change eventually anyway, it already did once when a company ran a shorty in a car that was technically not legal. It should happen again as shorty packs are becoming the new standard in 10th scale off road.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 11-21-2015, 12:42 PM   #9419
Brit_racer's Avatar
Trader Rating: 134 (99%+)
So i have a 2014 XB4 that I am really happy with. I see its easy to drop in a center diff for the 2015 but i can not find out if this is possible with the 2014. Looks like i would have to get new drive shafts and maybe new top plates? Or maybe its not feasible.
Any info would be great.
Rc10B5m, Serpent SRX4, Xray XB2, T5m, RC8B3e, RC8T3e
Innovation Raceway
Brit_racer is offline   Reply With Quote
Old 11-21-2015, 01:53 PM   #9420
Nothing is impossible, but the centre diff doesn't fit the '13-14 cars, unless you mod the hell out of it.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
tenex
