Like Tree38Likes
Old 11-17-2015, 09:48 AM   #9376
Slapjack's Avatar
Trader Rating: 19 (100%+)
Originally Posted by rcgod View Post
Thanks, $45 for a 10th scale body is so expensive. I think the only other body I have seen that cost that much was a kyosho 8th scale truggy body.
Originally Posted by BentKa View Post
  • '16 body #369703 : rear section = 119mm wide / widest front part = 126mm
  • '15 body #369702 : rear section = 116mm wide / widest front part = 124mm
  • 13 / '14 body #369700 : rear section = 109mm wide / widest front part = 122mm
All measurements done on new uncut bodies.
Bent
Thank you, Do you think the '15 will work on the '14? I mean I'm sure it would but would it give me problems when running it? Or could I close up the 3.5mm/side gap with Velcro maybe?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 11-17-2015, 09:54 AM   #9377
Slapjack's Avatar
what is this body for? XRA369701 XB4 DMX Body
And has anyone bought from this buyer on ebay that makes the bodies? His feedback seems like the bodies are pretty good.
Old 11-17-2015, 10:03 AM   #9378
I think the DMX body was for the original XB4 2wd, it should fit the '14 spec car, but I think there was a shorter front body post to match the shell. You could always cut down the post you have.
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 11-17-2015, 11:44 AM   #9379
gticlay's Avatar
I'm curious if anyone knows how the stock plastic rear hubs compare to the vertical ballstud aluminum hubs in terms of placement - I would have to run "X" mm of spacers to be the same as the plastic stock hub. Thanks!
Thanks to Lunsford, Proline, Schelle, Xray, RCAmerica, and SMC for your support.
gticlay is offline   Reply With Quote
Old 11-17-2015, 11:55 AM   #9380
rcgod's Avatar
Trader Rating: 27 (100%+)
That body fits the 2014 car. I ran one and liked it better than the stock body.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 11-17-2015, 11:59 AM   #9381
rcgod's Avatar
Smh.
If you want the stock body they are $32 plus shipping at amain. By the time you get it you'll be out $40. So $45 doesn't sound like a bad deal imo.
Dialed RC Hobbies
Old 11-17-2015, 12:27 PM   #9382
BentKa's Avatar
4mm under ball stud to get to stock composite upright height.
Bent
Xray XB4 | Xray XB2 | Xray XT2 | Xray XB8 | Xray XB8E | Xray T4 | Xray X12
Factory Team driver for:
XRAY | ORCA | JConcepts | FX-Engines | Hudy | G-Force | Maxima Fuel | Hiro Seiko
DubiDesign | Maugrafix | YeahRacing | rcMart | IB Prostart
Follow Malin on Facebook for race reports and setup tips
BentKa is offline   Reply With Quote
Old 11-17-2015, 01:33 PM   #9383
Dadaman's Avatar
Trader Rating: 20 (100%+)
Does anyone run the XB4 '16 with a Tekin RSX with the fan and heat sink on it? If so, any chance someone could post a piccy of the layout? Also, how close does the fan come to the body?
Dadaman is offline   Reply With Quote
Old 11-17-2015, 03:31 PM   #9384
jmcelroy42's Avatar
I run an RSX in my '16, clears the body fine as long as you run the wires out the side and not up.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 11-18-2015, 01:23 AM   #9385
They say the aluminum Ackerman plate is for high traction is anybody running on clay also changing from the inner hole to the outer holes what does that change
billsharp34 is offline   Reply With Quote
Old 11-18-2015, 07:36 AM   #9386
Send a message via Skype™ to djbxp
Default Motor & ESC
I'm expecting my new KIT XB4 and I'm coming from nitro 1:8th. I have no idea how to choose motor and ESC. I'm reading that motor's KV in relation to the battery has huge effect on runtime.
What do you guys recommend for motor in KV ? And what Pinion gear i may need? What adjustments to do for big tracks outdoor and what for indoor?
Also happent to have a reedy sonic motor size 550 & 5.5 turns / 3730KV. Can i use this one ?
Thanks in advanced.
djbxp is offline   Reply With Quote
Old 11-18-2015, 07:46 AM   #9387
symmetricon's Avatar
Can anyone compare the 16' box setup vs Bayers 2015 clay setup?
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-18-2015, 08:29 AM   #9388
Looking at giving off-road a try.. there seem to be some good deals on '13/'14'/'15... How would an older '13 hold up compared to a newer version??? I'm not looking to have the hottest technology but if it's really worth the upgrade, i'd rather get the newer model...
any feedback helps... it will be run on an outside dirt/clay track... 180x85...
thanks
junior1178 is online now   Reply With Quote
Old 11-18-2015, 09:23 AM   #9389
Regional Moderator
RobsRacin's Avatar
Well ive got a 16' XB4 on the way, looking forward to the build and driving it
RobsRacin is offline   Reply With Quote
Old 11-18-2015, 09:35 AM   #9390
thanks
I can't speak for dirt/clay tracks, but I drove a mates box standard '16 car a couple of weeks back on damp, slippy astro & it felt A LOT better then my '13 car, that is pretty well setup for our track.
EP buggies thread sim600 Malaysian R/C Racers 3586 03-30-2016 11:53 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
TPR 1
