Like Tree36Likes
Old 11-18-2015, 10:16 AM   #9391
Slapjack's Avatar
Trader Rating: 19 (100%+)
Can someone tell me if the '14, & '15 use the same front and rear drive shafts and what the lengths are and what part numbers I should be looking at getting? I know the front on my '14 is 68mm, not sure about rears. I am not home to check and want to order new ones right now. I see a set for the '15 on ebay but wasn't sure if they are the same.
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 11-18-2015, 10:41 AM   #9392
rraden's Avatar
Trader Rating: 231 (100%+)
Originally Posted by junior1178 View Post
Looking at giving off-road a try.. there seem to be some good deals on '13/'14'/'15... How would an older '13 hold up compared to a newer version??? I'm not looking to have the hottest technology but if it's really worth the upgrade, i'd rather get the newer model...
any feedback helps... it will be run on an outside dirt/clay track... 180x85...
thanks
I've owned and driven the 13/14/15 models and the 15 model is the best for me. With the 15 you have the option of running saddle packs or shorty's. In my experience moving the motor from the front half of the vehicle to the back half created a better balanced vehicle and improved overall handling. Nothing wrong with the 13 or 14 model other than the rear end likes to step out easier.
Xray XB8E 2016 | MBX7TR Eco | Xray XB4 2017 | Xray XB2 DE | Xray XB8 2017
Dirt Burners - Livonia, Mi
The Track - Carleton, MI
rraden is offline   Reply With Quote
Old 11-18-2015, 01:01 PM   #9393
gticlay's Avatar
Originally Posted by djbxp View Post
I'm expecting my new KIT XB4 and I'm coming from nitro 1:8th. I have no idea how to choose motor and ESC. I'm reading that motor's KV in relation to the battery has huge effect on runtime.
What do you guys recommend for motor in KV ? And what Pinion gear i may need? What adjustments to do for big tracks outdoor and what for indoor?
Also happent to have a reedy sonic motor size 550 & 5.5 turns / 3730KV. Can i use this one ?
Thanks in advanced.
You'll probably want to invest in a 6.5 turn motor. I can get 15 minutes on an indoor clay track without any over heating, etc with a 4500 shorty and no races are that long.
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 11-18-2015, 01:03 PM   #9394
gticlay's Avatar
Originally Posted by lagcisco View Post
I have an XB4 coming my way, can someone recommend a good starting setup for medium to high bite clay tracks? Specifically for OCRC, LRH and other local California tracks.
Here's a setup you might want to try that I found on the xray website. I think Bentka said they are ending up with same diff weights front and rear so I may try this at my local(ish) clay track with 7K front and rear. Anyway, thought this might be interesting.
http://forum.teamxray.com/xform/inde...setup=xb4_2016
Old 11-18-2015, 03:08 PM   #9395
gticlay's Avatar
Originally Posted by BentKa View Post
Took the time out of my day to measure the different track widths using the new Xray 12mm hex wheels with the Xray 12mm wheel hexes.
All measurement are done on the '16 XB4 using:
  • 20mm ride height (placed on Hudy 20mm droop blocks)
  • 3 degree toe-in in the rear
  • 1 degree toe-out in the front
  • Hinge pin inserts in the middle position front and rear.
  • Measured on the rear of the rear wheels (no tires)
  • Measured on the front of the front wheels (no tires)
Width using stock 14mm wheel hexes and Xray V2 14mm wheels:
  • Front: 245mm
  • Rear: 245mm
Width using 12mm wheel hexes and Xray 12mm wheels:
Front:
  • #365354 -0.75mm = 242mm
  • #365353 0mm = 243,5mm
  • #365355 +0.75mm (1 stripe) = 245mm
  • #365356 +1.5mm (2 stripe) = 246,5mm
  • #365357 +2.25mm (3 stripe) = 248mm
  • #365355 +3.00mm (4 stripe) = Not enough threads on axle to secure the wheel nut.
Rear:
  • #365353 0mm = 243mm
  • #365356 +1.5mm (2 stripe) = 247mm
  • #365357 +2.25mm (3 stripe) = 249mm
  • #365355 +3.00mm (4 stripe) = 251mm
Bent
Thanks for doing this, by the way. I measured my car with the Xray 12mm front wheels and with the TLR 22-4 wheels (I've been racing it since release so I have a TON of those wheels) and appears xray uses the same offset in their wheel as TLR does. Very good news for me. I probably don't have as nice of measuring equipment as you do, but someone else mentioned that the car was stock 245mm width with the TLR wheels and the +0.75 hex, I wanted to check that out for myself.
Here's my car too.
Old 11-18-2015, 11:46 PM   #9396
BentKa's Avatar
Here's my car too.
Meausurements will vary with ride height, toe-in, bump steer etc.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-19-2015, 12:22 AM   #9397
Send a message via Skype™ to djbxp
Thank you for your response, but the issue now is the motor size, rotor size and KV Selection. Too many parameters to choose
Savox says KV for their motor 6.5
http://www.savoxusa.com/Savox_6_5T_S...vblh365065.htm
Hobbywind Xerun 6.5T says KV 3650 - 5200 (???)
http://www.hobbypartz.com/07e-c-sd-6-5t-3650-blue.html
Turnigy Trackstar 6,5T IS 5150KV
http://hobbyking.com/hobbyking/store...or_5150KV.html
Reesy Sonic 6,5T is 540 size but no KV Rating.
What about size? 540 VS 550 ?
Poles?? i saw somewhere 3...
Rotor Size ? What about all that ?
Also what pinion gears i will need?
djbxp is offline   Reply With Quote
Old 11-19-2015, 01:12 AM   #9398
Don't worry about KV rating for 1/10th, 6.5 will vary from brand to brand.
20 or 21 pinion will work fine for 6.5, just need to check temps and lower number of teeth in case it get too hot that's it.
Motor size is 540. 6.5 is powerful enough in most cases and you could add timing if you need more power.
Coming from 1/10th I was a bit lost regarding KV and gearing for 1/8th e-buggy, you should be lost as well regarding 1/10th motors and gearing but overall it is very simple, check your temp and adjust to taste.
If you plan to run more than 5mn runs, then go for a 20T.
mojo tom is offline   Reply With Quote
Old 11-19-2015, 07:04 AM   #9399
seth556's Avatar
Trader Rating: 42 (100%+)
I hear that setup is pretty good The biggest things I've learned from it is the hard front spring, soft rear, and heavy-ish shock oil. That all makes the car super easy to drive. I was running 8/8k oils but the rear had too much drive in the sweepers, the 6k made it easier to manage. The car is super good, everyone who has driven it has either wondered what they need to do to make their car drive like mine or wonder how much they can sell their car for so they can buy an XB4.
Don't worry about the Kv rating. For sensored motors it's a pointless rating because as you move the timing up and down the Kv will jump all over the place. The Kv will probably jump a few thousand from minimal timing to full timing. Most likely you want a 6.5t, I usually turn my EPA down unless it's a giant track.
seth556 is offline   Reply With Quote
Old 11-19-2015, 07:33 AM   #9400
symmetricon's Avatar
Trader Rating: 27 (100%+)
Bummer... first day with the car...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-19-2015, 07:44 AM   #9401
suby723's Avatar
Trader Rating: 21 (100%+)
Honestly with this know issue this could be a major factor to push people to getting a yokomo unfortunately. Mine was perfect through the first race day but If this is going to be an issue I will not own this car for very long if I have to replace gears every weekend.
suby723 is offline   Reply With Quote
Old 11-19-2015, 07:51 AM   #9402
Although IMO it shouldn't have broken I didn't take the time to setup up my cars electronic settings. I had the brakes set way to strong and I race on super high bite clay with dirt glue sprayed on it. It stopped hard enough to cartwheel. I fully admit this was my fault not having my brakes setup correctly...
Fortunately the car runs fantastically, hands down more.corner speed than any other wheeler I've driven... I started with Bayers clay setup and found the oils and springs way to light... went back to stock springs and shock locations 1.6x2 hole 40wt 1.7x2 hole 35wt and it was excellent, the rest was Bayers setup...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-19-2015, 07:54 AM   #9403
First day with the the car and I ran my fastest lap ever and also ran the fastest in race lap.... not a coincidence. ...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-19-2015, 07:57 AM   #9404
suby723's Avatar
I completely agree. The 16 is the faster car I have ever owned and driven. I'm also very anxious to get my hands on the xb2 also.
Old 11-19-2015, 08:00 AM   #9405
Likewise, I'll definitely own the xb2, I have very high expectations after driving the 16', in fact I plan on switching to an all xray fleet...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
